Question about Dell PowerEdge 6300 Server
Dell PowerEdge 6300 Server Hangs after A13 Bios Upgrade
Unfortunately we just installed a required A13 BIOS upgrade while online with DELL Support.
We were at BIOS A11 running WIN2000TS and are preparing to go to WIN2003 so we flashed the BIOS and end up hanging after the POST
Just after the firmware check and print to screen;
Hot Plug PCI v 1.18
Not sure if we can find someone who found away around the hang but we had an instance where hitting F2 allow us into the BIOS once. Unfortunately we did not have a Floppy in the FDD with a rollback BIOS on it so we missed the chance. No such luck at F2 since...
  • 22 Answers
Re: Dell PowerEdge 6300 Server Hangs after A13 Bios...
I know this sounds simple but did you reset the BIOS by jumping it after pulling out the motherboard battery?
Posted on Dec 10, 2007
  • 921 Answers
When a BIOS is flashed it frequently resets all of the settings to default.
Go into BIOS settings and make sure that the proper boot device is selected.
I hope this helps.
Posted on Jul 30, 2009
0 characters
3 Points
CMOS Battery replacement
Hello here is a link to the homepage:
And here is the download site for drivers:
Try also to upgrade the bios. just make sure its the right model.
You maybe have to set up the boot settings when you replace the cmos battery or renew the bios.
Good luck
Nov 07, 2012 | Dell PowerEdge 6650 Server
Hi , i have just put 2 new processor in my Dell Poweredge 2600. but now it is showing nothing on the Monitor - Please help
You can check process in System do this
Go to program>Accessory>system tools>System Information
OR chec in BIOS. It definatley list all h/W devices..Also Check if another monior is working
I can suggest to upgrade firmware..
Feb 16, 2011 | Dell PowerEdge 2600 Server
Dell poweredge 1800 bios not installed. how do I intall the bios? I bought it used.
enter the bios.F2
You can download the update CD from here. Also, you can update the bios from within windows with this utility (still requires reboot).
Jan 08, 2011 | Dell PowerEdge 1800 Server
BIOS RAM change on Dell Poweredge 1600SC
When you inter the bios open the memory in the bios be sure to save on exit hope this helps
You may have to turn somthing off Like the USB in bios setup then save next return to bios and trun the USB back on and save the scond time . if this not help you Bruce e-mail me and i will call you
Nov 15, 2009 | Dell PowerEdge 1600SC Server
Can not boot dell 6650 from external dvd
Have you checked boot device options....from BIOS
Use F9 during boot to goto ROM-BIOS and change Boot device option to CDROM/DVDROM.
Insert Boot media or DVD-Win2003, to DVD-ROM device..
reboot Server, try now
If still issue.. Check to boot Server using some other media..
if other cd media works, then it could be DVD-Win2003 faulty, otherwise download firmware for CD/DVDROM and upgrade it and check if DVDROM works, otherwise you have to contact Dell Support..
Oct 06, 2009 | Dell PowerEdge 6650 Server
Dell poweredge 4300 Bootup problem after replacing cmos battery
Look for a jumper on the motherboard where it would allow you to clear the cmos. basically you would move the position of the jumper and turn on the computer and let it clear itself.
Then after it clears turn off the machine, put the jumper back into its original position and then turn the computer on and see if the message goes away.
Also go into the BIOS and put in the correct time, date, year, etc.
Aug 16, 2009 | Dell PowerEdge 4300 Server
Videoadapter in Dell 1650 server possible ?
8MB sounds like it is only recognizing onboard video.
Check the BIOS setup screen for video options. You may be able to select or enable PCI video.
If that does not work, Dell has lifetime phone support for their servers.
Write down the Express Service Code and Service Tag number that is on the server chassis and call Dell.
This is the last number I used for server support: (800) 945-3355
If it doesn't work you should be able to find a valid number at
I hope this helps.
Jan 13, 2009 | Dell PowerEdge 1650 Server
PowerEdge Server won't boot after memory upgrade
if you really need the BIOS update. you need a working PC to download the BIOS and unzip it to a CD. install it, since the PC do see the CD, you may have do some maneuver to ge the BIOS installed.
Oct 29, 2008 | Dell PowerEdge 1800 Server
1600sc second CPU
Yes, some systems (newer PowerEdge Servers, generally 6/7th Generation and above) have onboard VRMs.
1600sc is a 6th gen PowerEdge (with Simple Computing). I can checked and be absolute certain from within Dell. I'm on VAC until Saturday.
In the meantime, check the PRC model and revision and ensure that they match. Given that a single PRC POST/Boots, try upgrading (if not already) the system BIOS to latest revision.
If the PRC model/revision does match and you have the latest BIOS version, also if the VRMs are not needed, then from the Troubleshooting you have already done, we may conclude that the PRC 2 slot is faulty.
I will confirm the VRM query on Saturday.
PowerEdge 1600SC, BIOS A12 Update Package for Microsoft Windows -
PowerEdge 1600SC, BIOS A12 Floppy Update Package -
May 14, 2008 | Dell PowerEdge 1600SC Server
Memory and RAID Card for a Dell 1600SC
May be worth reseting the bios using the on-board jumper.
Jun 01, 2007 | Dell PowerEdge 1600SC Server
Dell PowerEdge 6300 Server Logo
1,112 people viewed this question
Top Dell Computer Servers Experts
Jax Planet
Jax Planet
Shawn DuRee
Edd nugent
Level 1 Expert
Are you a Dell Computer Server Expert? Answer questions, earn points and help others
