Question about Health & Beauty
It is a allen bradley 100-c16*400 ser.B I don't know what order thw wires go from the relay to the fanal like #58 goes to L1 or L2 that type of problem
  • LOLA Jun 27, 2009
    I need a wiring diagram for wiring the allen bradley contactor 100-c16*400 fanal to the allen bradley relay switch that you must have for the Sunal profi 3200 TANNING BED
    Brigadier General:
  • 3,917 Answers
Hope this helps.
Wiring Diagrams — Perimeter Access Controls Schematic Diagram Transmitter Receiver it is a allen bradley - diagram1.gif diagram2.gif Connector Pinout Diagram Transmitter Receiver 7-Pin Connector
diagram3.gif 8-Pin Connecit is a allen bradley - diagram4.gifg src="http://i.fixya.net/uploads/images/diagram4.gif" alt="diagram4.gif" class="h_mi" />
Or for more instruction please check the manual:
http://www.ab.com/industrialcontrols/products/solid-state_motor_control/soft_starters/pdf/adv_motor_wiring_diagram.pdf
Thanks for contacting Fixya.
Posted on Jun 27, 2009
Can you get me a diagram on electrical hookup?
Hello;
My name is Peter. I am a retired field service technician.
I do not know if you have a 3 wire or 4 wire connection. For a 3 wire connection you need 15 AMPS at the breaker box. For a 4 wire connection you need 30 AMPS at the breaker box.
Three wire hookup. Center wire goes to N, the other two wires are hot. It makes not difference witch of these two wires go to L1 or L2. The ground goes to the cabinet.
Check the voltage - With a volt meter between L1 & N = 220V, L2 & N = 220V, L1 & L2 = 240. These readings are general. You may get something like 210V instead of 200V
Mar 10, 2015 | Dryers
Sunal tanning bed m# X144459200 In need of wiring diagram if possible The problem im having is when you power the bed all I get is a loud buzzing sound coming from the relay/contactor there is 116 volts...
The buzzing sound indicates a problem with the relay itself. It is a simple device whose purpose is to take a small amount of electricity ( like turning your timer switch on) which activates a small electromagnet coil, which then pulls down a metal contact bar which closes a switch to activate a major power consumer ( like the bank of lights on the tan bed).
The reason to do this is so you don't have like 3000 watts or more of power passing thru your timer switch which would require much beefier wiring and controls. SO by using a relay, the relay uses a small amount of power to flip a switch on the major circuit.
The relay buzzing sounds like either the coil in the relay is shorted out (the heat sometimes melts the insulation on the wires in the coil), and the short is taking away enough power from the relay magnet coil that it can't pull down the switch activation bar to switch on the bed.
If you have a voltmeter you can measure the voltage in the activated circuit that powers the bulbs. The wires should be the bigger gauge ones. If you are getting low voltage or no voltage in the secondary circuit (that is the circuit with high amps that runs the bulbs and fans) that is a good indicator the relay is bad .
If oyu know your way around basic electricity, you can isolate one of the ballasts that feed some light bulbs and hook a 110V power source to that ballast and see if some of those lights come on. If they do that is further confirmation the relay is bad and you may need to order a new one
Jan 27, 2015 | Heating & Cooling
How do you wire a type b 3450 rpm mod.c48k2pa105c5 motor to electrical box
two red wires means 220 volt those are both hot green is ground
red to L1 2nd red to L2 then green to ground ( to case) make sure on side of motor it is wired for 220 volt
Apr 03, 2013 | AO Smith A O Smith Motors Century 1hp 115v...
Multiple operations in single command on new TI84
Run SetUpEditor to restore the list names L1, to L6
100->dim(L1) to set the dimension of L1 to 100
100->dim(L2) to set the dimension of L2 to 100.
Since you are going to store the random numbers in L1, you should use L2 as the FreqList. All elements of L2 should be 1. When you create it all its elements are 0. One way to fill it with 1's is 10 run the command
L2+1>L2; Add 1 to each number and store the results in L2 (overwrite the 0 values)
Perform a blank run of 1-var Stats to get the chance to set the default lists.
1-var Stats L1, L2 ENTER
Type in your command
randNorm(64.5,2.5,100) STO> L1:1-var Stats L1, L2 ENTER.
Use the Catalog to type in the 1-var Stats commnad so that you can type in the Lists L1 and L2 without opening the 1-var Stats configuration screen.
Do what you have to do with the statistics you generated.
To rerun the two commands again, press [2nd][ MODE] to (QUIT)
or press the sequence [2nd][ENTER] to have the last (ENTRY) echo on the main screen. Press ENTER to run again
Hoe it helps.
Jan 13, 2012 | Texas Instruments TI-84 Plus Calculator
I am trying to wire a dayton booster pump. it shows a L1 and L2 connection on the 115v connection. L1 goes to P1 L2 goes to T4. on the 220v connection it shows L1 and L2. L1 goes to wire P1 and L2 goes...
The power cord has a green ground wire; two hot wires, which are black and red; and a white neutral wire. Attach the neutral to the middle connector and the two hot wires to either end of the terminal.
In order to safely ground the machine the green ground wire must be securely connected to the dryer frame. There may be a screw on the frame where you can attach the ground
Jul 17, 2011 | Kitchen Ranges
Power cord comme unpluged from inside ac unit. has 2 spade and 1 green ground where do they go ?
Look for the terminals on the switch marked, "L1" and L2. this is where the two spade clips go. It really doesn't matter which one goes to L1 or L2 as long as you don't wire the green to either one. The green wire is the ground and should be screwed or clipped to the case of the unit.
Jun 05, 2011 | Heating & Cooling
Hi just wondering about 240 volt.What is the black wire and what is the red one and green and yellow....Which one is L1- N- E
The black wire is Half of the 240 volts. Both the black and red wires carry 120 volts to make 240 volts. The green wire is going to be your grounding wire. The yellow wir is more than likely your neutral wire (although that goes against the electrical code). Tie in L1 to either black or red. Attach the yellow to n. I hae no idea what the E stands for. What color and how many wire are coming from the oven?
May 08, 2011 | Ovens
I bought a new universal ac contactor relay to replaced the o.e.m. the new has l1 l2 t1 t2 . the old relay don't say l1 l2 t1 t2 or any indicatio.
The contactor should look alike. Just make sure the same wires are on the same side as the old contactor. Don't worry so much of the l1/t1 and l2/t2
Apr 05, 2011 | Heating & Cooling
I take it the wiring harness in front of me is 3 Phase. I have a Green wire, Red, Black and White. The wiring diagram on the back is marked L1, L2, N, E. Just need to know which wire goes where thanks.
It is not 3 phase...just single phase 240V....L1 goes to the one hot side of the 240 v, l2 goes to the other hot side of the 240V, N goes to neutral, and green goes to earth ground (metal box)
so....L1=Black L2=Red N=White E=Green
Jan 22, 2011 | Ovens
Need to know what color wire coming from motor itself and where they go.....wiring diagram on side only tells leg 1 and leg two and so on, but the wires coming from the motor are not attached to those...
Thank you for posting your question here on Fixya.com.
Part of your problem will be the snake has a reversing switch so it is not as simple as just wiring two line leads. I assume you have a DPDT switch for reversing it? If so line goes to the center posts/terminals, motor L1 and L2 go to one end, motor red and black to the other end, and a jumper crisscrosses from end to end allowing the reversing.
In essence, what has to happen is in one direction motor L1 and red get power from one line and motor L2 and black from the other; to reverse motor L1 and BLACK get power from one line and motor L2 and RED the other. All of this assumes you are connecting to 115VAC since that is the portion of the diagram you reference. If not, add a comment with what you are connecting to.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. You may also contact me thru our website at www.arrowpools.net. Positive feedback is appreciated once your problem is solved!
John
Dec 14, 2010 | AO Smith 1 1/2 HP 115/230V 56C Replacement...
Health & Beauty Logo
827 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
