Question about Coleman Mach III Air Conditioner
Coleman roof top rv air no cool,warm compressor
My rv has been parked a year now so the ac has to act up right.The compressor tries to kick on for a few seconds but stops.The compressor gets hot.The fan and everything else seems to be ok.It did this a few years back and then just started working on it own.It is a sealed unit Coleman roof top unit,so if it needs freon do I buy a new unit or have a valve installed to charge it?If low on freon what do you do seing as it it sealed??If that is my troubles,how do I find out??Can I check volts for start and run?What should they read?
If I need to replace it how do I know what size unit it is?This is a 98 model and the tag is pretty much faded under the roof top cover.
Thanks!
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 127 Answers
No Cooling.
Turn the selector switch to “Cool” and the
thermostat to a low temperature (below room temperature).
The fan runs OK, but the unit does not cool. When the unit
housing is removed, we observe that the compressor does not
run; however, it periodically hums for 15 to 30 seconds.
Possible Causes- Check all of this before buying a new unit, that may not be the solution.
“The voltage could be low – ”
a) Check the voltage between #1 on the
overload switch and the “R” terminal of the
compressor while it is not humming. This
voltage must be 115 volts domestic USA
models or 240 volts export/overseas models.
No less than minus 10% is allowable.
b) Check the voltage from “C” or “R” of the
compressor while it is humming (trying to
start). The latter reading will probably be
lower, but it still must be 103.5 volts
minimum domestic USA or 216 volts
minimum export/overseas models.
If the first reading is above 103.5V domestic USA and
the second is under 103.5V domestic USA, there is
too much voltage drop in the lines - a situation which
must be corrected for the air conditioner to perform
safely and satisfactorily.
2. “A capacitor could be shorted, weak or open.”
Turn the power off.
Caution – There is always a chance that a capacitor is
holding a residual charge, so before touching a
terminal, discharge the capacitor as explained earlier
in this booklet.
Remove capacitors, visually examine them and test
them per instructions given in earlier section on
capacitor testing (See page 9).
If the capacitors test OK, replace them and carefully
reconnect the wires. Be sure the wires are connected
to the right terminals.
3. “Start relay contacts could be open – ” if so equipped.
Turn off all power, then check for continuity with
ohm meter between terminals 1 & 2.
4. “Compressor start winding could be open or
grounded.”
Check compressor windings per instructions. See the
section on the compressors (See page 8).
5. “Compressor could be mechanically stuck.”
This very rarely occurs and when it does, it is usually
after a lengthy shutdown. This should be considered
only after all the above possible causes have been
positively eliminated. To free a stuck compressor, use
your hermetic analyzer according to the
manufacturers instructions.
Posted on Jun 29, 2009
Coleman mach rv roof ac, the fan comes on but the compressor doesn't, i've replaced all capacitors and stll is not comming on, how do i check voltage to the compressor to maske sure i have pow
At the compressor connectors you have a live and a neutral phase. The live usually goes to a ptc relay starting mechanism which you can test with a meter. If you can disconnect the relay and check the windings of the compressor from one pin to the other two it will tell you if the compressor is open circuit. It is more often than not an overload fault.
Apr 23, 2012 | Coleman Heating & Cooling
Coleman Roof AC on RV. Hums on COOL/Auto. Fan runs ON Only. I feel the compressor is locked up. Thank You in Advance, Dennis
Hi, Try this , Go on the roof and open the cover and cleanout any screens and filters you can find.
If this does not work seek a proffessional to look at it. Good luck.
Aug 03, 2011 | Heating & Cooling
I have a coleman roof top air conditioner on my 2006 Jayco travel trailer. The air conditioner will start to run and the fan blow air but it doesn't want to cool down. Is there somehting I should do or...
COLEMAN R.V. AIR CONDITIONER SERVICE AND REPAIR QUESTIONS
COLEMAN R.V. PRODUCTS
GO TO rvcomfort.com
Click on RVP (RV PRODUCTS)
Click on type of AC, if you can’t find the information you want there,
then click on contact us on the Green Bar.
You can get Service Support or Email address and Phone numbers.
Jul 27, 2010 | Coleman Mach III Air Conditioner
Coleman RV Roof Type 110v
GO TO rvcomfort.com
Jul 25, 2010 | Coleman Heating & Cooling
Coleman mach 3 rv roof mount ac
You will need 12 vdc (battery or converter) for controls to work, and 115 VAC (hydro) for fan & compressor to work. With your fan obviously working, that tells me you have both already but compressor may not be kicking in. Do you hear a "moaning" sound or see lights dim when switched to cool?
Aug 17, 2009 | Coleman Mach III Air Conditioner
Can my duo-therm air conditioner on my rv be recharged?
These unit can be recharged. 134A. You NEED A SERVICE TECH THAT KNOWS HOW TO CHARGE UNIT.RUS
Jun 24, 2009 | Dometic Rooftop RV Air Conditioner
Coleman (RVP) 7000 AC unit compressor problem
I had a problem with my coleman mach 3 AC, we were at an RV park up at lake shasta CA and the fan would stay on but the compressor would come on for a few seconds and then trip off. It was the motor overload relay on the compressor that was tripping. the RV park was old and apparently the wiring to the panelboard at the RV park was too small, when you are drawing a lot of current there was too much voltage drop across their line, to make up for this the motor tries to draw more current and heats up the motor overload and it trips off. I solved this problem by buying an autoformer from Camping World, it senses a voltage drop and automatically boosts the voltage.
I am now having a seperate problem, the compressor is either locked up or has too much back pressure and trips off the service breaker when trying to start. The only solution I can see with my current problem is to replace the entire unit.
Oct 07, 2008 | Coleman Mach 15 Air Conditioner
Coleman Mach III Air Conditioner Logo
854 people viewed this question
Top Coleman Heating & Cooling Experts
Bill Long
Paul Carew
Dan Webster
Dan Webster
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
