Question about Pentair MiniMax 100 Aboveground 100,000 BTU Propane Gas Electronic Heater
High pressure, and heater noise
I have a pacfab minimax 100 heater. It makes loud banging noises when pump shuts off and waterflow stops. The heater's outlet water plumbing fitting is failing as if there is too much pressure. My pool pressure gauge is now running high. Is the high pressure and heater noise connected? Is the heater exchanger getting blocked on the inside? I clean the outside every year since heater got too hot and burned through the fusible shutoff link.
    Problem Solver:
  • 15 Answers
The high pressure and heater noise are not connected.
The loud banging noises coming out of your heater is when theres is no water flow entering heater, it is a mistake to shut pool filter before shutting heater, i recomended shutting heater second.
It is normal for the bang on the heater when water flow dont exist.
shut heater first then filter. the psi on the gauge is high cause filter needs a backwash or clean, the filter. Remember the heater only heats the water that's it. it is seprate from pool filter.
Posted on Jul 15, 2009
  • 83 Answers
I am not sure if you have solved this issue, or not, but if the PSI on the gauge is high then the problem may not be the heater. When you have the system turned on, and the PSI is reading higher than normal, just the flow of water coming out your return lines. If the flow is normal, like when you clean your filter, then see if you have a way to re-route the water so it bypasses the heater. If the PSI on gauge drops, then the issue is in the heater.
If the flow of water is slower than normal, with the PSI reading high, then you have a blockage somewhere in the system. It could be something simple like removing debris from skimmer and pump backets, to time to backwash, or clean, the filter.
If the flow of water is really hard and fast, with the PSI high as well, then you have too much water going through the system and need to slow it down.
Posted on Jul 01, 2009
Pentair Mini max my power light comes on but my pressure sw does not light up
if pressure switch does not light that means no pressure either water flow or a bad pressure switch you can jump the wires on the pressure switch but be very carefull if it does start make sure it does not bang or make noises
May 14, 2014 | Pentair Minimax NT Heater
Raypack 2100 pool heater runs for a couple of minutes then loud banging noise. heater shuts off and error code HL appears
That HL is your high limit shutting the heater down. The banging is the sound of water boiling in the heat exchanger because it is moving too slow. This is almost always the result of the bypass or governor (thermostat) not working properly, so too much water is bypassing the heater. It's not too hard of a fix.
Dec 17, 2013 | Raypak RP2100 DIGITAL POOL HEATER R265
Hayward making grinding noise
low waterflow check filters or need more pump flow
Aug 13, 2012 | Hayward H Series Induced Draft Abg 100,000...
Banging noise when heater is on
not enough water pressure check pump and filters if ok check manual bypass (on side by plumbing)
May 30, 2012 | Teledyne Laars Laars Lite 2 Pool Heater...
Washing machine making loud banging cracking noise.
Sounds like something's got between the drum and tub and is resting on the heater element. Remove the heater and check in the gap
May 09, 2012 | Washing Machines
When the burners ignite, within one minute it starts making a loud banging noise and then the HS code comes on and it shuts down. the noise continues for about 15 to 30 seconds after the burners shut...
This sounds like a low water flow situation. The heater is telling you that the high limit sensor is curring heater operation. The noises are the heat exchangers boiling the water either due to a blockage in the exchanger , a bad mixing vlve, or most likely poor water flow. This is tough to troubleshoot through a posting like this, but 1st thing is 1st. Check your water flow and make sure it is minimum 50 Gallons per minute.
Jul 18, 2011 | Hayward H-series Electronic Gas Pool...
I just got a new Rancilio Silvia, it's making a loud knocking noise. Is this common if not what should I do?
The pump is a vibratory pump on rubber mounts. It makes a loud buzz when running.
The pump makes a knocking sound when it is out of place on the mounts and banging into something and when the pressure is high (water flow is blocked)
Open the wand all the way (no back pressure) and make some hot water. If the noise changes to a quiet hum, get a warranty repair. If the noise changes some but is still a knock, take out the water reservoir and the pump shield.
You can see the shield by looking down into the cavity left by the reservoir. One screw hold the shield in place. Remove the screw and the shield, and wiggle the pump around in its mounts until it does not bump into anything when running. Then replace the shield, screw and reservoir.
Oct 09, 2010 | Rancilio Silvia Espresso Machine
I have a PacFab MiniMax 100 pool heater. The pilot remains on... but the burner will not ignite unless I hit/jar the heater. Any suggestions on what may need replacement or repair?
First thing to check is the flow switch. You can bypass it temporarily, and see if it lights. DO NOT OPERATE IT WITHOUTH FLOW SWITCH. If it isn't the flow switch, then it could be the thermostat or a bad connection on this low voltage millivolt circuit.
Jul 04, 2010 | Pentair Minimax 100 Pool Heater
My gas pool heater is banging
Hayward, gas heater... a metal clinking noise and the hoses doing a twitch every 5 to 20 seconds. my experience says it is that diverter shield has come loose...disconnect everything. unscrew the in and outlet connections.look into the hole, you will likely see a metal, plate with two half circles, one facing the inlet hole, and if you go around to the other side you will see the other end of the plate, with a half circle. this plate comes loose, whatever they use doesn't last.
one guy used a small hose clamp to keep it from sliding up and down the post, I used that two part plumbers putty, to "weld" it in place....homedepot, comes in a small cylinder, it's two part, you cut off a piece and mold it in your hands, worktime is only 3 min. cures in an hour.... no more clinking metal or twitching hoses.
Apr 27, 2010 | Hayward H Series Induced Draft Abg 100,000...
Whirlpool top freezer refrigerator- compressor makes a loud noise
The compressor is that black casing you see at the bottom of your refrigerator - inside this sealed case is the motor assembly which stits on 3 or 4 springs that act like a cushion - you have a little gap at the bottom where the lubricating oil is present. Your springs have likely worn out and when the compressor shuts off the assembly is banging against the rigid casing make that loud "klonk" or bang noise. It IS normal for compressor to make some faint "tick-tick-tick...tick.....tick" when shutting off, but loud banging, bell sounds, etc, means the assembly is banging on the case from the inside - you can indeed live with the noise, your compressor will function normally, probably for months, or even years - it can also keep wearing out and one day the noise might get very loud (like a very high humming noise) - There is NOTHING that can be fixed, you either pay $400+ to change the compressor or buy a new refrigerator - If you DO replace a compressor usually the replacement will be noisier - Keep a thermostat inside your refrigerator at all time to make sure your compressor is still keeping your refrigerator and freezer cool.
Mar 20, 2009 | Refrigerators
Pentair MiniMax 100 Aboveground 100,000 BTU Propane Gas Electronic Heater Logo
726 people viewed this question
Top Pentair Pool & Spa Experts
Jay Finke
Jay Finke
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Pentair Pool and Spa Expert? Answer questions, earn points and help others
