Question about Kenmore Oasis HE 27082 Top Load Washer
Lid locked no power
Mid cycle my machine stopped. the lid is locked so i can not get my laundery out of the water. there seems to be no power, there are no lights or anything. I have unpluged the machine and plugged it back in, sometimes a few lights will blink but that is it.
  • 1 more comment
  • tubatuba Nov 07, 2007
    This is eerie, we are haing exactly the same problem, happening on exactly the same day. I called for repair but they can't come for a week. I need to get the wet clothes out or they will rot before then.
    Currently we are trying to push in the brackets so we can pull up the entire top of the washer to get the clothes out.
    I have already scratched off paint on my dryer using the recommended putty knife and we also resorted “assisting” the putty knife with a pie knife.
    This is a stupid design flaw. I would have thought the engineers would have designed a quick release feature for the lid in case of power OR washer failure.
    posted by lovex4 on Nov 06, 2007
    Report abuse
    mid cycle my machine stopped. the lid is locked so i can not get my laundery out of the water. there seems to be no power, there are no lights or anything. I have unpluged the machine and plugged it back in, sometimes a few lights will blink but that is it.
    "I have already scratched off paint on my dryer using the recommended putty knife and we also resorted “assisting” the putty knife with a pie knife."
    I meant washer ... I'm just so liviid and tried of trying to use brute force to open this washer
  • lovex4 Nov 14, 2007
    we had a repair person come on 11-9 there was a 75$ diagnostic fee which i was aware of however there was also a labor fee that was never mentioned. the man was here about an hour and labor was $69. the part was ordered and supposed to show on tues. i called sears tues night because the part didnt show. sears then informed me the part was backordered until 12-14. they are saying the problem is the main controll THE part is $143 with a grand total of $335 and 1 month with no washer i hope you have better luck with sears than we are we will never ever buy from sears again
I have the exact same problem. I have taken off the top area and am afraid the board is fried. Can you tell me what caused your problem and what the solution was?
Posted on Dec 25, 2007
  • 3 Answers
Use a screwdriver in the crevice beneath the lid. Approx 4 inches from each side you will see a 1" silver piece of metal, push the tab towards the back of the machine. Once you get one side loose place something such as a screwdriver to keep it unlatched until you get the other side loose. The top should come open. And there is also a service book inside your washing machine, I fixed mine myself. Look at my other postings. Good luck!!
Posted on Nov 22, 2007
W6444
make this steps and fix it. God bless you
Lid Switch Assembly
If the washer stops mid cycle the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Enter your model number to see parts for your washing machine.
Help me find my model number
Door Lock Motor and Switch Assembly
If the washer stops mid cycle the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Water Inlet Valve
If the washer stops mid cycle the water inlet valve cold water side may have failed. Most washers have a cold water rinse and so if they can't fill with cold water they just sit indefinitely waiting for the cold water to enter. If there is cold water to the water inlet valve and the cold water works in other parts of the cycle - or to make warm water - the valve is not the problem.
Main Control Board
If the washer stops mid-cycle the main control board might be defective. This is not common. Check other causes first such as the lid or door switch and other components.
Timer
If the washer stops mid cycle the timer might be defective. This part is often misdiagnosed, check other components before replacing this timer.
Jul 25, 2013 | Washing Machines
The washer work but stop along the way,ie unable to complete the circle
see this steps and fix it. God bless you
Lid Switch Assembly
Water Inlet Valve
Main Control Board
Timer
Jul 13, 2013 | Washing Machines
Skipping wash cycle
follow this steps and fix it. God bless you
Lid Switch Assembly
Water Inlet Valve
Main Control Board
Timer
Jul 13, 2013 | Admiral 3.4 cu. ft. Top Load Washer in...
Affinity stops in the middle of a cycle a just shuts off no signal or anything?
use the following steps. God bless you
Lid Switch Assembly
Water Inlet Valve
Main Control Board
Timer
May 23, 2013 | Frigidaire ATF6000ES Front Load Washer
Washer heavy duty cycle issue
Lid Switch Assembly
Water Inlet Valve
Main Control Board
Timer
God bless youcb4af627-0171-42f5-ad0a-5f8e85e72ae0.gif6634bf88-8eca-4d0f-b59c-0e8829e5d59d.gif419f93c3-fea0-4d93-af85-2e59d98d88e0.gif
May 23, 2013 | Whirlpool AWG320 Front Load Washer / Dryer
Water starts to pass through but then stops and error alarms start
see this causes and fix it. God bless you
Lid Switch Assembly If the washer stops mid cycle the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly If the washer stops mid cycle the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Water Inlet Valve If the washer stops mid cycle the water inlet valve cold water side may have failed. Most washers have a cold water rinse and so if they can't fill with cold water they just sit indefinitely waiting for the cold water to enter. If there is cold water to the water inlet valve and the cold water works in other parts of the cycle - or to make warm water - the valve is not the problem.
Main Control Board If the washer stops mid-cycle the main control board might be defective. This is not common. Check other causes first such as the lid or door switch and other components.
Timer If the washer stops mid cycle the timer might be defective. This part is often misdiagnosed, check other components before replacing this timer.
Oct 05, 2012 | LG Washing Machines
My maytag epicz will run water and then just stop it lock and later get code f33
Oct 05, 2012 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool 1000 w100 stops after filling with water
Sep 30, 2012 | Creda W100FW Front Load Washer
Washer stops at rinse cycle and give the ul code F1
Sep 28, 2012 | Whirlpool Cabrio WTW6600SBT Top Load...
H6 error code on a NEC NFL-1065 washing machine
see this causes, and fix it. God bless you
Sep 26, 2012 | Washing Machines
Kenmore Oasis HE 27082 Top Load Washer Logo
108 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
