Question about SIM2 Seleco Grand Cinema HT300 Plus Multimedia Projector
I have a Seleco SIM2 HT300HD. When I play a dvd, I get horizontal lines on the screen. That does not happen when I play vcrs or the TV. Can you help?
  • 6 more comments
  • d3van3y14 Jun 27, 2009
    That did not work. The dvd is set up as 1024 X 728. And the problem just occured in the past few weeks. The system has been installed for a while.
    I have a Seleco SIM2 HT300HD. When I play a dvd, I get horizontal lines on the screen. That does not happen when I play vcrs or the TV. Can you help? The system has been insatlled for a while and the problem just recently occured
    tried that already.
    I have a Seleco SIM2 HT300HD. When I play a dvd, I get horizontal lines on the screen. That does not happen when I play vcrs or the TV. Can you help? The system has been insatlled for a while and the problem just recently occured. I tried cleaning the DVD player - no luck; I replaced the DVD player - no luck.
    I used new RCA cables when I put in the new DVD player
    I will try your suggestion of plugging into a TV. But the Seleco is a projector, not a standard TV. If I isolated the problem to the projector, what can I do to resolve the problem? I can always send it back to the factory for repair, but that costs a ton. I would like to avoid that solution, if it is a simple problem to fix. hence i need someone whoi is an expert in high end projectors. Thanks.
  • d3van3y14 Jun 28, 2009
    I think that the problem is inside the projector.
    I think that thye problem is inside the projector. I sent an e-mail to the service dept of the mfg. Let's see what they say.
    President:
  • 632 Answers
Check the video system of the projector and the dvd player..they must have the same video system..say NTSC-NTSC,PAL-PAL and etc..or you can set the projector's video system to AUTO...
Posted on Jun 28, 2009
    President:
  • 2,777 Answers
Hello there, sorry to hear about your troubles.
Let'e examine your situation, according to the notes you have already cleaned the laser on the dvd drive, tried new cables, tried another dvd disc to verify it's not restricted to just that one movie, and replaced the dvd player itself?
If all four of these points are true then it is something on the input side of the TV not the actual DVD player. To confirm this you would want to take your existing dvd player (whichever one you have right now) and, using the same cables, attach it to another TV (a friends / family members maybe?) to see if the horizontal lines re-appear on that TV. If the lines do not re-appear then you know for certain that it is your TV that is the culprit and not the dvd player. It is possible that only one set of inputs on your TV has gone bad which would explain why the VCR works fine but not the dvd player.
If you hook your dvd player to another TV and the lines DO re-appear then you know it is something on the DVD side. It is possible that the outputs on the player have gone bad or the cable is bad but it sounds like you have already addressed those possiblities. To make absolutely certain you could try another DVD disc in the player (which I'm sure you've probably already done). If you have replaced the DVD player itself and it still has the lines and you've determined that your TV's inputs are fine then I would avoid that DVD player brand / model alltogether. If this were true it would mean that somehow you have received defective dvd players back to back which is virtually impossible.
I hope this answers your question, between all these trouble shooting techniques you should definitely be able to identify the culprit.
Posted on Jun 27, 2009
  • Tim Grayson
    Tim Grayson Jun 27, 2009
    I am sorry about that, I am definitely an expert with projects as well, I just focused on the part where you said it puts horizontal lines on your TV... I take it you meant across your screen =). Technically there is a huge difference.
    Anyway, once you have determined that it is the input on the projector you can "solve" the problem by avoiding that input. You can get an RCA switchbox that will allow you to plug multiple things into it (such as your VCR and DVD) and then from that into one of the inputs that is working fine on the projector (I would bet that your VCR is coming in through RCA as well?, if so you can use that input for both with a switchbox. Also, you can temporarily disconnect the VCR from there and connec the DVD player in it's place. If there are now no more horizontal lines then you should be ok using that input for both). If you want to avoid using the switchbox (or want to save money) you can just manually switch the cables whenever you want to watch a TAPE or DVD...
    Again I apologize for referencing "TV" so many times in my previous answer.
    Also, this would be considered a warranty repair item if the projector is still under warranty. Have you confirmed with the manufacturer one way or the other in that regard? They will also probably be able to give you a repair estimate although I know you mentioned it will probably be a lot, you may be surprised.
    Thanks for your patience and understanding, hope this helps!
    Tim
  • Tim Grayson
    Tim Grayson Jun 28, 2009
    Fantastic, let me know if you find anything more through troubleshooting or if you can think of any other questions please let me know. I hope I was of some help! =)
    Thanks sir,
    Tim
    Sniper:
  • 127 Answers
Try changing the RCA cable or try changing the AV RCA input cable in your TV.it is creating a problem or could be a possibility that it is loose.
  • 508 Answers
Try using proper dvd cleaner
    President:
  • 1,383 Answers
Set screen resolution to 1024*768
Horizontal lines appear on 32" in some hd format movies.
The technician is right, the TV will not show such lines selectively. Try changing the input device to some other. Play some sure shot, genuine DVD.
Jul 19, 2012 | Televison & Video
Looking for manuals
Hi molyneaux,
You can download the manual for free here - http://office.manualsonline.com/np/usermanuals/mfg/sim_2_usa_inc/ht300_plus__data_projector
Jul 21, 2010 | SIM2 Seleco Grand Cinema HT300 Plus...
We record a tv program. When we play it back it
Ur video head is dirty.Must have a head cleannig video tape run it the tape will tell u the head is clean.U can buy it in amazon.com or ebay.com the best brand it Scoth VCR cleanning head video tape.Must buy from the web.Video head cleannig tape don't sell any more in retails stores.
Aug 26, 2009 | Televison & Video
Horizontal line of white static
Will it happen in all chanels and all sources? Do you see this line when you are playing a DVD player.
If yes, you have to check the power supply and the main board as well.
May 05, 2009 | Samsung LN-S3241D 32 in.LCD HDTV
Sim2 Seleco DLP SDV 100 Projector only giving white screen dimly.
it's a resolution issue. make sure the projector matches the laptop's resolution. the projector has a 800x600 native and a 1024x768 max. and it's not digital.
Mar 02, 2009 | SIM2 SDV100 projector lamp Projector Lamp
Black Horizontal Lines on Philips Cineos 50" Plasma
First you want to determine if the issue affects the tv's menu if it does you are looking at a Light Engine issue which is expensive if it does not interfere with the On Screen Display the issue is with your signal board, also check to see if this happens on multiple inputs with multiple signal sources if it doesn't you just might want to use a different input which is a way cheaper solution
Aug 06, 2008 | Philips 42FD9932 42 in. Plasma Television
Horizontal Blue Line
WHEN YOU HAVE A SOLID BLUE LINE THAT DOES NOT MOVE...YOU HAVE A DEFECTIVE PANEL...LIVE WITH IT OR REPLACE PANEL..NOT COST EFFECTIVE TO REPLACE PANE....JOE ACE
Jun 13, 2008 | Westinghouse TX-42F430S Television
Playback problem on SP Tapes - Top 1/3 of screen wavy lines
there are guide posts that the tape goes around, they need to be adjusted if your good at that stuff take off cover and while playing tape be careful you could damage video head.with flat srew drive . adjust right post buy turning clockwise or counter clockwise. this could be hard i hope i helped , When i first started ny video shop 1987 we started doing only vcrs.
The video head also could be bad. thanks doctor video
May 04, 2008 | Sony SLV-D350P DVD Player/VCR
White horizontal, zig-zagging lines
Sounds like the flyback transformer is bad. couple of 100 dollars if it is that
Dec 03, 2007 | Televison & Video
It sounds to me like you're describing the re-trace of the unit. It is repairable, and more so the sooner you get it to the repair facility.
Nov 21, 2007 | Sony FD Trinitron WEGA KV-27FS120 27" TV
SIM2 Seleco Grand Cinema HT300 Plus Multimedia Projector Logo
126 people viewed this question
Top SIM2 Office Equipment & Supplies Experts
k24674
jasbo
jasbo
Are you a SIM2 Office Equipment and Supply Expert? Answer questions, earn points and help others
