N256 40 gig hdd jumper settings - Model 5T040H4
    President:
  • 623 Answers
It often depends what OS you are using. Linux i.e doesn't go well with cable select and I had to just play around with the jumpoer settings t get this drive to work. It is an old drive (~2000/2001), so it's slow and loud. I could not find any information on the Seagate nor Maxtor web sites. So try this;
The jumpers look like this:
If you bridge the most left pair, it is set to master.
If you bridge the second left pair, it is set to cable select.
No jumpers: set to slave.
"Cable select" only works if the IDE cable supports this setting. If you want to play around with it, look here.
If you have any more questions, just come back here and leave a comment - I'm happy to help.
Posted on Jun 27, 2009
  • 29 Answers
This drive comes with the jumper already installed in the master setting. The jumper is in the leftmost position, when removed the disk is set for a slave. The next position is for cable select, closed on, open off. The other positions are for factory use.
Can I use a Maxtor DiamondMax Plus 60 (5T040H4) 40.9 GB like Slave?? Thank you
Of course you can use it. Put the jumper to set the configuration as "slave" and insert the a plug from the ide cable. If you put the put the jumper to "cable select", put the slave plug and it should work great.
Mar 15, 2010 | Maxtor DiamondMax Plus 60 (5T040H4) 40.9...
The jumpers are not labeled on hard drive
If the sticker is not on the top showing where the jumper pin goes, you can do an online search for the make and model of the hard drive. A "new" hard drive usually comes with a booklet giving you specs on it. Otherwise, it will be a process of elimination of moving the jumper from one set of pins to next until your computer recognizes it as a slave. This will require shutting down and unplugging your computer, moving the pin, and restarting. Hope this helps you.
Oct 24, 2009 | HP Vectra VL420 Intel Desktop PC - Intel...
5T020h2 jumper setup
No jumper is used on the J50 pins, when using the Maxtor 5T020H2 IDE harddrive, as a Slave harddrive.
In otherwords do not use a jumper on any of the jumper pins.
This is a PDF file of the Harddrive Specifications of the 5T020H2, 5T010H1, 5T030H3, 5T040H4, and 5T060H6 Maxtor IDE harddrives,
from Seagate. (Seagate bought out Maxtor)
http://www.seagate.com/staticfiles/maxtor/en_us/documentation/manuals/dm_plus_60_ultra_ata_manual.pdf
The Jumper Settings are in Chapter 2, Page 5 (2-5)
Looking at the page number for the PDF file it's on Page 15.
Oct 07, 2009 | Maxtor Hard Drive
Setint the jamper as a 2nd drive and Do i need to farmat it frist
If I recall right this HDD is a PATA (IDE) type. As for the Jumpers please check the following link. The jumper should be as Slave drive.
http://www.helpwithpcs.com/upgrading/install-hard-drive.htm
May 15, 2009 | Quantum Fireball Lct20 (QML20000LD-A) 20...
Additional Hard Drive
The Motherboard will be able to handle it and XP will read the hardrive i have used a 500 gig hard drive in my old computer before it should work just fine
Apr 08, 2009 | Dell Dimension 2400 PC Desktop
Problem putting a 30 gig quantum lct 15 3.5"series as a slave
Did you switch the jumper config back to Master or CableSelect before trying to install them as a single drive? Also check the Maxtor website, (they owned Quantum too), for the correct jumper settings. Some of these drives (like the Quantum Fireball lct series) need TWO jumpers not just one.That was the trick that fixed mine from not being recognized by the Bios or the Windows setup disk....I got it used with only a single jumper, but it needed two to put it Cable Select mode.
Apr 07, 2009 | Quantum Fireball Lct20 (QML30000LD-A) 30...
Jumper setting
Put the jumper on J50(the closest set of pins to the IDE connector)
This will set the drive to master, with no pins on it's currently set to slave.
Chris
Oct 21, 2008 | Maxtor DiamondMax Plus 60 (5T040H4) 40.9...
2nd hdd
both hard drives will need to be jumpered to a master and a slave or both have to be jumpered to cable select. normally the jumper setting are either on the label of the drives or are marked on the bottom of the drives near the jumper drives. if the setting are not shown find the drive type, model and capacity then do a google search for the drive "select the factory manufacture link" and search their site for the jumper setting of the type drive you have.
BPCS
Dec 05, 2007 | IBM ThinkPad T21 Notebook
Computers & Internet Logo
1,688 people viewed this question
David Payne
David Payne
