Question about Refrigerators
Dirty ice my ice maker in my side by side refrigerator model no. SXD25MB2W is makeing ice with little pieces of black stuff in some of the cubes. Is there a filter?
    President:
  • 1,136 Answers
Hi, Remove the ice maker and look at the tray the cubes are made in. You will probably find the casing is flaking off. All you can do is replace the icemaker.
I hope this helps you.
Please let me know if I can assist you further.
Vic
Posted on Jun 27, 2009
My whirlpool GS6NBEXR refrigerator ice cube maker leaves slimey, flaky residue at the bottom of my glass. What can I do?
Diana, if I understand you ok, the ice you put in the glass leaves slimy residue. So that slimy stuff has to be in the ice cube. Well remove the the ice maker unit and thoroughly clean this ice holder and throw away the ice cubes in the kitchen sink and see if leaves slimy stuff. As for slimy stuff, while the unit is out, check any leaks etc. BTW any smell?
Jan 06, 2014 | Whirlpool GS6NBEXR Side by Side...
Not making ice cubes
Here are some basic tips for ice maker troubleshooting2_bing.gif...
Ice Maker Problems and Ice Maker Troubleshooting
http://www.fixya.com/support/r3876071-ice_maker_problems_ice_maker
heatman101
Jun 08, 2010 | GE 25.0 Cu. Ft. Side-by-Side Refrigerator...
My GE side by side ice maker quit making ice, no water sees to be entering the unit.what do i check for?
Pour 2 / 3 cup of water into the ice maker .
If it dumps the cubes , but does not refill with water , replace the dual water valve behind the refrig . This is the piece , the wall water line connects to , on the refrig .
If it does not dump the cubes , replace the ice maker .
Oct 12, 2009 | GE Profile PSW26P Stainless Steel Side by...
RF266ABPN French Door Firdge/freezer Ice maker sensor
I found David's solution very helpful and I'll just add to it. Take out the top freezer door-- it just slides out and up. I had a bunch of stuff on the little shelf on the actual door and I had to take some of it off first. The big bottom drawer stays on. The little foam piece was on the floor of the freezer so I picked that up and can see how the little sensor part fits into it. Next, I put a chair next to the open bottom drawer, sat on it and leaned back onto and into the big drawer. I had to torque my head to actually get right under the ice maker. I am 5'5" so I don't know the heck David did it! Anyway, there is a little "slot" next to the last ice cube mold closest to the door. This is where the foam piece goes in. The slot where this piece goes has some raised lines sticking out on each side-- I wouldn't call them brackets and the foam thing doesn't stay in well by itself. However, on the right side of the ice maker, near that last cube, is a little hook. So I slid foam piece up with the sensor tucked in, facing the ice cube mold. I wrapped the tail/wire around the bottom of the foam piece and also the hook, so that it kind of holds the foam piece up in there, kind of cradling it. That was my solution, we'll see if it works!
Sep 29, 2009 | Samsung RS2534 Side by Side Refrigerator
Ice maker is making ice too slowly
Dirty condenser. Clean under the ice box.
IM manual and other stuff
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Aug 30, 2009 | Refrigerators
Ice maker works but will only give crushed ice on the cube settin
little arm on side of ice bucket controls that..check it and the solenoid at back for freezer that trips it.
Jun 08, 2009 | Whirlpool ED2FHEXN Side by Side...
GE Side by Side Model #TFH24PRSMWW Ice maker
The on and off switch of the ice maker on the ge side by side model has fell off and appears broken. please instruct with a diagram how to reattach.
Oct 20, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
KITCHENAID MODEL KSRJ25CNST-00 FRIDGE QUIT MAKING ICE WITH OUT ANY WARNING. WTER IS WORKING.
I have this model and it has stopped making ice for two different reasons. These solutions may not fix your particular problem, but they worked for me.
Problem #1: the water inlet to the ice tray is frozen shut.
Solution #1: Raise the door that hides the ice tray. The water inlet is the black rubber nozzle on the right-hand side that points down into the ice maker. Squeeze the rubber nozzle between your fingers to break up any ice that may have formed inside the nozzle. This will clear the water path into the ice maker. Lower the ice tray door.
Problem #2: an ice cube is stuck in the ice tray.
Solution #2: Raise the door that hides the ice tray. Look for any pieces of ice that were not completely ejected from the ice tray - they are usually partially ejected and are very easy to see. Carefully (but it may require a good deal of force) remove ice cube from tray. Lower the ice tray door.
I hope this helps.
Aug 05, 2008 | KitchenAid Superba Architect KSCS25INSS...
ICE MAKER
test the solenoid voltage in auger assy. its a little tricky.
Jul 30, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
307 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
