Question about Heavy Machinery
The impeller does not rotate.
I used mi chipper three times yesterday, and after that it did quit working. Ican not pull hte rope. I took off the piece where the rope is, and it moves fine, I tried to rotate hte impeller by hand and it does not move at all
  • 389 Answers
Sounds like you probably have a large piece jamming the impeller. Look for an inspection cover somewhere on the outside of it. remove the cover and try to turn the impeller backward with a pry bar of some sort to free it up. DISCONNECT THE SPARK PLUG BEFORE BEGINNING!!
Posted on Sep 16, 2009
Hard pulling starter rope
You say Pull rope mechanism is ok, How do you know that? Ive's seen them get the rope a little off and gets caught being wedged into a small clearance. Is the rope wearing? I bet if you take it apart put a new nylon rope and some wd-40 in rubbing surfaces including the ratchet area it will be good as new. Crank bearing has to get really bad to effect pull. How is the spark?
Mar 13, 2015 | Troy-Bilt Troy Bilt Chipper Vac Plus Parts...
How do I put a new pull rope on my 5hp MTD Chipper?
pull the starter cover pull rope out to length lock the housing the rope is in, in place with a tool pull out rope. reinsert new rope into retaining hoe tie a not and cut off excess rope. put ropr through handle hole reattach handle and remove tool you used to hold the rope housing. This is if your spring and starter assembly are ok. Or you could stop being a cheap and let a shop do it for 5 minutes labor.
Jun 29, 2014 | Husqvarna Chain Saw 20" Bar
Pull rope will not pull
Remove recoil rope assembly. Ensure rope is properly wrapped around. While recoil assembly is removed use ratchet and socket to rotate fly wheel, remove spark plug first, observe compression and exhaust at spark plug whole during rotation of fly wheel. Clean or replace spark plug. Ensure oil is full. 30w. Set spark plug gap. Always use Stabile in gas. Replace coil rope is required. Purchased by the foot at any mower repair store.
May 12, 2013 | Toro Super Recycler Super Bagger Lawn...
Pull starting rope Broke
Most recoil assemblies are easy to fix...but not in an obvious way. Remove the recoil asembly from the small engine housing/flywheel cover. Usually three bolts hold it on. 10mm on Honda's. Pull the remaining rope thru the exit hole if possible. Otherwise, fish remaining rope thru the hole by turning rope winding pulley as if pulling handle was still attached, lining up any remaining rope end and pushing thru the exit hole in outer recoil housing or backing it out the inside pulley. Continue to wind rope winding pulley in a counterclockwise ( facing pulley...not outer metal) untill it will not tighten any further. Remove any more old rope. Line up pulley hole and exit hole. Melt end of new rope into a tapered shape..if not supplied that way. the pulley can be held in place by inserting a screwdriver thru the both the pulley and the metal housing spokes. Thread the new rope thru the exit and pulley hole. Tie the rope end sticking thru and draw tight. Cut 6 feet of rope...if not using a presized pull. Release screwdriver from spokes and rope should draw up onto the pulley. Tie off opposite end of the rope to keep from losing that end into the exit hole. put the handle on the rope and tie a knot in the end to retain the handle. Untie the tie-off and allow the handle to fully retract. If handle does not fully retract you may shorten the rope so that it does...as long as you have plenty of pull lenght
Oct 21, 2012 | Mi T M Mi-T-M WP-2403-3MHB NA 2400 PSI 5.5...
I have a 2500 craftsman power washer with a Briggs and Stratton engine. I used it about a month ago and it worked fine. Took it out yesterday and I could not pull the rope to get it started. I took out the...
It sounds like the pump is seized. Make sure any pressure has been released by pulling the trigger on the gun. Sometimes this will allow you pull the cord. If the pump is seized, a new pump would be in order.
Jun 15, 2010 | Briggs & Stratton Garden
How do you rotate shredder blades on duerr m/n 678?
Interesting question --
I just picked up one of these over the weekend, and was able to get the flywheel off with minimal excitement. After removing the center bolt from the flywheel, I used a hammer to "encourage" the flywheel off the keyed shaft from the back-- through branch feed hole in the housing. It took quite some time, and I rotated the flywheel as I did it to keep it from binding up, but it eventually came off.
As an aside, would you let me know if you've found any source for parts or documentation? I'm going to attempt some repairs on the flywheel and chipper blades, but may end up wanting to replace them.
Apr 07, 2010 | Heavy Machinery
Need to replace the recoil rope and handle on a tecumseh hm80 155481 p 8hp horazontal shaft motor. never done one before so any suggestions would be great
take the 4 bolt out of the starter housing, lay on table take the old rope out. turn the center rope pulley counter clock 6 to 7 full rotation's so the center pulley hole lines up with out housing hole(steck a screw drive throw to hold pulley in places). feed the rope from outer throw the center tie off. let the pulley dr ow the rope in. pull the rope out a Little tie off to handle
Oct 08, 2009 | Yard Machines Heavy Machinery
I have a 10 hp MTD chipper-shredder. Yesterday it worked fine 3 times and then it quit. The impeller does not rotate, I took off the part where the rope is and it moves fine. Could I take it apart to see...
Jun 27, 2009 | Heavy Machinery
Pull-start rope won't pull
This has happened several times for me and is usually caused by a peice of word jamed in the input hopper and half cut by the blades. Always make sure there is no wood in the input chute before stopping motor. remove the collector bag and use a long pry bar to reverse the flywheel. if this moves backwards you may then be able to remove the peice of wood jammed in the blades thru the input chute. Long Skinny arms is required to reach down the chute. Use a Flashlight to see if this is your problem.
Jun 26, 2009 | Troy-Bilt Chipper Shredder
Need set of 4 impeller vanes for Troybilt chipper model 47261
You can get the impeller parts at:
http://www.thefind.com/garden/browse-troy-bilt-chipper-vac-parts
Good luck,.,
I just purchased a used 47261 yesterday for $200 .. It is like new, but I may need a new bag from this site and I will need to find a manual somewhere.
MrBill
May 28, 2009 | Troy-Bilt Chipper Shredder
Heavy Machinery Logo
173 people viewed this question
Top Heavy Machinery Experts
Bill Boyd
Daryl Gleaton
Tom Chichester
Are you a Heavy Machinery Expert? Answer questions, earn points and help others
