Question about Toshiba Satellite Pro A200-EZ2204X Notebook
The sides of the screen on my laptop are blacked out so the screen appears smaller. The mouse doesn go into the black bits either. i havent changed any settings i just switched it on and have this problem! can you help?
  • Toshiba Master
  • 4,806 Answers
Go to the control panel and select "display" when the window pops up select the "settings" tab and set the display to 1024 x 768, select apply and then OK.
Your problem should now be solved :)
Regards
Posted on Jun 27, 2009
How do I change the desktop text, icons and bars back to 100% from 500% in Windows 8.1?
Hi Cindy
You have set a customer DPI scale for your display.
Right Click on desktop
Choose "Screen Resolution"
Click on link that says "Make Text and other items larger or smaller"
Click on link that says "Set custom text size (DPI)"
Adjust the scale back to 100%
Apply the changes and all should be well.
Regards
Andrew
Make the text on your screen larger or smaller Microsoft Windows Help
May 18, 2014 | Acer Aspire Computers & Internet
Model: Packard Bell Easynote GN45 - Display has "shifted" to the left; thick black chunk down the right hand side of the screen. Display at top of screen also appears at the bottom of the...
Test the laptop using an external monitor
If this works fine, then the issue is with the screen, or possibly the vga cable. I notice this is referred to as a compatible screen, was this obtained new, or is it 2nd hand. Although most 15.4 screens fit most 15.4 laptops, some do not display correctly, this might be your problem. If you know the screen to be good I would suspect the connection at the back of the screen
If this still shows issues with an external monitor, you have a problem with your graphics chip on the motherboard
Jan 22, 2011 | Packard Bell EASYNOTE GN45 COMPATIBLE...
Aftr i start n log onto my pc... I can see d mouse but d entire screen is blank!!! Pls say what to do
We wish you a merry Christmas and a Happy New Year.
Which is the operating system?
What exactly happens when you start the PC?
Is it Blinking cursor with a black screen?
Then its black screen error.
Firstly, there appears to be many causes of the black screen issue. The symptoms are very distinctive and troublesome. After starting your Windows 7, Vista, XP, NT, W2K, W2K3 or W2K8 PC or server the system appears normal. However, after logging on there is no desktop, task bar, system tray or side bar. Instead you are left with a totally black screen and a single My Computer Explorer window. Even this window might be minimized making it hard to see.
If you have these symptoms you can safely try this for free Black Screen Fix. It will fix the most common cause we have seen of this issue. Running the fix program is easy under normal circumstances, simply download with your browser using the link above and run the program. However, if you are trying to do this from the PC which has the black screen it is a bit more tricky. In these circumstances follow the procedure below:
1) Restart your PC
2) Logon and wait for the black screen to appear
3) Make sure your PC should be able to connect to the internet (black screen does not appear to affect this)
4) Press the CTRL, ALT and DEL keys simultaneously
5) When prompted, Click Start Task Manager
6) In Task Manager Click on the Application Tab
7) Next Click New Task
8) Now enter the command:
"C:\Program Files\Internet Explorer\iexplore.exe" "http://info.prevx.com
/download.asp?GRAB=BLACKSCREENFIX"
Note this command assumes that you are using internet explorer as your browser, if not substitute your browser path and file details for those of iexplore.exe or use the Browser option of Task manager to locate it.
9) Click OK and your browser should start up and begin the download process
10) When prompted for the download Click run, the black screen fix program will download and run to automatically fix the issue.
11) Now restart your PC and the black screen problem will hopefully be gone.
Hope this helps.
Cheers!!
Dec 31, 2010 | HP Pavilion dv6000z Notebook
After turnoing on my sl500 the screen flickers and turns black
Check your video adapter settings. try to set it on clone and see if the picture would appear the same on your LCD. From there you select it back to your LCD. Just make sure the primary display is set to your LCD and apply the changes.
Hope this helps.
Dec 20, 2009 | Lenovo ThinkPad SL500 - Intel Core 2 Duo...
ASUS eee pc 1ooo H doesnt start from time to time !
the blue light is your Wi-Fi
make sure you havent put the machine into "suspend" mode by accidently pressing Fn-F1 or Fn-F5 which toggles between screen and external monitor
Nov 19, 2009 | ASUS Eee PC 1000H Laptop
Laptop cursor jumps around, turns crosshair, screeturns black
windows vista is probably the problem...have you tried running a virus scan? McCaffe...could actually have one from the factory
Oct 05, 2009 | Acer NSK8458AN Keyboard
My hp compaq nx9010 notebook is no longer displaying the color black on the Windows xp start up page or on some of my powerpoints and videos. The color black is replaced by a redish color.
It seems that someone changed the desktop background color. point the mouse somewhere in the middle of the desktop, (away from any icons) and right click the mouse, a menu will appear with several options. The bottom one says properties. Click that. Once done another (more advanced) menu will appear with several tabs at the top. Click on the second to last tab, labled, "Appearance". Once in this tab. Toward the bottom right side of this screen you will see 2 buttons one atop another labled, "Effects", (on top), and, "Advanced", (below). Click the advanced button. A new window will pop up with the first option being desktop in a drop-down menu. To it's immediate right you will see "color 1" with a drop-down menu directly below it. That is where you will select the new background, (desktop) color. Once you have selected the new color, click OK, then apply on the remaining screen, then OK once the color is set.
Apr 16, 2009 | HP Compaq nx9010
Change batteries
This is a deceptive little beastie. As you look at the mouse, you will see that the front approximately 1/3 consists of the left and right mouse buttons and the scroll wheel. The rest appears to be a one piece cover with the black area with the GE logo in the middle. There's the tricky part. The black part with the Logo is the housing for the USB plug in part (so you can keep it with the mouse when transporting it). The rest of that (silver on my mouse) is the battery cover. You open it up by gripping the little raised line on each side of the cover and pull backwards while holding the front by the black area under the mouse buttons. The cover (only the silver part, the black is attached to the rest of the mouse) will slide backwards and Voila! There are your batteries.
Jan 12, 2009 | GE Optical Mini Mouse ho98094
Laptop Compaq Evo N620c screen gone tiny!
dear do one thing as you have not mentioned whether you r using a laptop or desktop.........press the ctrl button on your keyboard & use the mouse scroll button up/ down..........hope this will resize the icons..........................Sameeraryan
Jan 02, 2009 | Compaq Evo N620c Notebook
Partial blackout on Screen
I have the same laptop, and though I havent had a black out problem i do have screen burn or a discoloration in the lower corners of my screen. I was told that It was due to this model's overheating issue and that I would have to replace the screen.
Apr 20, 2008 | Toshiba Satellite M45-S331 Notebook
Toshiba Satellite Pro A200-EZ2204X Notebook Logo
69 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
