Question about Garden
The lawnmower starts but doesn't stay on.When I open up to full throttle it shuts off.
Sounds like the engine is not getting enough air. To test this you can pull of the air filter and starting it and see if it helps. If so you need to adjust the air flow or change the air filter.
Posted on Jun 27, 2009
1999 sportster 1200c after good warm up ride, 15 miles or so bike shuts off under full throttle twist
it sounds like your fuel filter is ready fr a change and that your main jet might be blocked or needle and seat might need checking cheers
Mar 12, 2014 | Harley Davidson XL 1200 C Sportster Custom...
Help, need to start a briggs and stratton 158 mower, and can't. not mine, so not sure of its quirks, also not a lawnmower person, use a brushcutter normally. lawnmower in good condition, got oil and...
after trying to start it a bunch of times, take spark plug out and see if it's wet with gas.
All mowers start with throttle High and with the choke on OR if it has a primer bulb, you have to prime it until you see gas in the bulb
Aug 28, 2013 | Briggs & Stratton Garden
Craftsman lawnmower wont stay running
Michael it sounds like there may be a blokage on you air filter. Check it and clean it then make sure there is not too much oil in the mower.
Jul 18, 2013 | Garden
Why does my 1982 25 hp mariner not idle down when it is at full throttle
broken/missing return throttle spring
jammed throttle cable
Nov 02, 2017 | Boating
Ive a honda lawnmower , engine is surging up an down when full throttle , is startin to do same at low throttle also.
Install a new spark plug,clean air filter,
& check for intake vacuum leaks.
If that doesn't work take the carb apart & clean
Nov 18, 2012 | Cars & Trucks
Rancher 455 wont stay running
you need too adjust the high jet ccw (making it richer) do do that takes
a little work cause you need a special tool but I can help you around that if you like. let me know
Jul 09, 2012 | Husqvarna , No.455 Rancher, 20" Gas -...
I have a 1992 GSF250 Bandit. Having trouble starting, battery charged, petrol full- attempts to kick over after a couple of goes put on choke and still wont start. Starts sometimes and not others.
You may have flooded the engine by now, leave the choke off and wind the throttle wide open. Wind the engine over to clear the fuel out. Then turn off, and back on again shut off the throttle. Try to start it without the choke or without opening the throttle. If it doesn't start turn it off and check your air filter make sure it isn't clogged.
Then check your carbs if it has them, slightly tap them on the bowls. Then find the screw on the bottem of the float bowl that lets the fuel out normally an allen head. Unscrew it and allow fuel to run out, then shut it off. Do the same for other carbs. Now try to start it again, if it starts then it was a faulty needle and seat and you might want to look at changing those. If you have a fuel tap make sure it is turned on, make sure you have plenty of fuel in the tank.
Failing that it is a spark issue.
Sep 11, 2011 | 1994 Suzuki GSF 400 Bandit
Engine starts but won't continue to run. Choke doesn't stay closed after starting. will stay running only if I hold choke closed manually.
let it warm up with choke closed manually after it starts to stall with choke closed open it and dont let it stall u can learn to play with the choke a little to get it to run right GOOD LUCK!
Aug 14, 2011 | Toro Lawnmower 20099 Mower Mowers Lawn
Lawnmower starts but shuts off imediately
this can one of two problems,, first if you have a electric fuel pump check it,, if it is ok try cleaning or replacing carb. hope this help you,,, good luck
Aug 12, 2009 | Garden
Garden Logo
73 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
Marvin
Marvin
