We cannot get the Closes Captioning to work on this TV. We have Comcast, bu it seems it has to be set thru the TV. Model #42hds52a
  • ejsoble Jun 27, 2009
    Had tried all that. Right now we have
    Caption display: On
    Analog Mode:Captions Channelc1
    Digital: (The Language cannot be selected)
    Tried on stations I know use CC
  • 13,433 Answers
Closed Captioning settings on your tv:
The picture is probably too small to read. - IF THE PICTURE IS NOT READABLE CLICK HERE TO GET A BIGGER VERSION
And here is the documentation for your Television
http://tv.manualsonline.com/manuals/mfg/hitachi/42hds52a.html
or here:
http://dl.owneriq.net/7/7c18b452-d8da-4487-9b19-36b2db60544f.pdf
be patient as it may take a minute or two for the manual to open.
if you can't open the manual then you are most likely missing a pdf reader, get it from here
http://www.foxitsoftware.com/pdf/reader/ - you can get it from the free download.
let me know if you need anything else.
Thanks,
Ekse
Posted on Jun 27, 2009
  • Ekse Jun 27, 2009
    see if you can change the options on the digital setting.
    Also NOTE:
    1. Some types of digital closed captions will not work with this TV.
    2. Caption Display will not work when viewing a 480p, 720p, or 1080i input via the
    COMPONENT connection
    3. When PIP SURF MODE is on, Closed Caption will not work.
    4. Digital Captions Font Style are sometimes different from the Font Style of Analog Captions.
    5. Closed Caption and Digital Captions availability and content depends on the broadcaster. Closed
    Caption is available when Closed Caption icon is displayed on screen.
    6. Digital Captions will not be available (grayed out) when using analog channels
How do I turn the closed caption off? I have a remote
      Immediately-within one second-push the MENU button on your remote. You should see a User Settings menu screen displayed. Use the arrows keys on the remote to highlight the Closed Caption option and press OK or SELECT on your remote to toggle Enable/Disable. Power on the Set-Top Box to return to watching TV.
      How do I turn Closed Captioning on or off? ' Time Warner ...
      www.timewarnercable.com/.../closedcapt/how-do-i-turn... Time Warner Cable
    Feedback
    How do I turn on/off closed captioning? - Comcast Help and Support ...
    forums.xfinity.com/t5/.../How-do-I-turn...off-closed-captioning/.../1325...
    Jun 25, 2012 - Turn STB off and leave TV on; Press Menu on STB or remote control; Using the ... If this does not activate Closed Captioning, try the following:.
Jan 24, 2016 | Televison & Video
Can i slow down close captioning?
The Comcast set top boxes only allow 1 type of CC. However your TV is programmed to handle 4 or 5 CC features. Go into your TV menu and find your CC options there should be different ones there choice 1 you like.
Nov 22, 2013 | Comcast XFINITY
Turning off close caption on xfinity tv
The Comcast boxes let you enter a special menu only when the box is turned off. Just turn off the Comcast box and press the menu button on the remote you will then see a menu for the box where you can turn on and off close captioning
/uploads/images/turning-off-close-caption-xfinity-tv-35300106-2-1.jpg
/uploads/images/turning-off-close-caption-xfinity-tv-35300106-2-2.jpg
Mar 13, 2013 | Comcast XFINITY
I can't turn on closed captioning on Hitachi with Comcast scientific atlanta explorer 2200 cable box. Any words of wisdom?
Both the set and the box used should have the closed caption feature.
If box is in line to rear audio/video jacks you will have to engage the CC from the box.
I doubt it will work if hooked that way from within the box---go to menu and in CC area in either set or box select CC1 which is the most common one used.
May 25, 2012 | Hitachi P50H401 50 in. Plasma HDTV
How to activate "closed captioning" for a Proscan Full HD 1080P
Comcast's remote has nothing to do with closed captioning. It's on your tv remote. First, the tv has to be capable of handling closed captioning, and your's is- and second, the program must have closed captioning provided- current programs do, some older shows do not support closed captioning. Recheck your remote, and if necessary- look at the setup instructions that came with the TV- they should also be posted online at the Proscan support site.
Mar 26, 2009 | Proscan 26LB30QD 26 in. LCD HDTV
Toshiba 62hx94 cant shut off closed caption have comcast cable How do I turn off closed caption on my TV. It suddenly turned on. can' turn off closed captioning 20" ws
The problem was with the Motorfolla Comcast cable box not my T.V. . I turned off my Comcast cable box, pressed menu on the remote to the cable box. This made a 16:9 ratio appear on the cable box's LED read out, and a bluish screen appear on my television. One of the options on my television was to turn on and off closed captioning. Therfore, I turned off closed captioning and the problem was solved.
Jan 30, 2009 | Televison & Video
Missing Close Captioning in analog Sony Trinitron
Make sure the CC is not just turned on but in the menu make sure it is set to caption 1.
Jun 20, 2008 | Hitachi 42HDT79 42 in. Plasma Television
Closed caption problem
I had the same issue... here's what I did.  If power off your cable box, then press the menu button, there's a selection to enable or disable Closed Captioning.  This works for both HD series Motorola boxes Comcast offers, at least in the Minneapolis/St. Paul area.  Hope this helps!
Evan
Feb 17, 2008 | Toshiba 42LX177 42 in. LCD HDTV
Televison & Video Logo
23 people viewed this question
Top Televison & Video Experts
