Apple iPhone 5 Logo
A
Anonymous Posted on Jun 25, 2014
Siri no lisen - Apple iPhone 5
madjoker34
Level 2:
New Friend:
Cheetah:
An expert who has answered 20 or more questions within one hour.
  • Apple Expert 49 Answers
  • Posted on Jun 26, 2014
madjoker34
Apple Expert
Level 2:
New Friend:
Cheetah:
Answers
49
Questions
0
Helped
4298
Points
106
Best thing to do is this:
Goto Settings
General
Siri.
Then turn Siri Off then on again.
Disable the whole service.
This should work most of the time.
(( Make sure you have some kind of internet connection as this is how Siri works. EG... Wifi, 3G, 4G ect ))
How do I get Siri on my apple ipad
Press and hold the Home button. Siri is enabled by default on all devices that support it, so usually you can just press and hold the Home button to start the Siri interface. The Siri prompt will appear, and you'll be able to speak your command or question.[1]
  • If Siri doesn't start, it may be disabled or your iOS device may be too old
Say "Hey Siri" if your iOS device is plugged into a power outlet. When your iOs device is plugged in, you can say "Hey Siri" to launch the Siri interface without pushing any buttons.
  • The iPhone 6s, iPhone 6s Plus, iPhone SE, and iPad Pro allow you to use "Hey Siri" without the device being plugged in.
  • If "Hey Siri" isn't working, it may need to be turned on.
Ensure your iOS device is compatible. Siri does not work on older iOS devices. The iPhone 3GS, iPhone 4, iPad, iPad 2, and the iPod Touch 1st-4th generation do not support Siri. Even though these devices may be able to install a version of iOS that supports Siri, they won't be able to use it.
  • Visit support.apple.com/en-us/HT201296 for information on identifying your iPhone if you're not sure.
  • See Determine an iPad Model / Version for information on determining what model iPad you have.
I hope this response helps you out.
I wish you the very best of luck! If I can help you further, please let me know.
I'm available for longer billable discussions at https://www.6ya.com/jim_8a00509cb5f5d7e2
If I've assisted you, I'd greatly appreciate you taking the time to provide me with a favorable rating. Thanks so much!
2answers
Does siri work without internet connexion?
No.
Siri will only operate with an internet connection.
Jan 23, 2017 • Cell Phones
When I try to engage Siri she says she cannot make the connection and I should try again later. I have iOS 10.0.2 installed. I have shut it off and restarted but the problem remains
Siri troubleshooting: Siri's not working at all on my device. Which iPhone/iPad models can run Siri? If Siri isn't working for you, the first thing to check is your model of iPad or iPhone - older devices can't run Siri, even if they update to a newer version of iOS. Siri is available on the iPhone 4s and later, on the iPad 3, iPad 4, and all iPad Pro, iPadAir and iPad mini models, and on the 5th- and 6th-gen iPod touch models. Plus the Apple Watch and 4th-gen Apple TV, of course Siri troubleshooting: How to turn Siri on If it's not working at all, Siri might be switched off. Go to Settings > General > Siri and make sure the top slider (next to Siri) is on, and green.
2answers
I can't find "Siri" on my iPhone 6. Where did she go?
1. Turn on Siri App if this is the first time you use it.
Settings > General > Slide the button next to "Siri" from the "off" state to the "On" sate. Now Siri on your iPhone is enabled.
2. Checking other settings
- Choose your language you prefer: For example, if you have a special English accent, you have options for English (Australia), English (Canada), English (United Kingdom) or English (United States).
- Select your gender: Siri is capable of telling the voice from male and female.
- Enable Raise to Speak. This setting means you can simply pick up the iPhone when it is awake and hold to your ear as if making a call. Once you do so, Siri will activate.
Jan 29, 2016 • Cell Phones
Can I get Siri on my iPad
https://support.sprint.com/support/tutorial/Turn-Siri-on-or-off-Apple-iPad-Air-32GB/WScenario_542_50660_771_en_1361-dvc7820010prd
-From home screen, tap settings
    -With general selected, tap Siri
    -Tap Siri switch to turn feature on or off
    -When prompted to enable Siri or disable Siri, tap preferred option
    -Siri is now enabled or disabled
How to get siri on ipad2 ios 8.1.2
How to configure Siri
  1. Launch the Settings app on your iPhone or iPad.
  2. Tap on General.
  3. Tap on Siri.
  4. Tap on Language to change languages and dialects.
  5. Tap on Voice Feedback to choose whether Siri always talks back to you, or only when in Handsfree mode.
  6. Tap **My Info* to select your Contact card so Siri knows who you are, what your numbers are, and what your locations are. This lets you say things like "Call home." or "Give me directions to work."
  7. Toggle Raise to Speak to have Siri pop up whenever you bring your iPhone to your ear, and you're not on a call. This may drain your battery faster than if it were disabled.
25337929-32tv5p3i4t34gwsttnmh0d03-5-2.jpg 25337929-32tv5p3i4t34gwsttnmh0d03-5-5.jpg http://www.imore.com/how-set-configure-secure-and-start-using-siri#siri-enable
How to turn on Siri
Make sure that siri is enabled by going into your settings on your iphone and making sure that you either have your mobile data on or you have wifi on. Then press down and hold the home button
Top Apple Cell Phones Experts
Grand Canyon Tech
Grand Canyon Tech
ADMIN Andrew
ADMIN Andrew
Paul Bade
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
