Question about Garden
What size sping & screw & what type of screw holds the blade
3 Suggested Answers
budmrtn
  • 11361 Answers
SOURCE: What size/type of screws hold on the stand on the
Mostly will be Metric M5 or M6, you should be able o get them from hardware store for about 25 cents.
http://s807.photobucket.com/home/budm/allalbums
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: try www.shopjimmy.com or Ebay
Posted on Jun 17, 2010
norma_wiles
SOURCE: Stirella sx 8040 d
We have removed the only screw we can get to but can't get the handle off to get to the inside screws
Posted on Apr 07, 2014
What other makes of attachment will fit the MtD power unit?
I have used blades from Toro on my MTD mower, found them better then the what MTD gave me ,bit stronger and cheaper. Just be carefull, when you take the blades off,do keep the 2 screws that hold the blades in place, they have different sizes depending on what brand you have, blades can be swapped but the screws and bolts can not be changed with other types. For belts etc you can use any " generic " brand, size matters but brand is not a big difference, i used belts from 40$ and 100$ , no difference what so ever. To be honest , the cheaper one is still running after 2 seasons while the expensive one snapped after one season.
Apr 20, 2016 | Mtd Garden
Craftsman edger model 358.796480 blade not cutting. Am I doing something wrong? Seems like looks OK but still not cutting.
Assuming the obvious that the motor is turning, the only thing that would keep it from cutting is that the nut holding the blade is not tight enough or the sping washer between the nut and the blade is missing or on backwards. The correct orientation of the spring washer is so the inside surface around the hole contacts the nut, and the outside circumfrance of the washer contacts the blade. P.S. the nut is tightened very tight.
May 18, 2014 | Garden
I need the screw that hold the blade on the saw. its the model # cs185cf
Fixya does not sell replacement screws. Your saw probably uses a flanged cap screw with a standard thread.
Apr 07, 2013 | Kraft Tech Krafttech 12 Amp 7-1/4"...
How to replace the upper cutter on the baby lock? which screws to release the old blade?
I also have a babylock eclipse BLE1DX serger & here's how my book says to do it
to replace the upper cutting blade
1.open the front panel
2.remove the screw holding the upper blade
remove the upper blade
3.position the new blade in the blade slot, replace the screw.as you tighten the screw, hold the blade up in it's highest position
4.close blade cover. close front cover
hope this helps you
good luck
Sep 12, 2011 | Baby Lock Eclipse Serger
King Compound Mitre Saw Mod.# 8370 Sawblade always comes loose. Th Blade is installed properly. What can I do ?????
This is very dangerous... There are possibilities of incorrect installation due to IMPROPER parts. Some blades use a diamond cutout for the shaft. It is VERY important that the right size spindle versus blade is used. The washer under the retaining screw should have a relief on the back side such that the washer lets the shaft protrude a few thousandths through the blade. If the spindle is round without the diamond cutout, sudden stops can unwind the screw. I have hadd that problem on a radial arm saw. I would recommend that you get some thread sealant (removable type) such as Loctite and put a little on the threads FOLLOWING directions. Make sure it is the removable type grade of Loctite. Also tighten the screw properly either using the locking pin or jam a piece of wood in the teeth to hold from rotating while tightening.
Jul 28, 2011 | Garden
We have a ryobi rj150v model reciprocating saw (older model) which needs the blade replaced. It had a broken part, which I ordered several years ago. My husband's FINALLY going to replace the blade,...
There are 2 types of clamps that hold the blade in that type of saw.
Since this is an older one it most likely has the type where the blade is held in place with a set screw and a "U" shaped piece of metal that holds the blade tight against the shaft. There should be a screw hole in the shaft of the saw. The blade rest next to the shaft and then the metal piece clamps the blade against the shaft. This is all held in place by a set screw that screws into the shaft. This screw uses a hex key to remove and tighten it.
If your tool doesn't have this style then it should have a twisting clamp. This will rotate and release the blade. Sometimes a pliers is needed to loosen the collar, but not to tight tho.
Jun 30, 2011 | Ryobi Saws
I need directions on how to change the baldes on a reciprocating saw.
Since this one most likely has the type where the blade is held in place with a set screw and a "U" shaped piece of metal that holds the blade tight against the shaft. There should be a screw hole in the shaft of the saw. The blade rest next to the shaft and then the metal piece clamps the blade against the shaft. This is all held in place by a set screw that screws into the shaft. This screw uses a hex key to remove and tighten it.
Jun 30, 2011 | Skil 921502 85 Amp Reciprocating Saw
How to put together the blade
askmanny.jpg Instruction to assemble a clipper blade.Above picture Socket askmanny_0.jpg
Turn Socket & Spring Tension over Make sure Socket is slide back askmanny_4.jpg
This is Call a Blade Guide Make sure the blade Guide is on the Spring Tension askmanny_5.jpg
Make sure blade guide is on like picture above, Now place Socket & Spring aside askmanny_6.jpg
Place cutter blade as picture above, making sure cutter blade smaller blade is on the comb blade Rail. askmanny_9.jpg
Hold the blade like this Finger on top and Thumb on the bottom askmanny_10.jpg
Turn blade over like this while still holding the blade together askmanny_11.jpg
Now that you have the 2 screw in and not tight place the blade like this You need to hold the blade with one hand and with your Philips screw driver tap the cutter blade back lightly until the cutter teeth are 2/32 back from the comb blade. askmanny_14.jpg
the cutter blade which is the smaller blade is back 2/32 from the comb blade which is the bigger blade. When this is done by holding the blade together with your finger & Thumb askmanny_15.jpg
We hope this was helpful when assembling a clipper blade.
May 11, 2011 | Andis AG 2 Hair Trimmer
My new toliet seat dosent seem to screw on properly its all wobblerly its going from side to side
You probably just need to tighten mounting screws. Most screws are covered by a cap or cover that snaps into place. You should be able to unsnap the cover with a small blade screwdriver or knife point. Use a wide blade screwdriver on the slotted head screw on top to tighten while holding retaining nuts on the underside of toilet. Some of the screws and nuts are plastic so you should be able to hold the nuts by hand while using screwdriver to tighten screws. If you can't hold nuts by hand use pliers. Some use brass screws and nuts so use proper size wrench to hold nut. Hope this helps you. Thanks
Nov 22, 2010 | Home
Change blade
OK first raise the cutting head. Loosen the screw that holds the guard in place and move out of the way. Find the spindle lock on the right hand side of the gearcase and turn blade by hand (UNPLUG SAW FIRST) until it locks. With the wrench supplied with saw put it on the blade bolt and turn it clockwise to loosen, it has left hand threads, remove outer flange and blade. Let me know it you need any more help
Jan 24, 2009 | Black & Decker DW713 10 In. In. Comp Miter...
Garden Logo
51 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
