Question about Yard Machines 158cc Push Lawn Mower #11a 034f200
Won't retract the pull string
The lawnmower won't retract the pull string
  • 64 Answers
The pull cord assembly either has something jammed in there or it's busted. Take the 3 or 4 bolts out that hold in on to the top, and inspect it for damage. If there's nothing in there or it's not damaged it might have just slipped off the spring. Rewind your cord and reinstall it.
Posted on Jun 27, 2009
Jessie doll string in the pulled position
Sometimes you can get the string cord to release and retract back. Hold the doll firmly and gently pull the string out about an extra two or three millimetres (eighth of an inch) or as much as possible. Keep the string tight for a short while and then allow it to retract slowly. It may take a few attempts, the skill is in pulling the string that little extra distance, holding it for a few moments, then slowly releasing it again.
Dec 30, 2013 | Toys
Ryobi ss26 trimmer puller cord won't retract
It appears that the recoil spring has broken and you will have to pull it apart to replace it
Jun 17, 2013 | Ryobi Multi-Volt Battery Charger
Pull string won't recoil
its your Recoil spring that is causing it to do what it is doing it may have came off or broke
Jun 07, 2013 | Garden
Blower string wont retract
you might have installed the wrong spring type, check also the stopper or the lock inside that holds the spring secure.
Jun 04, 2013 | Garden
Cant pull string on lawnmower
if motor is lock up pour oil in clinder and work the blade back and forth till it unlocks
Apr 28, 2013 | Craftsman Garden
Pull cord on my lawnmower is inoperative
You need to take the Starter cord assembly off and see if the Nylon gearing that 'grabs' the centrifical wings is broken OR those wings are rusted in a way that they do not make contact with the nylon piecs of the Starter.
Dec 07, 2012 | Craftsman 55 Torque 158cc 22" Push Lawn...
I have a stihl fs 80, the starter cord will not retract after the first pull. The spring is still intacted but doesn't spring back when re-attached to weed eater.
One of 2 things come 2 mind, if the spring is still in tact it could be that the retract line might be slightly to long and forces the spring to over travel and lock up against itself. A simple test would be to pull the pull start to only 80%. If at 80% it retracts normally then shorten the pull string by a few centimeters . alternatively the spring may be over tensioned by a turn or two. to release pull the string out with the pull starter off the machine to about halfway, hold down the recoil to release the tension off the string and pull the string out towards you through the slot provided on the face of the recoil into a loop. Gently let the recoil slip one full turn at a time until there is just enough tension to pull the handle all the way back. if its too loose just revers the process one turn at a time. its not complicated, to do but can be tricky,
if DIY is not your thing, refer to someone better qualified,
Sep 05, 2012 | Garden
Poulan Pro Lawnmower
i have a 950 zx poulan pro lawn tractor. it will start but when i release the brake it cut off . i can start it up with out sitting in the seat.
Jun 14, 2008 | Dryers
Yard Machines 158cc Push Lawn Mower #11a 034f200 Logo
1,441 people viewed this question
Top Yard Machines Garden Experts
dannydoesita
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Yard Machines Garden Expert? Answer questions, earn points and help others
