Question about Generac Guardian 200 Amp Transfer Switch with Service Disconnect NEMA 3R
Engine will not start, Watchdog 15K
I recently purchased this unit used for about 10 days when the last hurricane came thru east Texas. It had been running on butane and was unhooked when I purchaed it. don't know how long unhooked. I followed the manual and changed the "carberator" to LP gas and installed the proper regulator. Tried to start, but it would not. Checked the fuel solenoid, and it is getting 12 volts during cranking. thought it might be bad, so installed a new one. Before istalling new solenoid, turned the gas on for a second, so it is flowing up to the solenoid. Still won't start. It is getting fire to the plugs during cranking, pullede one spark plug wire off and stuck a screw driver in the wire, it jumped flame about 3/4". Any suggestions?
  • briscoeinves Jun 27, 2009
    I have already replaced the fuel solenoid. Prior to and after replacement, I have 12 volts at the solenoid (wire #14) during cranking. If the regulator or "carberator" is not working, what should I look for?
  • briscoeinves Jun 28, 2009
    Replaced both of them already. I am going to have my local LP distirbutor come out this week and check my pressure. Just because I put a new regulator in the fuel line, it does not necessarily mean it works. thanks for the help
  • 15,935 Answers
Is the plug fouled??
Posted on Jun 28, 2009
  • 508 Answers
Its not get any fuel to cylinder the solenoid that lets fuel in is most likely not letting fuel in or regulator is working properly disconnect solenoid going into cylinders jump voltage to it see if you can smell fuel to cylinders if not check for stuck solenoid valve or inoperable regulator!!!Best of Luck to You!!!!
Posted on Jun 27, 2009
  • Aaron Tonning Jun 28, 2009
    did you get working?
Recently bought XJS V12 with 15K miles; driven only 1K miles since 1993. I drove the car 250 miles the day I bought it with no problems. Since then, it idles well for 30-60 seconds but then stalls.
Check the fuel filter(s). Your long drive may have shaken dirt or old fuel gunk ("varnish") loose and plugged the filter most of the way. Enough fuel gets by to start the engine, but then it starves when you put it under load.
Aug 27, 2016 | Jaguar XJS Cars & Trucks
How long would it take to walk across the state of texas
The distance from Orange, TX (on the east) to El Paso, TX (on the west) is approx 762 miles.
Since the average walking speed is approx 3.1 MPH, it would take about 246 hours (10 days plus 6 hours) to walk across Texas.
(That is, figuring a constant walking speed for over 10 days, without stopping to sleep, eat, etc).
Plz rate via the helpful button if this helped answer your question. Thx.
Nov 05, 2014 | Washing Machines
Our power has been out for six days due to Hurricane Sandy. When we got power back today, the fridge wouldn't come on. Keeps tripping the ground fault. suggeations?
I am sorry for the problems you are having. I live in New Orleans so I know what you are going thru.
What is the model number of the unit?
Nov 05, 2012 | Kenmore Refrigerators
System reset by watchdog.tion
I've never seen a watchdog.tion error but watchdog errors can be set up on some CMOS when the 5v power from the power supply is bad.
I can't find anything on your specific error tho but I would try a different Power Supply Unit.
Jul 31, 2012 | Biostar 945GC-M7 TE Motherboard - v6.0,...
My sise by side refrigerator and freezer does not cool. it is on,it blows out air,air is not cold. the pow er was cut off during hurricane irene ,did that damage it ? also i cleaned it out,thru out...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Aug 31, 2011 | Whirlpool 25.3 Cu. Ft. Side-by-Side...
It,s always written DOOR on my lcd oven board.The oven doesn't heat.
Hi, it sounds like one of the "lock" switches for the self clean door lock assembly may be faulty, or the oven door light/monitor switch is faulty. Is the oven light "on" ? Either that or when the unit was last placed in self clean the cycle may have been interupted by a power failure or some other accidental/intentional "cancel" command. Try unplugging the unit and plugging it in again right away. The "reset" should force the oven thru a start-up cycle, it essentially makes the onboard "watchdog/monitor" in the processor to check all the switches for the proper position and makes the lock go thru a lock to unlock position. The unit may correct itself just by going thru this off-on process. Hope that helps, let me know. Good luck
Oct 01, 2009 | Ovens
Generac Watchdog 15K, engine will not start
throttle motor or governer board. or control board. your gas line could be to small. check the pressure while its cranking to see if it drops. watch the throttle to see if its moving while trying to crank the generator
Jun 27, 2009 | Generac Guardian 200 Amp Transfer Switch...
5yr old go.video/dv1130 recently dvd's stick for 3-5 count then jump
5YRS OF USE?I WOULD HAVE TO SAY IT HAS PROBALY BOUGHT THE FARM(OR IS ABOUT TO)USE THE UNIT FOR ITS VCR FUNCTION,& BUY ANOTHER DVD PLAYER.YOU CAN GET A GOOD 1 FOR AROUND 40$ WAL MART HAS A NICE SELECTION.I JUST BOUGHT A PHILLIPS FOR 34$ AND IT WORKS GREAT.ANOTHER OPTION WOULD BE TO TRY A DVD LENS CLEANER & SEE IF THIS HELPS.EITHER WAY IT WOULD COST YOU MORE THAN THE UNIT IS WORTH TO HAVE IT REPAIRED.HOPE THIS HELPS
Oct 20, 2008 | GoVideo Go Video DVD/VCR Combo
Low oil pressure indication in suburban
Dan,
If your oil pressure actually dropped below 10 psi at idle, your hydraulic lifters would start to collapse. This would cause them to "tick" or "click" at idle. If you are not getting this clicking, change the sending unit.
Charlie
Jul 15, 2008 | 1989 Chevrolet Suburban
Generac Guardian 200 Amp Transfer Switch with Service Disconnect NEMA 3R Logo
165 people viewed this question
Top Generac Electrical Supplies Experts
Craig Butler
Craig Butler
dennys23601
Don  Farrell
Don Farrell
Are you a Generac Electrical Supply Expert? Answer questions, earn points and help others
