Question about Pool & Spa
Lx220 worsks sometimes in the auto setting.
Their is plenty of solar heat outside. The equipment is about 4 years old.
    Champion:
  • 246 Answers
SOLAR SENSOR IS OPEN OR NOT GOOG CHECK YOUR WIRE AT THE SENSOR IT MAY BE INSTALLED AT THE ROOF SO BECARE FULL
Posted on Oct 15, 2009
I have a tomtom satnav and it will not find any signal while in my new van. The van is a Citreon Relay and is 4 years old. The satnav worsk fine in any other vehicle. Is there some sort of signal bloc
first of all make sure there is a clear line of sight with the sky ( middle on the bottom of the window) also important make sure the charger connects well. sometimes it needs a long time to find so try fixing satelite position while not moving for example at home near open window while charging
Aug 20, 2014 | Tomtom ONE GPS Receiver
Solar outside temp. unit has started losing power
If the rechargeable battery is two years old, it probably needs to be replaced
Jan 29, 2013 | La Crosse Technology TX61U-IT Solar...
I have a 4 year old intertherm AC /Heat pump...all works ok - but sometimes in summer or winter - when the inside unit cuts off - the unit outside still runs and whines and sorta sounds like a grinding in...
Has it always made that noise? If so then I would think that after 4 years and no problems that it is nothing to worry about. If it is something new then turn it off and call a service tech to look at it. I am leaning toward the service tech.
Jun 15, 2011 | Heating & Cooling
I've a pentair solar control panel for my solar system for my pool. On one sunny and very warm day in California, the water in the pool remained cold after a few hours of circulation. Therefore, I was...
There are many variables to this......
How big is your pool how big is your solar system.
Solar temps don't rise quickly ever, and definitely not when the temp is only 75 outside.
You need 80-90 degrees or more on the roof to see quicker results, if the water temp is currently at 70 and it's 75 degrees outside and 80 on the roof you will barely get any change.
You will also lose the heat at night due to lower temperatures.
Once it's hotter outside and warmer at night you get the gains and keep them.
Hope this helps
Mar 24, 2017 | Fafco Deluxe Solar Panel Heating System 1...
I have a Trane Xe-60 furnace about 19 years old. During summer months, with thermostat set to deliver air, the outside condenser runs, but furnace blower does not. I can move thermostat lever from auto to...
THIS IS A COMMON PROBLEM WITH THE DOOR SWITCHES, MY FIRST ANSWER WOULD BE REPLACE THE SWITCH SECOND WOULD BE OPEN THE DOOR AND PUSH THE BUTTON IN AND SEE IF THE FURNACE WILL WORK. THIS SWITCH IS JUST A DOOR SAFTEY IF THIS WORKS. I HAVE TAPED A PIECE ON THE INSIDE OF THE DOOR WHERE THE SWITCH WILL HIT THE DOOR ABOUT A 1/4 INCH THICK AND SEE IF THIS WILL GET YOU RUNNING UNTILL YOU CAN GET A SWITCH
Oct 12, 2009 | Omega Trane Furnace Draft Inducer Blower...
Automatic mode not to respond LX220 solar heat pool
please be more especific about what is not working
Aug 27, 2009 | Pool & Spa
I have a Compool lx220 control for my pool solar
Check the valve actuator toggle switch. It is 180 degrees out. If the toggle switch is in the up postion flip it down or vise versa.
Aug 26, 2009 | Pool & Spa
Same Issue
the pump stop so will not drain spa dip # 4 may turn off for the delay but not sure if the pump will still turn off since this is new tech. good luck
Jul 05, 2009 | Jandy Aqualink Rs4 One Touch Control...
Fafco Solar Panel system - how to bypass sensor?
I would, put a quarter turn ball valve in the sensors place.
Apr 14, 2009 | Fafco Deluxe Solar Panel Heating System 1...
Whirlpool Gas Dryer, LGR5636EQ2, timer not moving on Auto (DryMis
If that is a 3 wire gas assembly then the timer is screwed.The orange wire when removed from the mix will make the thing advance. The trouble is in the timer. If that is a 2 wire gas operator you need to change the high limit and open up the outside vent. My opinion.
Nov 14, 2008 | Whirlpool GGQ8831L Gas Dryer
Pool & Spa Logo
122 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
