Question about Panasonic CT-32SL14 32" TV
Panasonic ct-36SL13G worked fine, one day would not power up.
Fuse is not blown. Any suggestions?
  • 37 Answers
The plug fuse may not have blown but the fuse inside set may have blown, or dry solder joints on pcb
Posted on Jul 13, 2009
Our Panasonic CT-27HL15 set is only 4 years old and suddenly decided not to turn on. When you press the power button, it turns on for a second then makes a noise inside and shuts off. Any ideas is it worth...
I have one of those that is the same age and the 6.3 amp fuse was blown out. I replaced it with a 6 amp fuse (i could not find 6.3 nearby) and got a few more weeks use until the fuse blew out again. someone suggested i get a slow blow fuse next time.
Jun 20, 2009 | Panasonic CT-27HL15 27" TV
My Panasonic HDTV 1080I just died- no power! The model number is CT-36HL43G.
I would suggest to try a different power outlet.
I could also have a blown fuse inside. the fuses can blow due to the following conditions:
Power outage, shorted hardware condition inside your TV.
Apr 13, 2008 | Televison & Video
Panasonic CT-32g19j
check The B+ of your tv. If no b+ Check the input AC voltage. If Ac i/p are ok but no B+ Volt maybe your IC in power supply has problem.
Jun 01, 2009 | Panasonic CT-32SL14 32" TV
Panasonic HDTV /no power
the loss of power was do to a blown fuse. could not access it through the small opening near where the power cord went in at the back of set.. carefully took the back of just far enough to access the fuse and replaced it. Working fine.
Nov 25, 2008 | Panasonic CT-36HL43 36" TV
Panasonic television
I had the same problem, however mine was a 32inch. It is a blown fuse. It is not the power cord. What you need to do is find out what fuse voltage you need. Hope this advice helps. I have a panasonic model CT-32SX12C.
Aug 20, 2008 | Panasonic CT-36SX12 36" TV
Panasonic ct-36sl13g
Mine did same thing. Found a fuse blown by the power cord inside case. Replaced it and power came back on.
Jan 13, 2008 | Panasonic Digital Video Duplex, Color...
Main fuse blown on CT-32G11 32" Panasonic TV, Replacement fuses continue to blow.
If the main fuse keeps blowing, check the horizontal output transistor for a shorted condition and diodes in that section as well.
Jan 12, 2008 | Panasonic CT-32G11 32" TV
Panasonic CT-32sl 13 32" TV
This sight rocks! And so do the people that posted information! Went to Radio Shack and got the 6.3amp 250 volt fuse. Fuse was easy to get to once I removed all of the screws and easily slid off the back. $2.99 fix (foe the fuses)
Jan 04, 2008 | Panasonic CT-32SL14 32" TV
Panasonic model CT-36SL13G TV
Your problem is most likely the thermistor , or degausser, is going bad. It is a little black box with pins and says D1R5M on it. It can be found by following the wire from the degaussing coil around the picture tube. The location number is CF803( i think)the Panasonic partnumber is D4DF1R50001. Also, I believe your fuse is 6.3A not 3.6A.
Nov 07, 2007 | Panasonic Digital Video Duplex, Color...
Panasonic CT-32SL14 32" TV Logo
208 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
