Question about Whirlpool Washing Machines
Water continues to fill and overflows - Whirlpool Washing Machines
  • Whirlpool Master
  • 3,361 Answers
1.Drain hose is too low. Minimum 30 inches from the floor.2.Water fill valve is defective. If it fills with timer set to OFF,replace the water fill valve.
3. The Air hose from the tub to the water level valve is pinched or stopped up with soap scum. Check the air hose for a pin hole,pinched or obstructed..
Posted on Jun 27, 2009
After my toilet fill valve shuts off, water continues sipping into tank slowly. This causes water continuously overflow through overflow tube.
check that the fill valve was installed correctly
adjust the float level so that when full the cistern water level is around 1/2" below the over flow pipe end
what you have now is that the inlet water is not being shut off correctly and the water is still coming in and flowing out of the overflow
Mar 20, 2017 | Washing Machines
I have mtr-2 dishwasher ..it is continuously showing the symbol for water filling and not going even water fully filled ..what should i do..bcz machine is not running....
You say it says water flowing. But, is it flowing? Does it overflow? If so it may be overflow switch on the bottom that got food stuff in it.
Mar 27, 2016 | Dishwashers
How to fix amana w10240534c washer wont fill?
check your water inlet valve. Check it for continuity with a multi meter it should show Ohms or a closed circuit. To test it when water is overflowing unplug the unit and see if it still overflows or continues to fill. no fill If it stops when unplugged. Then it is not a water inlet problem but an electrical signal problem going to ur water inlet valve. Possibly from the panel or board.
May 31, 2014 | Amana 3.2 cu. ft. Top-Load Washer
Washer will not fill with water
The other item to check would be your water inlet valve. Check it for continuity with a multi meter it should show Ohms or a closed circuit. To test it when water is overflowing unplug the unit and see if it still overflows or continues to fill. If it stops when unplugged. Then it is not a water inlet problem but an electrical signal problem going to ur water inlet valve. Possibly from the panel or board.
Mar 06, 2014 | Amana Washing Machines
Water will not fill
Mar 04, 2014 | Amana 3.2 cu. ft. Top-Load Washer
Leaking toilet from overflow
if you flush and the water continues to run into the bowl the it is the flush washer that needs repalcing
If that water shuts off and the cistern fills and then continues so that it flows down the over flow pipe into the bowl the it is the water inlet control washer that needs replacing
Feb 20, 2018 | Porcher Home
When machine is filling with water, it overflows
The soleniod valve is bad.... here is a tip that will help...the problem you have is with the same part but the opposite problem...
http://www.fixya.com/support/r3880845-washing_machine_problems_no_water
heatman101
Apr 27, 2010 | Maytag Neptune MAH6500A Front Load Washer
I have a Whirlpool stacked washer and dryer combination. The water is overflowing on the washer. It happens during the rinse cycle when the water is filling up. It appears that the cycle gets "stuck" in...
check the pressure hose. a kinked clogged or disconnected hose continues to fill. the pressure switch senses the air pressure in the hose.awaiting your further comments. thank you.
Dec 23, 2008 | Whirlpool LTE5243D Top Load Stacked...
Washing Machines Logo
111 people viewed this question
Sal De
Gerry Harvey
Gerry Harvey
