Question about Mitsubishi VS-50111 50" Rear Projection Television
VS-50705 50" rear projection TV does not
VS-50705 50" rear projection TV does not power up. Diagnostics say it has a problem with "Short protect (short protect monitors low voltage supplies)". I don't know what that means
  • 261 Answers
Hi is most robably that you are having a issue with the power supply.
Posted on Jun 27, 2009
I keep getting a blank blue screen when I turn on my Mitsubishi 60 inch TV and then turns off by itself after about a minute. When I press "pip" on my TV remote I can see a small square screen...
there are 2 tuners in a rear projection tv. maybe the main tuner is faulty or the tuner's associated circuit has problem. if there is no signal these tv are programmed to turn the power off/stand by.
Aug 19, 2011 | Mitsubishi VS-50603 50" Rear Projection...
AFTER TURNING ON TV ,THE GREEN LIGHT COMES ,SOUND STARTS AND THEN TV TURNS OFF ASAP
after tv shuts off press and hold menu and input buttons on tv at same time for about 8 second. power led will start to blink error code 12 ok 22 dead short 23 deflection failore 24 vertical failore. after you know error code have electronic technition repair for you. J.D.W.
Jun 24, 2010 | Mitsubishi VS-50607 50" Rear Projection...
Estimated Weight
Direct quote from 2001 Mitsubishi Product Catalog Specs. Gold Series
VS-70707
Weight (approx. lbs.) 365
Jul 19, 2009 | Mitsubishi VS-70707 70" Rear Projection...
Mitsubishi 50111
Run the diagnostics.
With the TV power cord plugged in, press the 'INPUT and 'MENU' buttons at the same time -- use the buttons on the front of the TV, NOT the buttons on the remote; a diagnostic Error Code Operational Check will begin, utilizing the 'POWER ON' LED (the green 'POWER ON' indicator light).
There will be a pattern of two sets of flashes, with a pause in bewteen flashes; this sequence of flashes will be repeated a total of five times.
The Error Code designations are listed below:
Error Code Description
12 No eror has occurred.
21 X-Ray Protect circuit.
22 Short Protect circuit.
23 Horizontal Deflection failure.
24 Vertical Deflection failure.
I hope this information helps.
Jun 17, 2009 | Mitsubishi VS-50111 50" Rear Projection...
Mitsubishi VS-5004R No Picture and No Audio
not enough power, you may need to rebuilt or replaced the power board
Mar 31, 2009 | Mitsubishi VS-50605 50" Rear Projection...
VS-50609 no picture no sound
Seems to be the power button is stuck on the tv itself
Jun 24, 2008 | Mitsubishi VS-50609 50" Rear Projection...
Shutdowns
How long does it come on? If on then off, possible short somewhere, if turns off during movie, maybe weak power supply.
Apr 25, 2008 | Mitsubishi VS-50607 50" Rear Projection...
Mitsubishi Projection TV Model # VS-50502
The power supply section is having trouble.
Common possibilities are:
- Convergences amps have failed overloading the supply
- High-voltage section (flyback transformer) has failed
(happens sooner or later, about 8 years typical))
- Power surge has popped the power input circuit.
(Fuse, rectifier diodes, turn-on relay etc)
- One of a hundred of electrolytic capacitors has failed short overloading the supply. They dry out with age, are cheap to replace, but hard to find which one it is.
- Or any of many other possibilities.
In short, you need a experianced tech to troubleshoot this.
Feb 13, 2008 | Mitsubishi VS-50502 50" Rear Projection...
Need help repairing Mitsubishi VS 4541 rear projection TV
This model is equipped with a self-diagnosis feature to help with diagnosis of shutdown problems, to activate this turn the unit on let it shutdown then press the input and menu buttons on the front panel simultaneously and hold them in for 5 seconds after 5 seconds the power LED on the front panel will blink a two digit sequence. This will be one set of blinks a short pause then another set of blinks, this will repeat 5 times. 1 - 2 = no error detected 2 - 1 = X-ray protect (high voltage or beam current) 2 - 2 = Short protect (short protect monitors low voltage supplies) 2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection) 2 - 4 = Vertical protect (usually loss of vertical from the source
Jul 28, 2007 | Mitsubishi VS-45605 50" Rear Projection...
Blown fuse
Sounds like a problem in the transformer (a short) possibly visible as surface burn marks on the transformer coils. This can sometimes be fixed, but is not usually worth it for a small transformer, but easily replaced. Also check that there is not a short where the power cord connects to the workings of the tv, maybe a loose connection or some debris. Hope this helps :)
Mar 18, 2007 | Mitsubishi VS-50607 50" Rear Projection...
Mitsubishi VS-50111 50" Rear Projection Television Logo
185 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
