Question about Mitsubishi VS-50605 50" Rear Projection Television
Mitsubishi Projection TV. Works for a couple of hours and then the picture shuts off
After about 5 hours the picture shuts off and the sound works. You use to be able to shut the TV off and turn it back on and all was good. Now you have to wait an hour or so and it work again. If you don't it will work for a couple of minutes and the picture will shut off again. If it helps a while back we noticed lines going horizontally across the screen at the top and bottom in random patterns (black and white). It still does that and that usually tells us the TV is about to go...but the lines do not always show up when it happens. Also when it happens the picture kind of absorbs itself into a horizontal line with 3 colors and then it all goes black. This happens very quickly.
We did call out a service guy and he could not recreate the problem. He noticed a couple of cracks and he soldered them. The problem has not been fixed since we had it happen twice within a week of him fixing it. The weekend seems to be when we see the problems since the TV is on more hours..... any help is appreciated.
  • 1,694 Answers
Very often older Mits CRT's develope a slow leak of coolant
onto one of the circuit boards....various problems arise,depends
on where the drip lands....even a good tech can miss the drip
evidence.....I have pulled the chassis to the shop only to find
"wet" area under well-lit conditions.................T.
Posted on Dec 04, 2007
I have a Samsung HL-R5678W DLP TV that is acting up. When I first turn it on everything works, after 5 minutes it shuts itself off. After 2 minutes it will come back on without sound. It will do this a...
U turn tv on hear any squiling,grinding or motor noises?Picture show up before it shut down picture have flashes of black&white within the picture?Yes,to all of these,this tv have a colors wheel and it dead,require the colors wheel replacing.No,none of these problems.The tv projection lamp,if in this tv like a 1 1/2 or 2 years,tv ben on an watches like 4 or 5 hours a day?The "LAMP" LED light indication lite up or flahes,the projection lamp life is over.Require a new projection lamp.
Oct 22, 2010 | Samsung DLP HL-P5663W 56" TV
The picture on our Mitsubishi 1080P went off but
Ur tv have been on using like 4 or 5 hours a day?This tv have not been replaced it projection lamp?The lamp in the tv used like a 1 or 1 1/2 years?The projection lamp life is over,replace the lamp.
Jun 15, 2010 | Mitsubishi WD-60735 Projection Television
Mitsubishi projection tv picture and sound turn off but the power button remains on with no picture or sound turn tv off real quick and then back on and works for 2 mins then turns off again what could be...
Here's the basic troubleshooting:
  1. Make sure that no front panel buttons are inadvertently stuck in an "engaged" position.
  2. Disconnect ALL devices from the TV.
  3. Press the SYSTEM RESET button and hold for 10 seconds. Proceed if the problem still exist.
  4. Press and hold POWER and MENU buttons simultaneously for 20 seconds. Proceed if the problem still exist.
  5. Unplug the TV from it's power source for various times, ranging between 5 minutes and 24 hours.
  6. If it still shuts down, press the DEVICE and MENU buttons on the front panel simultaneously and hold it for 5 seconds to activate the Error Code Operational Check. The status LED indicator will then flash denoting a two digit code.
  7. Count the number of flashes then pauses for about a half second then flashes again. The first number of flashes indicates the first digit of the error code and the second number of flashes indicates the second digit of the code. For example, if the error code is "35", the LED will flash 3 times, pauses, then flashes 5 times. The error code is repeated a total of 5 times.
Please let me know the code you got and I'll tell where the problem lies and how to fix it.
Dec 01, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Mitsubishi vs-5041 -after a few hours on, the tv goes black
Get the projection bulb checked if fine its something internal in your tv but i think you need new bulb
Aug 01, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi w52525 - replaced lamp and red light still on
could be the wrong lamp or not set right in housing or bad door switch.
May 03, 2009 | Mitsubishi WD-52525 52" Rear Projection...
TV turns on with sound but blank black screen
This solution from troylove solved my problem. troylove11
Rank:wizard_s.gif Wiz
Rating: 85%, 1164 votes
This model is equipped with a self-diagnosis feature to help with diagnosis of shutdown problems. To activate this turn the unit on let it shutdown then press the input/device and menu buttons on the front panel simultaneously and hold them in for 5 seconds after 5 seconds the power LED on the front panel will blink a two digit sequence. This will be one set of blinks a short pause then another set of blinks, this will repeat 5 times. 1 - 2 = no error detected 2 - 1 = X-ray protect (high voltage or beam current) 2 - 2 = Short protect (short protect monitors low voltage supplies) 2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection) 2 - 4 = Vertical protect (usually loss of vertical from the source.
Jan 07, 2009 | Mitsubishi VS-50607 50" Rear Projection...
Big Screen TV not working
Check your video input cable or replace, maybe it is damage if not Video chip problem etc
Dec 16, 2007 | Mitsubishi WS-55513 55" Rear Projection...
Mitsubishi TV problem
your unit is lack of oscillation! thats why your unit turn off it self! maybe change value of resistors or capacitors... or maybe lost contact to oscillation circuit....
Sep 26, 2007 | Televison & Video
TV does not come on.
I had the same problem, it had a couple of bad condensors. I took it to a local shop and total repair bill was $180.00 Well worth it. TV works great now. Glad I had it fixed. ( your cost may be cheaper I live in Po-Dunk USA)
Feb 06, 2007 | Mitsubishi VS-60621 60" Rear Projection...
Mitsubishi VS-50605 50" Rear Projection Television Logo
175 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
