Question about Astoria Divina SAE-1 Espresso Machine
I am getting steam and or air in water line feeding my machine.
I have a manual lever style duel head Astoria Machine Made in 1968 or 1969. I am using it in a self contained (using water tanks) drive-thru espresso shop. I am getting air and some times steam in the water line feeding the machine. This causes the water pump to cycle on and stay on or in extreme cases the machine loses pressure and will not steam milk or make shots. I have replaced all the water lines feeding into the machine with the thought that the machine could be sucking air from an old water line fitting this is not the case I still have the the problem.
    President:
  • 1,618 Answers
Try adding an accumulator in line after the shurflo pump, that will assist the machine.
Posted on Jun 30, 2009
How are the 2 lines from the pressure gauge supposed to be hooked up to the tank? We just bought this machine and cleaning it up when we noticed the 2 lines coming from the gauge but only one line (the...
One of the lines is for pump pressure and lines up with the side that reads 0-15, that would be the one leading to the bottom of the machine. The other side is for steam pressure which reads 0-3 that is connected to the boiler. As for the grouphead if the screen is in place you should be able to use a 5mm allen wrench if that is what the screw head is, which is someone changed it from a flat head that is what they put in.
Mar 19, 2015 | Astoria Divina SAE-2 Coffee Maker,...
Astoria sae 2n . the lights stay on. They do not flash. Nothing comes out of the heads but water did come out of spouts that are located directly behind panels. There seems to be one for each espresso head...
Has the machine been cleaned / descaled? Coffee machines become clogged with mineral scale deposits from the water. Some folks use citric acid , about two tablespoons /qt of water, and some folks use white vinegar, 1/2 & 1/2. Place the solution in the machine as if you were making coffee. It may take a few cleanings if there is a lot of deposits. After cleaning dissolve two tbsp of baking soda in a quart of water and run through machine to neutralize the acid.
May 13, 2014 | Coffee Makers & Espresso Machines
Blinking lights in Astoria sae
Water is not flowing through the flowmeters. It could be a blockage in the line or the wheel is damaged or the flowmeter head is damaged. But the blinking lights indicate a water flow problem.
Oct 27, 2011 | Astoria Argenta SAE-2 Espresso Machine
We have an astoria model SAE.2 for some reasen the machine has gone very quiet and appears to be strugling when re charging after each use
It sounds like the water pump is not doing its thing or the machine cannot get water, either blocked filter or water line.
Jan 03, 2011 | Astoria Divina SAE-1 Espresso Machine
We need to increase the hot water temperature, how
Depending on the model, if using a manual knob for the tea valve(same kind of setup as the steam) then you will have to turn up the p.stat. If it has an electronic button then remove the front top panel and look on the side of the solenoid you will notice a knob attached to another solenoid called an economiser valve, there should be a plus and minus sign on the knob. Reducing the amount of cold water being mixed with the hot water will increase the temperature.
Jan 25, 2010 | Astoria Divina SAE-1 Espresso Machine
I need a new pressure guage for an Astoria A2 - coffee machine
here is the site where you can get your presure gauge and other parts for your machine.http://www.espressoparts.com/results.cgis?catalog=&select=NAME&keywords=astoria+pressure+gauge&image.x=15&image.y=14
Jan 19, 2009 | Astoria Argenta AEP-2 Coffee Maker,...
Hot water no steam low psi
Boiler pressure gauge should be showing in the green zone which should get you 195+ degrees.
Nov 17, 2008 | Astoria Argenta SAE-2 Espresso Machine
Astoria Divina SAE-1 Espresso Machine Logo
168 people viewed this question
Top Astoria Coffee Makers & Espresso Machines Experts
noel
noel
J.D. Browning
J.D. Browning
Kolbrun...
Are you an Astoria Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
