Ietm stuck between inner and outer front load washer drum maytag
Maytag mfw 9600sq. I would like to know how to take machine apart to get to drums, please. thanks so much, tiff
  • 82 Answers
Need u to post make and modle
Posted on Jun 27, 2009
Drum rotating unevenly, squeaking
If the drum moves up/down side/side without the outer drum moving, bearings gone, replace. To check for clothing, which I doubt, remove front seal outer section, look around outer part, to bottom you probably find clip, prise apart, front back, not side ways, refit sideways
Mar 16, 2013 | Maytag MAH2400A Front Load Washer
Washer maytag front loading 4000 series assembled and runs but iwith two problems.1) residue on inner surface of door window..lint like oily paste ..gasket rubbing on inner drum?? meaning main rubber
The fault seems to be that the main seal is rubbing against and is thus producing the oily residue on the window. Now the fault seems that the drum is rubbing due to POOR ALIGNMENT or poor BEARING settings.
You need to check the PLAY on the drum and if this shakes a bit then the assembly must be reset with correct aligment and the drum must move without rubbing the rubber seals.
Check this link; replacing bearings
Jan 14, 2013 | Maytag Washing Machines
Washing machine making vey load something is wrong noise. Called repair man, he states too young (2yrs) to be a drum problem and okay to use just do smaller loads. On 2nd load found metal shavings..have...
The rear half of the outer tub that contains the rear metal bearing has loosened so much that the inner drum has sagged and is rubbing on the front half of the outer tub. You need to see if this is under warranty. There is usually a 5 year warranty on the outer tub and a 10 year or a lifetime warranty on the inner tub. When I do this repair, I replace the rear half of the outer tub and the inner drum since it's under warranty anyway. The repair is the most difficult and time consuming repair possible on that type of washer. It needs to be done by an expert, not just your average washer repair guy. It's not rocket science, but you have to take EVERYTHING apart and it takes a long time and you've gotta know a few things about the machine in the first place. It's not fun. If it's under warranty for parts, expect to pay between $75 and $200 for labor. If the parts are not under warranty, then throw it away. They're $500+ for the parts.
May 25, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Progressively louder on spin maytag neptune model# MAH5500BWW serial#C8028996LC
You have a bad rear drum bearing ( unfortunantly , so do I ) . This involves removing the inner drum and outer drum . The complete rear of the outer drum , has to be replaced , due to the bearing is already installed in the new one . Very expensive to have done and very time consuming to do yourself . You probably should invest in a different washer . Front load washer manufacturers , have not come up with a way to support the front of an inner drum as well as supporting the rear also . Until this happens , rear bearing problems and excess expense for repair , will continue to be the downfall of front loading washers .
Nov 17, 2009 | Maytag Neptune MAH5500B Front Load Washer
Bra wire's trapped between inner and outer drum,
If you cant pull wire out from inner drum with long nose pliers, Remove heating element and use torch to inspect bottom of washer. Most of the time the obstruction makes its way to the bottom. Use whatever tool necessary to remove spring.
Sep 25, 2009 | Hoover AAA160 Front Load Washer
Maytag Epic Z Washer has object between drum and tub.
did you ever find out how to separate the tub and basket on your maytag washer? I have exactly the same problem.
Jun 23, 2009 | Maytag EPIC MFW9700S Front Load Washer
"whirlpool duet makes big noise on hi spin cycle and sandy grey staf is coming out from drain hose"
You have a big problem here. It sounds like the bearings on the drum shaft are going. this is over $400 for the back half of the outer drum and you have to be a very good mechanic to get it all apart. I currently have mine apart for the same problem which I verified by opening the door of the washer and lifting the inner stainless steel drum up and down with the machine off, of course. The tub is supported by two large ball bearings on the shaft that is supporting the stainless steel drum, and they don't sell just the bearings and seal, only the back half of the drum. If it has gotten bad enough to rub against the front half of the outer tub, it will probably have to be replaced also, about $120. This was probably caused by overloading the washer or washing something that was unbalanced and heavy; this destroys the seal between the inner drum and the heavy bearings, also not available separately, and lets water into the bearings in the aft outer tub which support the inner tub shaft. If you want to try to take this apart to verify, try looking at Whirlpool consumer services technical education group presents #L-68, Job Aid Part No. 8178076. I found it online. It has detailed instructions how to take this machine apart if you are a technician or a talented amateur, as I am. Good luck.
Apr 04, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Loud noise(not jet whirring sound) during rinse & spin cycles.
the rear bearing is bad the bearing is press in to the outer tub the outer tube is like a **** shell you need the rear half and new seals it is a big job if you are going to do it you will need a manul
Dec 02, 2008 | Maytag Neptune MAH5500B Front Load Washer
Loose drum!!!!
inner drum is tightened usually with a bolt thro the main pulley (sometimes a nut) but this is unlikely to be the problem. suspect you bearings have worn.
Apr 24, 2007 | Haier XQG65-8SU Front Load Washer
Washing Machines Logo
85 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
