Question about Garden
Petrol chainsaw wouldn't start, and with trying to get it running the pull cord is very very stiff to pull out and it is now just jurking small sections of the cord out at a time and still will not start
    Brigadier General:
  • 4,088 Answers
Sounds like it may have hydraulic lock--the upper cylinder is full of fuel. Remove the spark plug and pull the engine through a number of times. Make sure the ignition switch is off--it might ignite the expelled fuel. You may find that the crankcase is also full of fuel--continue to pull the starter until there is no raw fuel expelled. Now, why didn't it fire! Probable bad ignition system--check for firing of a clean spark plug (ignition on). If ok, try the original plug, it may need to be cleaned or replaced.
Posted on Jul 04, 2009
    Problem Solver:
  • 16 Answers
I bought a new chainsaw and it wouldnt start because of the above problem. I took out the spark plug and wiped away the fuel around its thread and tip. With the switch in the off position I pulled it through with my thumb mostly over the spark plug housing. I wiped away the excess fuel from my thumb and continued as above until my thumb was dry. Placed the spark plug back and it started first time!
Posted on Sep 16, 2009
Small gas engine won't start
hi u need 3 things for a motor to run spark petrol and compression buy a new plug earth it on the side of the motor with lead on it and pull the cord to check spark///// next pull the cord with youre finger over plug hole to check for compression and last check for petrol in carby it might need a clean ......good luck. .
Sep 17, 2015 | Garden
Ryobi petrol chain saw jammed, prior to this it happeningit was not running on idle so I thought was the problem and tried adjusting the idle screw but it made no difference...undid cowling and put a
I'm not sure what you mean by jammed. If the engine was hard to pull the cord then you probably tripped the chain brake. Most chainsaws all you do is pull back on the hand guard to reset the brake. If you are adjusting the idle you will need to have it running then turn the screw until you have the desired engine rpms.
Feb 12, 2014 | Ryobi Garden
Ozito chainsaw petrol 14 inch bar model
Hi Ed, I had this same problem with my chainsaw when it was new. Once you get it to fire with the choke out push the choke back in but don't pull the trigger. Then try pull starting again and let it run for a few moments to warm up. It should run fine then.
Jan 18, 2014 | Garden
Ryobi pcn 4040 chainsaw won't start What is the
1st add fuel/oil mix to fuel tank , then top off oil tank with bar oil , place saw down on flat surface , press 'ON" button above trigger handle to ON (its marked on case) then pull out blue choke handle till it clicks and stays out , press primer bulb with thumb 8 to 10 times bulb will become harder to press as it fills carb , push chain brake forward (on) ` place left hand on top of saw and right hand on start cord , hold saw down firmly and pull cord vigorsly several times till it sort of starts (sound) , squeeze trigger in and pull cord once more , saw should take off running , chain wont move ,walk to wood pile then disengage the chain brake and cut wood , if saw fails to start after this procedure then there must be a fault in saw , consult a exp small engine dealer for repairs
Sep 01, 2013 | Ryobi 18-inch Electric Chainsaw Chain Saws
After fitting new oil pump on chainsaw,why is it stiff to pull the cord and not start
Hello Richard,
Have you tried it with the spark plug removed just to determine if it is high compression causing tightness?
Before assembly, were you able to turn the oil pump by hand just to ensure it was rotating properly and not binding?
If all else fails, you may be able to download a service manual from the manufacturer by clicking here:
User manuals
Feb 18, 2018 | McCulloch Garden
Can't start the strimmer. It is a petrol strimmer, Partner Colibri. Is there a technique other than pulling the cord? Does it need more than just petrol? would be pleased if you could help. Regards...
Start procedure, switch the ignition switch on, press the primer bulb as many times as it takes to 3/4 fill the bulb, put the choke to the full position,hold the throttle trigger open, crank the engine until it fires once, move the choke to the centre position, crank the engine until it fires up and runs, once warm move the choke to the open position.
Jun 11, 2011 | Garden
Hard to start, new racher455
1) Check plug & gap if that doesn't work try new plug. 2) Try cleaning air filter 3) Clean out main jet 4) Test petrol filter inside tank if dirty fit new one 5) Take plug out & fit inside HT lead & put to head of engine & see if you can see a spark when you pull the cord
Jan 24, 2010 | Husqvarna , No.455 Rancher, 20" Gas -...
New ms230 stihl chainsaw won't start
Sounds like its flooded pull the plug and run pull it a few dozen times to dry it out. then try again
May 26, 2009 | Makita DCS6401 20 20",64cc Chainsaw 2...
Garden Logo
131 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
Marvin
Marvin
