I've never had this problem before with any other dehumidifier, but the house smells terrible even though the basement feels dry with the unit running. Is this something like the air conditioners in cars that smell if you don't alternate air conditioner and blower? This is a new unit and none of the other dehumidifiers have had this problem. What can I do?
SOURCE: Friedrich dehumidifier
Most dehumidifiers have a "Frost Guard" mounted on the condensor coil. If frost accumulates on the condensor coil the frost guard turns the compressor off until the frost melts, then comes back on again. For the dehumidifier to work properly, the surrounding (ambient), temperature must be higher than 65 degress. This temperature allows the moisture in the air to condense on the coils and drip into the reservoir without freezing up on the condensor coil. Also, if the humidity is too low, (below 45%), the same condition will occur. So it will help to keep the parameters in mind when you have this issue.
Thank you for your allowing me to advise you on this issue.
Dave E. (Illeagle)
SOURCE: settings
Typical human comfort leve is in the range of 40 - 60% RH. I'ld go with 60 so I didn't have to empty the bucket so often and less run time means lower electric costs.
SOURCE: My D50C friedrich dehumidifier does not work. It
There are many reasons why a dehumidifier will not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
SOURCE: My D40 runs OK but
No, it's probably not shot. Just may need some adjustments. Below are the common causes of the problem you're having.
1. The humidity extraction level is set to HIGH. Lower it to 32 - 35%
2. Air intake filter is dirty or clogged and needs to be removed and cleaned.
3. Clear air obstruction. Maintain at least 12" of clear air space around the entire unit, while in operation.
4. The ambient air temperature at floor level is between 40 - 60 degrees F. This is particularly true in basement applications. Raise the unit up off the floor, onto a sturdy table, cabinet, etc, that will hold the weight of the unit, plus a full tank of water. The air temp at chest level is warmer than floor level in a basement. Unless, your dehumidifier is what's called a Low Temperature Model (designed for basements) it may be contributing to the problem. Although, based on all the odds, numbers 1 & 2 above, are going to be the culprit.
Hope this helped you to troubleshoot and solve the problem. Please let me know. Thanks.
SOURCE: why does the fan run non stop? the compressor
Depending on the time sequence you have this unit set to run, Fredrich's are designed so that the fan runs almost constantly, to keep the air moving. When it senses a rise in humidity above the level you have it set on, the compressor turns ON and runs until the level of humidity is lowered. This is especially true, if you are operating this unit in continual mode.
Hope this helps you and thanks for choosing FixYa.
