The water will not shut off in the toilet.
Something that you might try is calling a plumber to come to take a look at it. Since they do have the proper training when it comes to fixing toilet problems like this, it would probably benefit you a lot. This would be a lot better than trying to fix it yourself. http://www.louisianaplumbingllc.com/services
Is the water constantly running inside the toilet or leaking from behind. If it is running inside the toilet it is often cause by the valve not being allowed to return to the off position. This could be a result of a bad flush linkage from the foot pedal or handle or it could be that the ball or blade gasket is messed up inside the toilet. If it is leaking behind the toilet that means your water flush module has cracked and must be replaced. Turn the water to the coach off. Disconnect the water line to the rear of the toilet. Remove the nut on each side of the base of the toilet. Take the toilet outside and inspect every component and replace what has failed. It is very basic and simple to repair.
