Question about Mitsubishi Televison & Video
On my big screen top and botttom bows out occassion AND IF YOU TAP BY THE SWITCH PLATE THE SCREEN WILL GO BACK TO NORMAL FOR A LITTLE WHILE! PROBLEM IS GETTING MORE FREQUENT AND WIDER! IS IT WORTH FIXING?
    President:
  • 788 Answers
Your symptoms sound like an intermittent solder connection in the top and bottom pin cushion circuits.
This can be a very simple repair, but, finding the solder connections can be very difficult to see. I recommend that you contact a local servicer and see if you can get a quote over the phone and see how much is may cost.
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. (Two Thumbs Up) If you cant rate this post with the highest rating, then please comment to this post and I will try to help you further.
Posted on Jun 27, 2009
Pitney Bowes FD40 error top cover open
Locate the top cover switch that is apparent stuck in the open position. Fix or bypass it.
Oct 20, 2016 | Pitney Bowes Office Equipment & Supplies
HOW TO DELETE SEQUENCES FROM MY PFAFF AMBITION 2.0 SEWING MACHINE?
The instructions on pg 40 of the manual says to hold the Delete button in for a longer period.
quilt ambition 2 0
http://sewing.patternreview.com/SewingDiscussions/topic/89785
Also found the following comment to a review:
Jo-Ann16 May 2013 at 07:30
"Hello, I have the ambition 1.5, absolutely love it. To switch the font to normal stitching you have to delete or save the sequence. To delete it just tap the little garbage photo and to save tap the heart. With that done you then go back to your stitching tab select a stitch and tap the little garbage bin to erase sequencing and go back to normal stitching."
Mar 06, 2016 | PfaFF Sewing Machines
The right side of our screen keeps going dark, almost black. Once I tapped the side of the tv and it popped back to normal. Sometimes it goes back to normal by itself. It is black most of the time though....
Yes usually fixable unless its the panel goning bad. What if you squeze the panel where the black bar is does that effect it. If so the cabinet is probably bowed. Hope this helps.
May 25, 2011 | Sanyo Televison & Video
Have a p61927 rca 61" big screen - chassis ptk195m2 - picture bows in at top/bottom, color overlaps- thought it was stk730-130 on convergence board but don't see it, is it located on the back of board ?...
I believe that is on the back of the convergence board. What makes you suspect that particular switching regulator out of curiosity? It may very well be, but just wondering how you pinpointed it to that.
Thanks
Tim
Oct 01, 2010 | RCA P61927 61" Rear Projection Television
My screen on my iPhone 3GS has gone big. The
Hi what you need to do Is tap your iPhone screen twice with three fingers,sounds silly I know but will return your screen back to normal x
Apr 25, 2010 | Apple iPhone 3G
Mitsubishi WS-65857
easy easy problem.! simple. bad solder connections on the convergence ic's. they are located on the side of big circuit board with big silver heat sinks attached to them. they will say red,green,blue on circuit board. lift board up and solder. enjoy!!!!
Nov 11, 2009 | Televison & Video
Iphone 3gs the icons are very big and i cannot change them back
I ve had the same issue today and freaked out thinking the phone was crasing. How ever after spending 3 hours trying every thing and aking on the web.
when you double tap the screen it normaly zooms?? yes
use 3 fingure tips to do a double tap!
this will take a sort off large zoom screen lock off and bring the main screen fuctions back inline for you.
please let me know or leave a reply
:0
Jul 28, 2009 | Apple iPhone 3GS Black (16 GB)
Samsung HCM5525W 55inch
This is a convergence problem. It happens to all big screen rear projectors. The convergence output ic's need to be replaced. I would let a repair man do this.
Nov 11, 2008 | Samsung HCM5525W 55" Rear Projection...
On/Off switch will not turn unit on..sunk in
that unit may have the locks open it by screw driver check the power at cord then insert and check ac voltage at fuse if present then check after fuse if not then replace it then check dc voltage across big capacitor if not then check 4 diodes if faulty replace it if dc volt is very low then replace capacitor problem may solved
Oct 23, 2008 | Computers & Internet
Open Questions:
Televison & Video Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
