Question about Olympus FE-190 Digital Camera
Olympus FE-5010 Card cover open error. Card cover is closed. Tried a new battery and new card. It didn't help.
I hv olympus fe 5010 nd problem is "write protect" error sawing .....so how i cn solve it
Posted on Jul 16, 2009
5 Suggested Answers
  • 1382 Answers
SOURCE: card cover open fe 280
You can fix it with a small piece of tape inside the unit where the memory card goes. Just look inside for a sensor or a small button, and try pressing it down yourself. If that works, then maybe a slip of tape over that spot would fool the camera into thinking the cover is closed. If this is not fixing your problem take your camera to Olympus as this problem involves some built in mechanism troubleshooting.
Thank you !!
Posted on Jun 18, 2010
SOURCE: Olympus FE-130
I had the same problem after a little plastic trigger thing fell out of the hole above where it says push to eject. After poking around for a while I took the camera apart (remove 7 screws) which made it much easier to see, with a magnifying glass and lamp, what the problem was. A damaged wire that needed to be connected to something. Only the very end of the wire was visible, inside a small white plastic box thing. The plastic box thing eventually fell apart with my attempts to put in bits of wire of varying shapes. When it came loose I was left with a short stiff bit of wire. I took a strand of copper wire (from an old piece of electrical wire), twisted it so I had a small loop at one end, looped it over the end of the stiff bit of wire, and then curved the rest of the wire (about 3 - 4 cm long) so it was resting on a silver piece of metal just below where the white plastic box had been. Put the cover back on and the camera worked. Needless to say, it won't let me know if I've left the cover off, but then it won't work unless the cover is on, so it doesn't seem to matter. Saved about $100.
Posted on Nov 03, 2007
  • 479 Answers
SOURCE: every time i turn on the camera it say card-cover open
clean the seal around the door... else it is repair
olympusamerica.com/repair
Posted on Jan 20, 2009
SOURCE: Olympus FE-46 shows Card-cover open error. Cover
Hi, I have solved this problem in a Olympus Fe-20 camera. First of all, I will explain the facts of the problem. When closing the cover, inside the camera, there is a switch that get closed. This switch is like a door that opens or closes a electric contact. So when this switch is broken it does not join the contacts, so the camera thnks that the card cover is still open. Taking out some screws of the plastic tap of the touch screen, you will see, the touch screen fixed with a special conector. With a small screw driver take the black part up, and then you will manage to take out te touch screen. Then you have to take out the the board where the touch screen was fixed, taken out some screws , and disconneting the card from a similar conector than the one of the touch screen. So you can take out this board, and see that you have reach the main board of the camera. If you close the card cover, you can see in the main board the switch that opens/closes a contact due to the position of the cover. The switch has 4 welding points. You will have to take it out, by a tin solder. Then put a tin in the left down welding point and fix with a wire to the rigth up welding point. Fix the boarding card with its conector, fix the touch screen with its conector, and try to switch the camera on. If OK, fix everything up. If not, have a look at the contacts welded, that the problem is there. Hope to be helpfull.
Posted on Dec 22, 2010
Olympus FE-46 shows Card-cover open error. Cover is closed.
Oct 26, 2010 | Olympus FE-46 Digital Camera
Card cover open fe 280
Thank you !!
Jun 18, 2010 | Olympus FE-280 Digital Camera
When I remove the card of my olympus fe 5010 and download to pc, when I put it back in the camera it requires formatting
That's because you probably just yanked out the card when you were finished instead of using the "safely remove hardware" icon at the bottom of your screen. Now, the only way to use the card again is to format it in the camera.
Jan 09, 2010 | Olympus FE-5010 12MP Digital Camera with...
My laptop pc cannot find my olympus fe 5010.
Consider NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
Aug 11, 2009 | Olympus FE-210 Digital Camera
Card cover open
The problem you are describing is a problem with a sensor that is on the card cover door. It seems to have failed and needs to be replaced. Following are the instructions to send your camera to Olympus for service.http://olympusamerica.com/cpg_section/cpg_servicerepair.aspOlympus will charge a flat rate repair fee for this product if beyond the one year factory warranty or the warranty is voided. The cost is $124 plus your local sales tax. This covers parts and labor, factory cleaning and diagnostic check, 6 month warranty and the cost of shipping the product back to you is all included in that price.
Jun 11, 2009 | Olympus FE-190 Digital Camera
Card cover open error message...
The problem you are describing is a problem with the sensor on the card cover door It seems to have failed and needs to be replaced. Following are the instructions to send your camera to Olympus for service. http://olympusamerica.com/cpg_section/cpg_servicerepair.asp Olympus will charge a flat rate repair fee for this product if beyond the one year factory warranty or the warranty is voided. The cost is $101.85 plus your local sales tax. This covers parts and labor, factory cleaning and diagnostic check, 6 month warranty and the cost of shipping the product back to you is all included in that price.
Jun 10, 2009 | Olympus Stylus 850SW Digital Camera
Every time i turn on the camera it say card-cover open
Jan 20, 2009 | Olympus FE-310 Digital Camera
Broken battery compartment door switch
The switch is a micro switch that is depressed(and not sad :)) by a plastic tag moulded on the battery cover. Once the cover is moved into position and closed, the tag presses on the micro switch closing the switch and thus removing the error message. As with any switch, a switch is simply open or closed, Open = high resistance or O/L, while closed = 0 ohms reistance. You can use a small wire to overcome the switch by soldering the wire to both tags of the switch so it is permenantly 0 ohms. This will send a message to the microprocessor that cover is closed and camera ready for use. Hope this helps.
Twitcha
Sep 28, 2008 | Olympus FE-140 Digital Camera
Olympus FE-140
Yes I had the same problem, however, where is says "push to eject," it means to push the the memory card down and it will eject. You pushed down the latch for the plastic door cover. Try pushing something into the hole so the camera thinks the door is closed. I am still having trouble with mine. Hope this helps alittle.
Sep 16, 2007 | Olympus FE-140 Digital Camera
Did I break my camera???
u can´t do anything, it´s pretty normal to happen, if it´s under warranty send it to the repair centre and they will repair for free.
Dec 15, 2006 | Olympus FE-100 Digital Camera
Olympus FE-190 Digital Camera Logo
652 people viewed this question
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Jerry Greenberg
Jerry Greenberg
Are you an Olympus Camera Expert? Answer questions, earn points and help others
