Question about Sewing Machines
Hand wheel won't turn
I replaced the belts on my Necchi 535 FA and now the hand wheel won't turn. It's like it's locked in place. The motor hums so I know it's working but won't move anything. The stop motion knob is tight so I don't think that's the problem. Please help. Thanks.
PS - This is one of the good old machines that has no electronics in it whatasoever.
  • mrsvjones Jun 27, 2009
    The belts were replaced because they were threadbare. Can you tell me what the correct position would be for the idler pulley. I am wondering if I have it too tight. How much tension is the right amount on the belts?
  • Paul Howell
    Paul Howell May 11, 2010
    If the belts were loose or removed, would the handwheel still be locked? The 535 has an adjustable idler pulley which may need getting in the optimum position.
  • 208 Answers
The belts needed for this machine are very specific in size, particularly the small one. The wrong belts will not work.
Look carefully at the bracket that holds the pulley. There are two screws that hold it in place. Loosen them slightly and run the machine and the pulley bracket may move on its own to where it needs to be. If not, you must find the right spot where it is tight enough not to slip and not too tight to bind.
Posted on Jun 28, 2009
Necchi 546 how to wind a bobin
This video may be helpful. Not quite your model, but machines generally operate very similarly.
How to thread Necchi model 535 FA sewing machine now with captions
or you can order a manual for your machine:
https://www.sewingpartsonline.com/instruction-manual-brother-home-lock-546.aspx
Apr 11, 2018 | Necchi Sewing Machines
Necci 752 manual is needed.problem with threading and stitching
Hm, I'm not able to locate a manual but may be able to offer some suggestions.
Remove the top thread from the machine.
AVOID OLD OR BARGAIN BIN THREAD!
Use the same thread in top and bobbin.
Be sure to use a brand new needle--needs to be compatible with the thread and fabric of the project..
ALWAYS RAISE the presser foot and rethread from the beginning.
Set the top tension to the midway point.
Verify the bobbin is loaded and threaded correctly and it turns the correct direction.
Pull the bobbin thread up through the fabric before taking the first stitch. It also helps to hold both thread tails in your left hand when taking the first stitches.
Test your machine and tweak the top tension until the top and bobbin threads meet in the middle of the fabric. (Increased top tension will pull the bobbin thread up. Decreased top tension will allow the bobbin thread to pull the top thread down.)
How to Thread Necchi Sewing Machine
How to Thread Necchi 535FA 535 534FB 534 Sewing Machine and Bobbin Case (not your model, but the threading and basic instructions will be similar or the same as your machine)
Mar 18, 2018 | Sewing Machines
How to thread a NECCHI royal series machine 3204FB
How to thread a Necchi model 535 FA sewing machine [now ...
? 8:52
https://www.youtube.com/watch?v=CEGuA6kZG4A
Jan 8, 2012 - Uploaded by Wren Paasch
How to thread a Necchi model 535 fa sewing machine. I'll make a separate video to show how to wind a ...
Necchi 3215 Sewing Machine Demonstration - YouTube
? 0:40
https://www.youtube.com/watch?v=ulo4kvnj3PU
Aug 9, 2011 - Uploaded by GoldCoastSewVac
... explains what the Necchi Heavy Duty Sewing Machine can sew and ... How to thread a Necchi model 535 FA sewing machine [now with ...
How to Thread a Necchi Sewing Machine (with Pictures ...
Dec 14, 2015 | Necchi Sewing Machines
Sorry the needle is not going down,
Needles will not go down for:
1. The lock on the hand wheel isn't locking. Try this
a. Loosen the lock like you're going to wind a bobbin.
b. Loosen screw that is on the side of the lock. (sometimes front)
c. Tighten the lock just like when you're going to sew.
d. Tighten the screw that is on the side of the lock.(sometimes front)
e. Turn hand wheel by hand. Did the needle rise and fall?
2. The drive belt isn't moving the shaft.
a. Remove the top of the sewing machine.
b. You will most likely have to remove the panel on the end where the hand wheel is.
c. Turn your hand wheel to see if the belt is moving the shaft or is it broken?
d. Replace if you need to. (look at wear). Loosen the motor.
e. Make your motor run (foot pedal) slowly. Tighten the belt by pushing on the motor while it is running. When the motor is placed at the right place the motor will be moving with very little drag. (This will need a listening ear)
f. At this point tighten motor and retest for the speed and drag.
Mar 21, 2015 | Sewing Machines
I have a Necchi model 549. I have to hand turn the wheel in order for it to start to stitch then it will run, but as soon as I stop it needs to be hand turned again. it will not sew upholstery or heavy...
I have the same machine and have had a similar problem. My belt was just old though. You need a new belt. And once installed it must be adjusted properly for everything to work correctly. I changed and adjusted mine myself. Although Necchi parts are not available from the company any more, there are several places online that carry belts and a few other items. One is sewingpartsonline.com. The belt shows up under Necchi 541, but it lists compatibility with our machines (549) on the order page. The size belt is 12 5/8"-- with teeth (lug type). While the belt is being changed the shaft that holds the wheel needs to be cleaned and oiled. Also clean up any excess oil in the area with a sewing machine safe cleaning fluid. Clean the plastic wheel with a little dish detergent and water on a paper towel. Oil should not be put, or remain, on any plastic parts in your machine. Not many people want to fix these machines anymore, but I love mine and will probably keep it as long as I can keep it running. Hope you see this post and get your machine running again. Win
Jan 15, 2012 | Necchi Sewing Machines
Necchi Model 535 FA - Replaced drive belt, after running machine for approximately 5 minutes, machine locks down with motor running, motor pully burns plastic belt into.
The motor is running.That is confirmed that motor is fine.But the wires from motor has to be checked.the motor connections are getting short and this is causing the plastic belt to burn.Check the motor as well as its connection.
thanks.
Jun 05, 2010 | Necchi Sewing Machines
I need new belts for my necchi 535 FA. Can you help me?
try to google the manufacturer and place online order
Dec 08, 2009 | Necchi Sewing Machines
Model 575 FA .. Haven't had it open in a long
Take out the bobbin and bobbin case and check round the raceway, chances are you have a small piece of thread stuck
Oct 25, 2009 | Necchi Sewing Machines
Sewing Machines Logo
553 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Are you a Sewing Machine Expert? Answer questions, earn points and help others
