Question about Kodak Cameras
Camera wont turn on tried different battery - Kodak Cameras
Kodax easy share Lens won't open. Need new battery?
Posted on Sep 09, 2009
I have a kodak easysharez612 camera.I try to charge the battery with a different charger and now it wont turn on and the camera gets hot.what could be the problem
If the camera or most likely the batteries are gets hot then the camera is faulty and it is drawing too much power from the batteries.
Apr 11, 2012 | Kodak Cameras
Wont take a photo - wont focus
Assuming it is not a new camera and you do not have it set to manual mode and you know how to operate it appropriately - it could be a broken lens, dirty contacts, frozen firmware, or broken camera. First try turning your camera off - wait at least 15 seconds - then try a different lens. If the camera works with a different lens - then it is your lens. If you do not have a different lens, using a pencil eraser, clean the brass (gold color) contacts that can be found on the lens and camera where they connect. Make sure you do not get any eraser particles in the camera or you will have more problems. Once done turn your camera on. If it works it was dirty contacts. If it still does not work it could just be frozen firmware. Turn the camera off and remove the battery. Then replace the battery and turn the camera on. Remove the batter will get the camera to "reset." If it still does not try uploading the firmware again - preferable with an update if available. If it still does not work it is with the camera - sorry.
Jul 05, 2011 | Canon EOS 550D Rebel T2i Digital Camera
Camera wont turn on.
Make sure that you're using fully charged battery pack.
Remove the battery and reinsert it.
Try using different battery if available use AC adaptor and check..
If the issue persists with different battery, service is required
Jan 01, 2011 | Nikon Coolpix 8400 Digital Camera
MY CAMERA WONT COME ON THE TELESCOPE LENSE WONT GO BACK IN IT DOSNT SEEM TO CHARGE
Please try the following: Don't forget if you're charging though the computer NOT to turn the camera on. 1. Clean the battery contacts. a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth. b. Reinstall the battery/batteries into your camera. Please make sure that you are installing a fresh/ fully charged battery c. Turn the camera on. 2. Without the memory card, turn your camera on. (If it works then it?s your memory card that is faulty) 3. Please test with the a different battery If you do not have access to another battery Try these steps instead: Please take the battery out of the camera. b. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the battery. If you camera doesn?t switch on you will need to order a no power repair with KODAK or a new cable.
Jan 27, 2010 | Kodak EASYSHARE M1063 Digital Camera
Camera shuts off when plugged into computer wont turn on while plugged in trying to put pics on computer
The camera needs battery when connected. Please use lithium batteries Ni-Mh or rechargeable Batteries (2000 M.Amp or higher).
NOTE The cameras LCD screen will remain black throughout the transferre.
If you're experiencing that the computer is not reacting to the camera at all try the following:
Remember you need to turn the camera on when transferring.
Try a different USB outlet
Try a different cable
Try a different computer.
If all fails please contact KODAK in order to arrange a repair or order a new cable. Remember your USB cable is covered under the same warranty as your camera, so remember your serial number when calling:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Jan 27, 2010 | Kodak Easyshare C813 Digital Camera
My camera wont turn on. It has new batteries in it.
try using a different company battery and it may work, my camera had the same prob and wen i used another companys batterys it started working
Jan 11, 2010 | Olympus FE-140 Digital Camera
Camera wont turn on!! help!!
Dear Texaslilly,
Although there is nothing much to do but you can still try the following.
  1. Try with different set of batteries
  2. Remove the memory card from the camera
  3. Cameras generally do have an option to plug-in external power supply..Try with external power supply .. if there is any.
  4. Now this might sound little crazy but no harm in trying .... Remove batteries... Press and hold the power button for few seconds... release the power button ... reinsert the batteries and try to power on without memory card.
Try the above and let me know if it works.
Regards,
Srinivas.
Jun 19, 2009 | Pentax Optio T20 Digital Camera
Camera turns itself off immediately even though it is fully charged
are you using rechargeable batterys or cheap ones
you have to get batteries specifcly designed for digital cameras or they wont power the camera properly.. try using different batteries !!
May 22, 2009 | Kodak Easyshare V1233 12.1MP Digital...
Camera turns on for 2 seconds or wont turn on at all.
There is no hardware reset on this model. We have many situation on different make digital cameras that uses AA batteries that would not turn on with some other AA batteries due to Amp requirement on the batteries. Which means that some circuit design would work only with rechargable batteries because they have more power due to higher Amp power. So I would try rechargable batteries for the last resort. -James
Apr 12, 2009 | Fuji FinePix A820 Digital Camera
Olympus Stylus 770SW Battery Problem
It may be the battery - try using one of your spare batteries, see if that makes a difference.
Jul 10, 2017 | Olympus Cameras
Cameras Logo
73 people viewed this question
Top Kodak Cameras Experts
Jerry Greenberg
Jerry Greenberg
Computer Links
Are you a Kodak Camera Expert? Answer questions, earn points and help others
