Question about Garmin nuvi 260W GPS Receiver
Garmin 260w will not show arrival time but does
Garmin 260w will not show arrival time on bottom right. The box looks like this. _ _ :_ _ Siganals are good and everything else works fine.
rockfixya
  • 679 Answers
SOURCE: GARMIN 260W
Hi It is more important to know how to add POIs. Here is a simple tip:
1. Create some directory especially for download. I use the following one: C:\Garmin_POI_GPS_DATA_TEAM
2. Download and save all CSV and BMP files to that directory. You may create any subdirectory and use it to save POIs for that category.
I use: C:\Garmin_POI_GPS_DATA_TEAM\Restaurants, C:\Garmin_POI_GPS_DATA_TEAM\Petrol etc.
3. Garmin's POI Loader will find all files in these subfolders and will use them to create a category.
Garmin POI Loader will search through the directory C:\Garmin_POI_GPS_DATA_TEAM and will create/transfer all corresponding POIs to your connected GPS.
4. You can remove any POI file simply by removing it from your POI folder. and re-running the POI Loader software. This POI update procedure takes about 1-2 minutes.
In summary, keep your POI files updated on your PC and run POI Loader to update your GPS or SD card via any SD card reader.
Cheers
Posted on Feb 13, 2009
the kowalski
  • 86 Answers
SOURCE: I would like to register
You can register your GPS on www.myGarmin.com if it's a brand new unit. If someone else have registred it first (i.e. bought on eBay or similar), it could be a bit of a hazzle however.
Posted on Jun 02, 2009
HarryHarley
  • 343 Answers
SOURCE: nuvi 260w no power.
Yes, you need to charge it. USE the charger that came with it for best results. Some off brand chargers will NOT work.
You plugged it into your car and nothing? Even if the batteries are bad it should still work. Is it the Garmin charger?
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} If your unit will not charge in your vehicle, you may need to replace the fuse located in the tip of the vehicle power adapter.
  1. Unscrew and remove the silver or black, round end piece.
  1. Remove the fuse (glass and sliver cylinder) and replace with a new fuse.
  2. Ensure that the silver tip is placed in the end piece. Screw on the end piece.
Posted on Jan 13, 2010
HarryHarley
  • 343 Answers
SOURCE: garmin 260w no sound just purchased
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} If you are not receiving any sound on your Nüvi 2xx the first thing to check is that the sound is not muted. To ensure that your units sound is not muted please perform the following:
  1. Turn the device on
  2. Press the Volume button on the ‘Where To?’, ‘View Map’ screen
  3. Ensure the Mute box is not ‘checked’
If the mute button is not ‘ticked’, you will need to change the voice to ensure that the preset voice is not faulty:
  2. Touch the Tool icon
  3. Touch Settings
  4. Touch Language
  5. Touch the language voice next to Voice
  6. Scroll through and select another appropriate voice
If changing the voice is not helping you will need to ensure that you are running the latest software which can be done by installing a program called WebUpdater. WebUpdater can be installed via the link below:
http://www8.garmin.com/support/collection.jsp?product=999-99999-27
Once updated please allow the unit to reboot which will ensure the software successfully installs.
If after following all the above the final steps would be to perform a master reset:
Note: A master reset will erase all waypoints or favorites and will restore your unit to the default factory settings.
  1. Start with the unit OFF and unplugged from power
  2. Touch and hold the lower right corner of the screen with an index finger or the eraser end of a pencil
  3. Continue touching and holding the lower right hand corner of the screen then power the unit ON
  4. Release the power button when the device powers on. After 5-10 seconds you will see a new message: Do you really want to erase all user data?
  5. Remove your finger from the touchscreen when this message displays
  6. Touch Yes
The device will automatically reset. Please follow the on screen prompts on the nuvi and when completed place your device in an area with a clear view of the sky until it acquires satellites.
HarryHarley
  • 343 Answers
SOURCE: I game my parents a garmin 260w with just the car charger.
I would only us the Garmin charger. Why take a chance. They are fairly cheap. Plus you need the car charger since that's where you use it most of the time. The batteries don't last all that long.
Posted on Jan 18, 2010
Garmin nuvi 50lm only shows garmin screen and just a bit of green on the bottom. sometimes it shows the green register bar all the way accross
Garmin nuvi 50LM Boot problem ' POI Factory
www.poi-factory.com > Garmin talk
Aug 11, 2012 - Why won't my nuvi 30, 40, or 50 go past the Garmin logo screen when I turn it on? .... Just wanted to say thanks to Muell9K for the hard reset solution. ... get the Nuvi to start up with the screen that shows the picture of a Garmin ...
Crap... White Screen (nuvi 350)
May 11, 2008
garmin frozen?? (how do I reset?)
May 11, 2008
More results from www.poi-factory.com
How to Reset the Garmin nuvi 30, 40 and 50 with GPS City ...
? 0:51
https://www.youtube.com/watch?v=mujdSP-fM98
Jul 31, 2012 - Uploaded by GPSCity
In this video learn how to RESET the Garmin nuvi 30, 40, and 50GPS back to factory default settings. Back up all ... With the GPS unit off, press the bottom right hand corner of the screen. Turn the unit ... Show more. Show less.
Jan 05, 2016 | Garmin Nuvi 200w 250w 260w 580 660 670 680...
My 260w has a screen lock and it has no reset button! what's the fix?
To reset the Garmin satnav you power on while holding the bottom right corner of the screen until it asks if you want to reset it.
Jun 12, 2011 | Garmin nuvi 260W GPS Receiver
Does Garmin nüvi 260W show
Yes, but not on the same screen
Dec 04, 2010 | Garmin nuvi 260W GPS Receiver
Can you check or varify your speed with garmin nuvi 255w
Yes, your mph shows up on the bottom left box, your estimated arrival time on the right...and if you're on a major highway, the posted speed limit will show up all the way on the left side. Hope this helps!
Dec 03, 2010 | Garmin nuvi 255W GPS Receiver
Cannot save direcctions to my gharmin 260w
Unfortunately the Garmin Nuvi 260W lacks the capability to save a route. If you are looking for a unit with great Trip Planning (route saving) features, the new Garmin Nuvi 3790T is a great option. I am currently using one and I love it.
Cheers
Jul 14, 2010 | Garmin nuvi 260W GPS Receiver
Have Garmin Nvui 260w that has lost it maps. earlier purchased mapdates and hasn'b been the same. shows Garmin and computer on sceen.
GO INTO SETTINGS
THEN MAPS
THEN MAP INFO ,
MAKE SURE THE "TICK" IS IN THE BOX OF THE MAPS YOU WANT TO USE
IF THAT FAIL'S THE THE DOWNLOAD DID NOT TAKE, IF SHOWING COMPUTOR ON SCREEN STILL, THEN RESET, EITHER THE RESET BUTTON ON THE BASE, (PUSH) OR HOLD/PRESS BOTTOM RIGHT CORNER OF SCREEN WHEN POWERING ON AND WAIT, THEN RELEASE PRESSURE TO HARD RESET
Dec 29, 2009 | Garmin nuvi 260W GPS Receiver
My 260 is way off on time of arrival by many hours.
When was the last time you updated the GPS firmware?
Sounds like that is the problem.
Jul 02, 2009 | Garmin nuvi 260W GPS Receiver
Nuvi 260 won't turn on at all.
Had the same problem with my Garmin Nuvi 260w. It just needed to be reset. Lift up the sticker strip on the bottom of the unit and press the reset tab. Worked like a charm for me. HTH!
Jun 13, 2009 | Garmin nuvi 260W GPS Receiver
MY GARMIN 260 gps gives wrong information on non existing rounderbouts on highway,freeway ramps,and destinations, showed arrival flag and map when 40 ks away from town
there is 2 things u can do... either try and reset the gps .. normally its by holding the power button down. or have u tried up dating your maps.. to do this u will have to jump on to the garmin web site and purchade from them... i know alot of ppl have trouble with garmin, i find that navman is the best :)
Mar 25, 2009 | Garmin nuvi 260W GPS Receiver
Nuvi 260w no power.
Dec 26, 2008 | Garmin nuvi 260W GPS Receiver
Garmin nuvi 260W GPS Receiver Logo
94 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
