Question about Frigidaire Washing Machines
Recently had the door lock replaced on our 2yr. old Frigidaire front loading washing machine for around $270.00. Now the machine intermittently goes off and on and then goes completely dead. If we unplug it for multiple days, it will restart, but then eventually goes dead again. Is it worth it to put more money into this machine? (Called multiple repair people and it looks like it will cost me at least another $120.00 just to get the diagnosis with additional unknown costs for repair.) Thx so much!
  • 10,515 Answers
There might be 6 reasons for the same :-
1. Condenser Coils
2. Outlet Voltage
3. Condenser Fan
4. Compressor Relay
5. Overload Protector
6. Compressor Motor.
No doubt, as it only 2 yrs old, However, it would cost you 120 bucks only for diagnosis.It's not a wise Idea to spend more. Do it yourself.Diagnose yourself, it might be a small fix. I am ready to help you in all way.
1. Condenser Coils :- Check the below mentioned link to have a complete guideline :-
http://www.acmehowto.com/howto/appliance/refrigerator/check/condensorcoils.php
2. Outlet Voltage :- Check the below guideline :-
http://www.acmehowto.com/howto/homemaintenance/electrical/outletvoltage.php
3. Condenser Fan :- Check the below guideline for Condenser Fan :-
http://www.acmehowto.com/howto/appliance/refrigerator/check/condensorfan.php
4. Compressor Relay :- Guideline would be :-
http://www.acmehowto.com/howto/appliance/refrigerator/check/compressorrelay.php
5. Overload Protector :- Guideline would be :-
http://www.acmehowto.com/howto/appliance/refrigerator/check/overload.php
6. Compressor Motor :- Guideline is :-
http://www.acmehowto.com/howto/appliance/refrigerator/check/compressor.php
IF POSSIBLE CHECK YOURSELF, IF THAT'S COMPRESSOR, IT USUALLY HAVE 5 YEARS OF WARRANTY.GET IT REPLACE WITHOUT ANY CHARGE. THERE IS NO POINT OF PAYING 120 BUCKS FOR DIAGNOSIS AND LATER FIND THAT YOU NEED TO SPEND 200 MORE BUCKS. THAT DOESN'T MAKE ANY SENSE.
It might be an issue with Control Board. In that case, better to invest in New One.
Check yourself, If by cleaning coils you can get it fixed it's great. Unless, if that's compressor, get it replaced without any charge.
If there is some other issue you might determine of all the above mentioned, its Control Board.Better buy a New Machine then spending 300 more bucks.
Hope i helped you.
Thanks for using "Fixya".
Posted on Jun 27, 2009
My Electrolux front load will not lock. I close the door and the light goes out but will not lock. The washer is around a year old.
Sounds like the door latch assembly strike is not catching correctly and not telling the sensor the door is shut properly. Contact Frigidaire to see if you have any limited warranty on such a concern and then schedule a professional.
Sep 03, 2012 | Electrolux EW1000i Front Load Washer
I have a frigidaire front load washer that gave me a error 47 code. what can that be.
The circuit thinks the unit is in spin cycle - Remove the door lock assembly and measure the resistance of the PTC. Shorted or open, defective door lock assembly. Reads around 1500 ohms, defective Main Control Board.
Aug 19, 2012 | Frigidaire ATF6000ES Front Load Washer
The front door will not lock and pau is flashing on my frigidaire affinity front end loading washing machine and it will not start
You will need to replace your door lock mech.
On the bottom of the door seal lift the edge and locate the retainer spring and remove the spring then remove the door boot,unscrew the door lock disconnect the wirng and replace the door lock mech
Oct 07, 2011 | Frigidaire Affinity ATF7000E Front Load...
I have a Affinity frigidaire front load washer and need to replace part number 131763202. The model number of the washer is ATF6000FS1 Thank you in advance
Disconnect power then open the door and remove the spring-hoop assembly that secures the door gasket. Peel off the part of the door gasket near the door lock and switch assembly. Remove the screws securing the door lock and switch assembly to the front panel then pull the door lock and switch assembly out. Transfer the wires to the new door lock and switch assembly then install into place. Put the door gasket back and secure it with the spring-hoop assembly. Click on the link below for the detailed procedure.
Replacing the Door Lock and Switch Assembly on Frigidaire Affinity and Gallery Front-Load Washing Machine
Nov 12, 2010 | Frigidaire ATF6000ES Front Load Washer
2yr old daughter hit some buttons now it won't - pau 33 pau 33
did you get this fixed? how? my 2 year old son did same thing.
Dec 13, 2009 | Frigidaire ATF6000ES Front Load Washer
Accessing the door lock switch
spring clamp around boot (spring at bottom) pop off with screwdriver, pull boot off groove.
Mar 16, 2009 | Frigidaire ATF6000ES Front Load Washer
My Frigidaire affinity washer doesn't start: the "door locked" button doesn't come on though the door is closed properly
If the washer fills with water, but will not start the wash cycle or spin, it is 1 of to things. the most common for frigidaire front load affinitys is the door lock assembly. I have had to replace numerous of these. if the door lock indicator is not on when it tries to wash, you need to replace the door lock assembly. if the door lock indicator is on, but wont wash, it is likly that you have a bad motor control board.
Dec 01, 2008 | Frigidaire Affinity ATF7000ES Front Load...
Frigidaire front load washer
I had the same problem. The service tech came out and replaced the pump, it has been working fine ever since. I couldn't believe the pump went out in only a couple of years.
Jul 06, 2008 | Frigidaire ATF6000ES Front Load Washer
Frigidair front-loader washer door remains locked
there is an Emergancy release you can pull to open the door it is either in the soap dispenser area or behind the front lint clean out door depending on your model
Mar 30, 2008 | Frigidaire ATF6000ES Front Load Washer
Washing Machines Logo
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
