PICTURE IN PICTURE (PIP)
NO MATTER WHAT I DO
I CAN'T GET THE PIP SETTING TO COME ON
I'VE EVEN USED FACTORY RESET AND STILL
NOTHING, COULD IT BE FAULTY?
  • 1 more comment
  • Anonymous Dec 14, 2007
    From the menu selecting picture and PIP it shows it as being OFF. There is no selection between ON and OFF. If you press the PIP button the remote control the screen displays UNAVAILABLE. This is rediculous as the Owner's Instructions manual of the LE26R72B shows you how to select it. The manual does not state that there are exceptions when not available.
  • Anonymous May 25, 2008
    pulso PIP y solo me sale una ventana completamente en negro y como no tengo el manual de intrucciones no se como hacerlo para que se vea la imagen
  • BOOBOOfrog Jun 16, 2008
    I do not have a maual for this TV could e-mail me one please?
    janetdbuck@charter.net I will be very greatfull.
    this a second hand TV The only thing I did was press pip button and then try to change channel its like there not something not hook up. If you can
    mail one Janet Buck-2809 Pecan St., Columbus Ga. 31906
I have an LN46C630 with a hi-def satellite receiver.The tv must be set in hdmi mode then the PIP can be used by going into MENU then SETUP.Hopes this helps.
Posted on Sep 22, 2010
High this setting is only active if power save mode is set to off
Posted on Apr 30, 2008
Samsung say;
The feature only works on the AV/PC channels and not on a single tuner (digital or analogue) and only if your AV source (Sky Box/Freeview/Dvd ect.) is connected to the TV by way of the RGB or HDMI connections.
Good Luck
Posted on Feb 29, 2008
Picture count stays on 9999
reset to factory setting, after do this set numbering to "by month"
hope this will solve your problem
Jun 29, 2014 | Canon EOS 1100D / Rebel T3 Digital Camera
The pip got stuck using a universal remote..i cannot clear it no matter what button I use
If you can access the Menu options with your present universal remote, get into it, and surf thorugh picture adjustment and PIP adjustment screen, and set the PIP option to OFF. If you can't access the Menu option with your present remote control, there is no other way to do this without its original remote control.
Apr 06, 2012 | Panasonic CT-36D32 36" TV
How to reset sony kv27V42 to factory settings ?
There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts.
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
Sep 22, 2017 | Sony KV-27S42 27" TV
Please tell me lg factroy setting codd
Hello
I don't understand your post. About what settings you wants to get it to its factory settings or its lost password problem!. If the password probelm,
If you ever forget your password, key in '7', '7', '7', '7' on the remote control
If picture settings must be set to factory settings do the following.
Reset is unique to each function: Manual config., Position, Split zoom, PIP position
and sub picture size for double window.
- Use the Reset option to initialize the adjusted settings.
Press the MENU button and then use [up/down] button to select the SCREEN menu.
2. Press the [=>] button and then use [up/down]button to select Reset.
3. Press the [=>] button.
• You can initialize Position, Split zoom, PIP Transparency, PIP position, PIP size
OK.
Mar 15, 2011 | LG RU-42PX10 42 in. HD-Ready Plasma...
Zoomed out Picture
button 19
ASPECT Cycles through Wide mode settings:
NORMAL/FULL/WIDE/ZOOM.
PIP Turns PIP/POP on and off.
Mar 25, 2010 | Polaroid FLM-2632 Television
53UDX10B
Good Day, peterferd;
Try resetting the TV by unplugging from A/C outlet wait 3 to 5 minutes then plug back in. No fix? Call service company.
Good Luck, big IRISH.
Apr 16, 2008 | Hitachi 53UDX10B 53" Rear Projection...
PIP
Look for a "PIP" (Picture In Picture) button on the remote or in the TV's menu. I suspect that it has been pushed but there is not a second source to view. That would explain the smaller version in the corner.
Apr 08, 2008 | Vizio GV42L 42 in. LCD Television
Panasonic tv ct-27sf37b
Hi!
Please check the troubleshooting chart of the manual.
Hope it will help!
https://manualsbrain.com/en/manuals/1430640/?page=29
Aug 09, 2017 | Panasonic Televison & Video
I can not get picture in picture off screen
if your sony don't have pip buttn. that tells your sony don't have pip board installed , i am afraid the pip comes out of the source you are getting the video signal sometimes your sat dvb dvd have pip in its menu check it out plz regards
May 02, 2007 | Sony KV-32S26 32" TV
Panasonic CT-36SL13 Can't select video inputs
On a Panasonic to do a factory reset while the set is on press in on the power and action buttons on the front of the TV at the same time. In a few seconds the screen shouls go blank and come up with a screen that says "CHK" in the upper left hand corner. Once it does that press the action button again to clear the screen. You have now reset the TV to factory settings and will have to re-program the channel memory once again. Hope that works...
Apr 23, 2007 | Panasonic CT-36SL13 32" TV
Televison & Video Logo
582 people viewed this question
Top Televison & Video Experts
