Question about GCC Technologies Elite XL 1208S Laser Printer
Unit has started putting 4 lines down polyester plate invisible to eye but prints when plate inked. have replaced cartridge and still same problem???
    President:
  • 1,383 Answers
Clean dust and ink powder from printer .
ASlo clean it from ink cartridge position.
Posted on Jun 27, 2009
Leaving black streaks down paper? Ink cartridge
If this started after cartridge was replaced, then it is probably defective.
Take the cartridge out and take a look at the print head. Clean the print head.
Put the cartridge back in
Try and feed paper (not printing anything on it, if you can not get it to just feed paper, print a blank page) and see if it still has lines. If so, you are probably going to have to clean ink from inside the paper feed area. If not, try using it for a while and if it starts again, get a replacement cartridge. You might want to save some of the bad prints to show the clerk and try to get the new cartridge under warranty.
Mar 18, 2010 | IBM Infoprint 1612 Express Printer
My black ink does not work. I have put 2 new
please clean the heads of your black cartridge also the scanner or sensor for cartridges this can cause to black cartridge not to print.
Aug 19, 2009 | HP Photosmart C6180 All-In-One InkJet...
HP Photosmart 7760 wierd colours and white lines
In this case I would suggest you to clean the cartridges of the printer.
Cleaning the ink cartridges with the HP Printer Toolbox
  1. Click Start .
  2. Click Settings .
  3. Click Printers .
  4. Right-click the icon of the printer in use.
  5. Click Properties .
  6. Click the Services tab.
  7. Click Open the HP Photosmart Toolbox or Service this device.
  8. Click the Device Services tab. This tab does not display in Windows XP; proceed to the next step.
  9. Click Clean the Print Cartridges .
  10. Follow the onscreen prompts.
Manually cleaning the ink cartridges
  1. Turn the printer on and lift the top cover.
  2. After the ink cartridges have moved to the center of the printer, unplug the power cord from the back of the printer.
  3. Remove the ink cartridges and place them wide side down on a piece of paper.
  4. Prepare a clean, foam-rubber swab or a lint-free cloth slightly dampened with water.
  5. Locate the copper-colored circuitry strip on the back of each cartridge.
  6. Clean the copper-colored strip with the dampened swab or cloth. Do not wipe the nozzle end of the cartridge or touch the nozzle plate.
  7. Clean the carriage contacts on the back wall of the ink cartridge carriage with a damp foam-rubber swab or lint-free cloth. Use a dry foam-rubber swab or a lint-free cloth to remove moisture from the contacts.
Cleaning the ink cartridge cradle
  1. Assume an eye level position with the HP Photosmart printer.
  2. Locate the ink cartridge cradle.
  3. Using clean, moistened swabs, wipe the underside of each wall of the carriage where fibers may collect and come in contact with the paper. Repeat until no ink residue is seen on a clean swab.
  4. Reconnect power cord when finished cleaning.
  5. When finished cleaning the ink cartridges and the cradle, print a test page.
Aug 03, 2009 | HP Office Equipment & Supplies
Lines in the print
Nozzle check perfect? No ink drop outside lines? Cyan lines is random position. Print blank pages. It is still appear cyan lines? If yes, it caused by waste ink at bottom plate. Print blank pages more, it will clean itself.
Jun 29, 2009 | Epson Stylus CX9400 Photo Printer
Wrong cartridges error
Printer cartridge is damage replace it
May 29, 2009 | HP Photosmart C5180 All-In-One InkJet...
Black Horizontal lines
hi!
Horizontal white lines usually indicate the ink cartridge is running out of ink or has some clogged ink nozzles. Try the following steps:
  1. Some of the ink cartridge ink nozzles may be clogged with dry ink. Use the ink cartridge cleaning service to try to clear them. Follow the steps below:
    1. check if there is plain white paper in the Input tray.
    2. Press Setup .
    3. Press < or >to select Tools and then press OK .
    4. Press < or > to select Clean Print Cartridge and then press OK . The unit prints a test page.
    5. Examine the test page. If the print quality of the page is good, stop here. If the print quality appears to be getting better, run the Clean Print Cartridge utility again
  2. If the self test appears better, Increase the copy quality setting (Normal or Best) and try copying again. If the quality is still poor, continue to the next step.
  3. If the quality is still poor, one or more of the cartridges may be low on ink or empty. Follow the steps below to check the ink levels.
    1. Open HP Solution Center .
    2. Click Settings .
    3. Click Print Settings .
    4. Click Printer Toolbox .
    5. Click the Estimated Ink Levels tab.
    6. Replace any ink cartridge that is low on ink.
  4. If the ink levels are not low, clean the cartridge face and electrical contacts at the back of the print carriage.
    1. Open the front of the unit to access the ink cartridges.
    2. After the ink cartridges are at the center, unplug the power cord from the back of the unit, and remove the ink cartridges. The power cord must be removed to ensure that the unit is not damaged during the cleaning process.
    3. Clean the cross-hatched area of the ink cartridge with a soft clean cloth that is slightly dampened with clean water to remove any build up. Avoid cleaning the ink cartridge nozzle plate. Cleaning this area can force foreign matter into the ink nozzles and plug them
    4. With a soft lint free cloth slightly dampened with clean water, clean the copper-colored contacts on the back of the ink cartridges.
    5. Allow the cartridges to dry before reinserting them.
    6. Close the unit, and plug the power cord back in.
    7. Print a self-test page to check the results. Follow the steps below to print a self-test page.
      1. Press Setup .
      2. Press <or > until Print Report displays and then press OK .
      3. Press < or > until Self-Test Report displays and then press OK . The self-test report prints.
    8. If the problem is not corrected by cleaning the ink cartridges, replace the ink cartridge(s).
- hope it will help to resolve you problem...
Jul 14, 2008 | HP OfficeJet 6210 All-In-One InkJet...
Ink problem
I had the same problem. This is what The Geek Squad recommended:
1) Make sure your ink cartridge isn't low.
2) Go to Setup on the printer, choose Tools, then choose Clean Print Cartridges
3) Then, go back to Tools and choose Align Print Cartridges
This worked for me -- good luck
Jul 12, 2008 | HP PSC 2355 All-In-One InkJet Printer
Epson stylus cx4400 printer
This for the CX5400 which is similar with its menu system:
Using the Control Panel Follow the steps below to replace an ink cartridge.
r_1.gif Make sure this product is on and the On light is not flashing.
When the ink is low:
Press one of the Menu buttons until Change Cartridge appears on the LCD panel, and then press the fontx1.gif Color Copy button. The ink cartridges move to the replacement position. r_3.gif Make sure that the document cover is closed, and then raise the scanner unit.
a8101037.gif r_space.gif r_caut.gif Caution: r_space.gif r_space.gif
  • Do not raise the scanner unit with the document cover opened.
  • Do not move the print head by hand. Doing so may damage this product.
  • Do not start replacing the ink cartridge before the print head stops.
r_4.gif For best results, shake a new ink cartridge four or five times, then remove it from its the package.
a8102006.gif r_5.gif Pinch the sides of the ink cartridge that you want to replace. Lift the cartridge out of this product and dispose of it properly. Do not take the used cartridge apart or try to refill it.
a8101049.gif r_space.gif r_warn.gif Warning: r_space.gif r_space.gif Be careful when you are handling used ink cartridges, as there may be some ink around the ink supply port. If ink gets on your skin, wash the area thoroughly with soap and water. If ink gets into your eyes, flush them immediately with water. If discomfort or vision problems remain after thorough flushing, see a doctor immediately.
r_space.gif r_caut.gif Caution: r_space.gif r_space.gif Be sure to always install an ink cartridge into this product immediately following the removal of an old ink cartridge. If the ink cartridge is not installed promptly, the print head may dry out rendering it unable to print.
r_6.gif Place the ink cartridge vertically into the cartridge holder. Push the ink cartridge down until it clicks into place.
a8101051.gif If you need to replace other ink cartridges, repeat steps 4 through 6 before continuing with step 7. r_7.gif Lower the scanner unit.
a8101039.gif The print head moves and ink charging begins. The On light flashes while ink charging is in progress. When the On light stops flashing, ink charging is completed.
Jun 14, 2008 | Epson Stylus CX6600 All-In-One InkJet...
Horizontal colored lines through grayscale printed photos
Hi George,
It sound's like an ink-feed issue:
1) Dirty heads, even after cleaning
2) No-ink or poor quality ink
3) Damaged head: some are part of the cartridge, some are not
4) Air bubbles in ink
The test page is typically not as hi-res nor as saturated as a
photo print. The hi-res photo puts the greatest demand on the print head.
The color lines you see are actually lines of missing color,
where the head has failed to deposit ink, so one or two primary
colors are missing from the complete picture.
For example missing yellow will make a blue line.
Missing magenta will make a green line
Missing cyan will make a red line.... etc..
Clean the heads again and again, print again and again,
hoping to flush the system.
BUT, keep in mind that cleaning wastes huge amounts of
ink and tiny little cartridges of ink cost more than many new printers.
Martin
Apr 24, 2008 | Canon PIXMA iP90 Mobile Printer
My printed and copied pictures have horozontal lines
White lines through copies White lines can appear on a copy in either a horizontal or vertical direction. How the white line appears on the copy will determine the cause and solution. Horizontal lines Horizontal white lines usually indicate the ink cartridge is running out of ink or has some clogged ink nozzles. Try the following steps: 1. Some of the ink cartridge ink nozzles may be clogged with dry ink. Use the ink cartridge cleaning service to try to clear them. Follow the steps below: 1. Verify that there is plain white paper in the Input tray. 2. Press Setup. 3. Press or to select Tools and then press OK. 4. Press or to select Clean Print Cartridge and then press OK. The unit prints a test page. 5. Examine the test page. If the print quality of the page is good, stop here. If the print quality appears to be getting better, run the Clean Print Cartridge utility again 2. If the self test appears better, Increase the copy quality setting (Normal or Best) and try copying again. If the quality is still poor, continue to the next step. 3. If the quality is still poor, one or more of the cartridges may be low on ink or empty. Follow the steps below to check the ink levels. 1. Open HP Solution Center. 2. Click Settings. 3. Click Print Settings. 4. Click Printer Toolbox. 5. Click the Estimated Ink Levels tab. Figure 1: Estimated ink levels - both cartridges low NOTE: You can also open the Printer Toolbox from the Print Properties dialog box. In the Print Properties dialog box, click the Features tab and then click Printer Services button then click the Estimated Ink Levels tab. 6. Replace any ink cartridge that is low on ink. 4. If the ink levels are not low, clean the cartridge face and electrical contacts at the back of the print carriage. 1. Open the front of the unit to access the ink cartridges. 2. After the ink cartridges are at the center, unplug the power cord from the back of the unit, and remove the ink cartridges. The power cord must be removed to ensure that the unit is not damaged during the cleaning process. 3. Clean the cross-hatched area of the ink cartridge with a soft clean cloth that is slightly dampened with clean water to remove any build up. Avoid cleaning the ink cartridge nozzle plate. Cleaning this area can force foreign matter into the ink nozzles and plug them. Figure 2: Cleaning the ink cartridge 1 - Clean in the cross-hatched area only 2 - Do not touch the nozzle plate 3 - Clean the copper-colored contacts 4. With a soft lint free cloth slightly dampened with clean water, clean the copper-colored contacts on the back of the ink cartridges. 5. Allow the cartridges to dry before reinserting them. 6. Close the unit, and plug the power cord back in. 7. Print a self-test page to check the results. Follow the steps below to print a self-test page. 1. Press Setup. 2. Press or until Print Report displays and then press OK. 3. Press or until Self-Test Report displays and then press OK. The self-test report prints. 5. If the problem is not corrected by cleaning the ink cartridges, replace the ink cartridge(s). Vertical lines Vertical white lines usually indicate the scanner did not calibrate correctly. This can be caused by debris on the scanner glass or white reference pad. Try the following steps: 1. Turn off the HP all-in-one product and unplug the power cord. 2. Open the document cover to access the scanner glass. 3. Using a non abrasive glass cleaner, thoroughly clean the scanner/copier glass, and white lid backing on the inside of the top cover. CAUTION: Spray the cleaner onto the cloth. Never spray fluids directly onto the HP all-in-one product. 4. Plug in the power cord and turn on the HP all-in-one. Let me know what happens, Good Luck, Tim
Mar 14, 2007 | HP PSC 1315 All-In-One InkJet Printer
GCC Technologies Elite XL 1208S Laser Printer Logo
27 people viewed this question
Top GCC Technologies Office Equipment & Supplies Experts
k24674
jasbo
jasbo
Are you a GCC Technologies Office Equipment and Supply Expert? Answer questions, earn points and help others
