Good Afternoon Friend,
I understand you want to know how to fix a bad defrost control timer on your Frigidaire freezer, model# FFU14FK1CW. Typically, this is not a do it yourself repair, as there are no step by step instruction manuals. I suggest contacting your local authorized technician for further assistance. They have been trained on your appliance and should be able to fix the defrost control timer with ease. Hope this is helpful.
-Best Regards-
WP
SOURCE: where is the defrost timer located Frigidaire
Part 23 on this diagram is a defrost timer. It's behind the kick panel at the bottom. Since your model number was incomplete this may not be yours. Look at the second link for other model number choices.
http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=FRS26WGHD0&productCategoryId=0165000&brandId=1428&modelName=FRIGIDAIRE/REFRIGERATOR---P5995319877&diagramPageId=00006&componentDescription=CONTROLS&documentId=Y2705410&blt=06
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=+FRS26wgh
Hello friend, thank you for your post!
From what you have described you are having a problem with your Frigidaire freezer not shutting off and you feel it may be due to a defrost timer. This issue you are seeing could be a problem with your timer or thermostat. You might want to perform a reset on your freezer and you can do that by disconnecting the power cord from it for roughly ten minutes. If that does not help resolve your issue you might want to have a professional technician out to perform a diagnosis and repair. I hope this is helpful. -Matt
