Question about Standard (CRT) Televisions
Sony Trinitron KV35V35 picture blinks off and on
TV was made 11/96 Sony Trinitron KV 35V35 it takes longer for picture to come on then normal, it blinks off and on constantly, sound works all the time.I Adjusted screen knob on a circuit board mounted to the back of the picture tube. Problem did go away for a few hours, but is now back. Color is off as well. Is this worth fixing, or is set too old??? The circuit board with the screen adjusting control has some light brown spots in areas that are labled, blue, red,... Could this curcuit board be the problem, and if so, what is this board called? Is it hard to replace? Any assistance is greatly appreicated.
Thank you,
  • 1,694 Answers
Re: Sony Trinitron KV35V35 picture blinks off and on
Classic bad CRT = sorry, not worth fixing.......T
Posted on Nov 07, 2007
0 characters
3 Points
Sony trinitron kv 32fx68e has 14 blinks. So to switch it on you have to try 20 to 30 times. What can be the problem. Thanks
sony trinitron kv 32fx68e has 14 blinks light. that"s mention tv have bad picture tube. replace it . good luck!
Sep 22, 2012 | Sony FD Trinitron KV-32HV600 32" TV
Air conditioning technician made a wrong connection in my house so he sent 220v through the regular outlet instead of 110v. this caused to blown out the main board on my tv. Its there any chance i can find...
If you can't find one, it won't be of any consequence, the electrician will buy you a replacement.
Why not repair the power supply in your set?
Jan 01, 2011 | Sony KV-35V35 TV
Sony Trinitron TV
read the answer on this page really helpfull
Apr 01, 2010 | Sony FD Trinitron WEGA KV-27FV17 27" TV
Hi...I have a problem with my Sony Trinitron 29
the power supply section should be resoldered....must be loose power section...
Jan 26, 2010 | Sony FD Trinitron WEGA KV-29LS35 29" TV
Sony KV-32FX68U problem, blinking power light
Please update this with the count of hte blinks. This is a diagnostic code that will indicate the problem circuit. From that we can tell you probable solutions and their costs.
Sep 28, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony trinitron kv-36fv26 (2000) tv wont show picture
Trires unplug,replug about an hour later see if it reset it self.Not take to the shop the two power ICs help the power it dead.Need it replaced.
Jan 27, 2009 | Sony FD Trinitron WEGA KV-36FV27 36" TV
Blinking Sony Trinitron with no picture or sound
you have a drive ic problem. ic 600, r640 and modification needs to be performed. Take to a Sony servicer. Est.$150 parts and labor
Dec 30, 2008 | Sony FD Trinitron WEGA KV-24FS100 24" TV
Could be a weak Picture tube . You can try turning up the screen control but don't turn it up too much you'll get retrace lines in the picture . Turn it alittle at time until picture comes on then turn it down until the retrace lines go away . Then try turning the tv on and off to make sure it comes back on. Be careful you can get shocked if you do this while it is on and you touch one of the circuits . The control is on the flyback or the module thats on the picture tube it will say screen by it . If this does not work you could have vidoe problems or just the picture is no good . Good luck
Jan 20, 2008 | Sony KV-35V35 TV
Sony trinitron kv35v35
Tell Tail sign of a bad picture tube!! How is the color? Does the picture stay on at some point? Don
Aug 14, 2007 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Standard (CRT) Televisions Logo
1,330 people viewed this question
Top Standard (CRT) Televisions Experts
matt martin
matt martin
Are you a Standard (CRT) Television Expert? Answer questions, earn points and help others
