Question about General Electric GE SmartWater Household Water Filtration System - GNWH38F
My faucet is dripping--is there an easy fix, or
My faucet for my GE Smartwater under sink filtration system is dripping--is there an easy fix, or where can I get a faucet replacement. This does not have a seal like a normal faucet.
  • 332 Answers
You could aoways go to there web site alot of these type of faucet have real good warrantys you might just be able to get a replacement for free,,, depending on the age of the unit
Posted on Jun 28, 2009
Not enough hot water ge smartwater water heater gas
1) Copy following links:
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
http://waterheatertimer.org/Crossover.html
http://waterheatertimer.org/How-to-adjust-temperature-on-water-heater.html
2) Low temperature setting, extremely cold incoming water, Water leak or broken pipe running hot out of tank, crossover caused by bad faucet cartridge or bad recircirculation check valve,, bad gas control valve thermostat.
Feb 19, 2013 | General Electric GE SmartWater Household...
Water filter drain running all the time
Is this a new system? The should be a small restriction in the drain line. The size of the restriction is matched to the gallon per minutes of the R.O. system. Yours could be missing or not the right size, ie not enough restriction.
Jul 02, 2012 | General Electric GE SmartWater Household...
I need a handle for the Smart Water System
Here is the web page for GE. You will probably have to replace the whole faucet. When you call have the model # available for your system so they can supply the appropriate faucet. You may as well order more filters as they will be less expensive ordering on-line. These filters should really be changed every 6 months.
http://products.geappliances.com/ApplProducts/html/GEAResults.htm#Category=Dual_and_Single_Stage_Water_Filtration
These faucets are relatively easy to replace for the do it yourselfer.
RJ
Feb 24, 2011 | General Electric GE SmartWater Household...
MY GE SMART WATER FILTRATION HAS A DRIP ON THE
If it is coming from the canister, pull it off, check the o-ring, it is probably pinched. It will need to be replaced.
RJ
Mar 29, 2010 | General Electric GE SmartWater Household...
The red pressure relief button on my GE Smartwater GXWH35F whole house water filter system doesn't seem to be relieving pressure. As a result I cannot turn the filter cartridge in order to replace the...
To replace the filter cartridge. Do the following;
1. Assuming that you have a pump in your water filter
system, shut it off.
2 Close the intake valve before your filter system.
3.To relieve the pressure, open the faucet after your
filter system. Any of your faucet for that matter.
4.Once the pressure is relieved, you can of course
replace the the filter cartridge.
Nov 26, 2009 | General Electric GE SmartWater Household...
GE SmartWater RO Filter Tank Leaking?
I had same system under my sink for same amount of time and have since then removed entirely for health reasons related to Ro Systems. Mainly the tanks becomes contaminated [alge build up]and my faimly had constant nagging stomach aches which took a long time to resolve untill we decided to disconnected and throw out our "beloved healthy RO System" and decided to install a bi annual disposable type filter system. If you are expereanceing this I would advise the same as for the leak ,There are so many connections under there and it is usually not the tank but the fittings in lines some where and the reason it looks like the tank is because that is the lowest point the leak has traveled. So check all your fittings and if you decide on simple water filter I will advise you.
Please rate. Thanks jj505
jthomefix
gmail.com
Mar 28, 2009 | General Electric GE SmartWater Household...
Hot water faucet starts to whistle as it gets hotter
Ajust the stop under sink , or the line to the fixture, to elimate the whistle.
Mar 15, 2009 | General Electric GE SmartWater Household...
General Electric GE SmartWater Household Water Filtration System - GNWH38F Logo
277 people viewed this question
Top General Electric Water Heaters Experts
Paul Carew
Are you a General Electric Water Heater Expert? Answer questions, earn points and help others
