Question about Kenmore Elite 45986 Front Load Washer
It seems to be in th emiddle of a wash cycle and there is beeping alarm and the letters dl and f are flashing.
  • 82 Answers
Check the door to see if it is hot if its not i could be the heater element
Posted on Jun 27, 2009
My mass 6 Bosch washing machine is locked up and was blinking in red light letter F what do I do
"Sd" - (Excess suds)
F8 followed by E1 - (water supply error)
F9 followed by E1 - (drain pump system error)
F5 followed by E2 - (door will not lock)
F7 followed by E1 - (motor drive error)
"rL" - (remove load)
Washer making error beeps - Door has not been opened and closed for at least 3 cycles
Washer beeps when HOLD TO START is touched - Door not closed
F# E# code other than as described above appears in display - System Code Error
"nt" (interrupted) - Cycle was paused or cancelled
Clean Washer LED flashing at end of wash cycle - The washer has run 30 wash cycles and is indicating a reminder to run the Clean Washer cycle https://removeandreplace.com/2015/05/05/washing-machine-error-codes-front-and-top-load
Sep 21, 2017 | Bosch Washing Machines
What is Error Code "F6E1"
I had the f6 e1 code flashing on Whirlpool Duet washer. It would stop midcycle and beep. I cleaned out the lint filter. This seemed to help but gradually the problem got worse. I cleaned filter again. Still beeping. I read more solution and finally found the answer! I never put the cover back on. There is a switch on the left bottom that is held in by the cover. Works fine now!
Jan 14, 2012 | Whirlpool duet Washing Machines
What does F DL means i opened the door to add something then t came up F DL and wont start again, the cycle had just started I pressed cancel all it does is beep and flash F DL
Hello and welcome to FixYa
FDL is a door lock error and is caused due to an issue with the door lock when it is unable to lock/unlock. Please check the door lock mechanism/door switch assembly and replace the part that has gone bad so that the issue is resolved. Please get back to me if you have any other questions.
Kevin
Sep 14, 2011 | Whirlpool GHW9400 Duet Washer
When I try to use the washer I press the Express Wash Cycle as usual. The panel lights up as usual but when I press the start button it dosen't start. I don't hear the front load door lock as usual and...
'F' for fault, 'dL' for door lock and you don't hear it operating. It's pretty clear there is a problem either with the lock operating solenoid (highly likely 'cos you don't hear it operate) or the door lock sensor (not so likely).
Either you need to replace it or it needs replacing by a service engineer. Sorry, no other option ;-0(
Good luck,
John C
Mar 04, 2011 | Kenmore Elite 45986 Front Load Washer
Washing machine stops after wash cycle beeps flashes f11 or dL error
Might be the pump is plugged Remove the lower front panel and if you see a large white thumb screw attached to the pump remove by unscrewing to the left and clean.
Feb 27, 2011 | Kenmore Washing Machines
The washer beeps and flases f dl
it probably flashes also f11....to correct that problem , you must replace CCU board (upper board) and latch assembly...
F11: CCU board
FDL: latch problem
Jul 03, 2009 | Whirlpool Duet GHW9150P Front Load Washer
I pushed the start button and got some clicking noise, then I got an alarm sounding beep with a "F" flashing, then another alarm sounding beep with a "dl" flashing...which continued until I cancelled
If you give a specific model I could get a manual and see what i can find out but what i will do is direct you to the Kenmore questions line which is, (one last thing try unplugging the washing machine and then plug it back in maybe that will reset it, if you still get the error look below.)
Product questions
Call 1-888-KENMORE (1-888-536-6673).
also if you do not have the manual for the product you can obtain an online version here.
http://www.managemyhome.com/mmh/
if you look on the right hand side of the page you will see in bold letters.
Find Owners Manual
We've got manuals for every major brand in your home
just enter your model number in there and look through the manual for the troubleshooting section and then error codes.
Jun 01, 2009 | Kenmore Washing Machines
My tricity bendix washing machine flashing and beeping end light
Hi, we had something similar happen just before christmas. Our machine seemed to finish a cycle and started making beeping noise with end light flashing. Then when I switched it back on to do another load it just started beeping with end light flashing no matter what cycle was selected. Engineer has been out and advised that it is a fault with the motherboard so has ordered another one. Hope this is of some help. Machine was tricity bendix aw1400w.
Dec 14, 2006 | Tricity Bendix AW1400W Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
77 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
