The printer makes a jerking noise when print command is sent
SOURCE: Xerox 8560 printer error message
That is a fault in the process drive motor area.
It is the assembly that operates the maintenance kit movement.
You may simply have to reseat the maintenance kit.
The motor drive train may also be mistimed. If you have purchased that machine in the last year, there is a one year onsite warranty on that product. If so have your serial number ready and call 1-800-835-6100.
SOURCE: Xerox Phaser 8550 Won't Print
I was having the same problem. Turns out the IP address in the printer was incorrect. Once I changed the IP address the printer works just fine through our network again. Find your IP address off your server and follow these steps:
1. Choose Info on display menu, press okay button
2. Choose Info pages, press okay
3. Configuration pages-printer info, press okay
4. IP address should read: Correct IP Address number should be displayed on screen.
If not follow these steps to change it:
1. Find printer setup on display menu, press okay
2. Go to connection setup-press okay
3. Network setup-press okay
4. TCP/IP setup-press okay
5. Auto should show as “Off”
6. TCP/IP should show as “On”
7. DHCP/Boot should show as “Off”
If any of these are not listed on display correctly press ok, reset to either On or Off and then enter correct IP address.
Press okay button and follow steps on display menu to exit back to main menu display screen.
SOURCE: Xerox Phaser 3100 Printer Error Fuser Temp.
fuser Temp printer error problem.please give me the solution.
SOURCE: printer error fuser temp
You will have to replace the fuser. Call 1-800-835-6100 and follow the prompts to purchase parts. It isnt real expensive. Just make sure you still don't have some warranty left on the parts.
SOURCE: PDF documents do not print completely on my Xerox Phaser 8500
I am having the same problem. Sometimes my Xerox Phaser 8500 prints a PDF or web page fine, and other times I get pages and pages of what looks like PostScript code. I thought I had installed the most recent printer drivers, We are using primarily Macs with OS 10.4 or 10.5. One recent change is that we connected the printer to an Airport Express using a USB cable, which is sweet when it works correctly....any ideas???
