Question about RTO Letro Jet Vac Automatic Pool Cleaner without Booster Pump
Trying to find a repairman to look at my dolphin automatic pool cleaner which conked out.
    President:
  • RTO Master
  • 1,378 Answers
Contact us through www.arrowpools.net and select the dolphin service button along the bottom.
Posted on Jun 27, 2009
Goes to wall and turns itself over. It is clean.
Maytronics-Dolphin pool cleaner, Dolphin Diagnostic ...
? 3:44
www.youtube.com/watch?v=-x8hwghv8BE
Apr 4, 2012 - Uploaded by Swimming Pool Tips, Reviews & How To -MrDgvb1 Maytronics-Dolphin pool cleaner, Dolphin Diagnostic ... Solar Breeze: The Robotic Solar-Powered Pool Cleaner Review: http://youtu.be/jzWfClbOnIc ... Pentair Kreepy Krauly Legend Review, Troubleshooting & Tips:
Aug 08, 2015 | Dolphin Maytronics Diagnostic Robot...
I have a Dolphin Orbit diagnostic pool cleaner approx 3 years old haven't used it for some months. Put it back in the pool and now it won't work any suggestions
It is either going to be that your impeller is blocked or your drive system has something stuck in it. Check your wheels, axles, etc. for obstructions. If it is not either one of these, it is going to be an issue with the electrical system and you are going to have to take it into a pro that specializes in robotic pool cleaners.
Sep 17, 2010 | Smart Pool Inc Dolphin Diagnostic...
My dolphin begins to work, then stops. What could
There are several problems that could make these automatic pool cleaners fail to climb the walls. The cleaner could be too heavy. Empty and wash the filter bag and add floats if necessary. Make sure there is no water in the handle and that the brushes arent worn. If the cleaner is too light, add weights. If there are excessive amounts of algae on the wall, you will need to brush the walls first. The algae can prevent the cleaner from climbing. Make sure that the temp is at least 65 degrees in the pool. Make sure there is nothing caught in the impeller.
Jun 14, 2010 | Dolphin Maytronics Advantage
I have a dolphin pool cleaner and it won't sink. Any advice?
If these automatic pool cleaners will not sink, 9 times out of 10 it is because air is caught in the filter bag. The best solution is to turn the Dolphin upside down under water for a few minutes to remove the air or to machine wash the filter bag.
Jun 11, 2010 | Dolphin Maytronics Advantage
Need replacement motor. Two years old motor shot
The only place that you can buy a replacement motor for these automatic pool cleaners is directly from Dolphin.
May 31, 2010 | Smartpool Dolphin Robo - Kleen Above...
My Maytronics Dolphin pool cleaner does not entire pool
Check to make sure that your power supply is in a position that it can reach all sides of the pool. It may be as simple as repositioning your power supply to make it more effective. Also, with these automatic pool cleaners, you need to make sure that the filter is off, because it being on can affect where the cleaner is able to go. Finally, make sure the handle is locked in a diagonal position.
May 30, 2010 | Dolphin Maytronics Diagnostic Robot...
Dolphin Interactive pool cleaner stops running
If the dolphin is falling backward when it meets the water line, there is an easy fix. The automatic pool cleaners often have this problem. The easiest solution is to remove the handle floats and attach an 8 oz weight to the bottom inlet cover.
May 23, 2010 | Smart Pool Inc Dolphin Diagnostic...
Dolphin diagnotic pool cleaner just stopped working.Son took it out of water and wrapped cord up and almost pulled wires out of plug that goes into the motor mount.
The wires in the pool cleaner probably did disconnect from the motor. You might not be able to see the disconnection, but i would guess this is the problem since you already know your son made the mistake. You are probably going to have to take it to a service center so an electrician can reconnect your wires.
Aug 12, 2009 | Smart Pool Inc Dolphin Diagnostic...
RTO Letro Jet Vac Automatic Pool Cleaner without Booster Pump Logo
78 people viewed this question
Top RTO Pool & Spa Experts
john h
old fart58
Craig Butler
Craig Butler
Are you a RTO Pool and Spa Expert? Answer questions, earn points and help others
