Question about Freezers
M3 Turboair Refrigerator does not cool
M3 Turboair Refrigerator transported to Houston now does not cool at all. The longer it runs, the hotter the internal temp seems to get. (Not oven hot, but you get the idea). What's up with that? Any information is appreciated. Thanks!
  • Freezers Master
  • 1,252 Answers
Http://www.turboairinc.com/TB-Service/Service.html#SANDWICH
Try this web site. It has you M3 listed with manual but needs exacting model number to get right one.
good Luck - Hope this works for you. If not, let me know.
Posted on Jun 28, 2009
Refrigerator will not cool down
If the unit does not cool down at all, then you might have a refrigerant leak and be low on gas. Locate the leak, fix, and refill to manufacturer's specs.
Jan 18, 2014 | Kenmore 4.6 Cu. Ft. Compact Refrigerator...
The freezer side of the unit will freeze until it freezes over and will no longer keep the freezer frozen. The freezer then has to be defrosted so it can freeze again.
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
May 08, 2011 | Maytag Freezers
I have a Turbo Air TGF-49F freezer and it is not cooling. The compressor unit seems to work but when I turn the unit on all I hear is the compressor running continuously but nothing gets cold.
Difficult for you to check this I'm afraid, if the fan on the cooling unit is working unless you have an experienced 'ear' you will not hear the compressor running or worse still occasionally clicking.
Possible faults are
1. Compressor not running (the fan will run even if the compressor does not) electrical fault
2. Compressor seized (consult your service guy) also true for the rest of these
3. Compressor not pumping
4. Refrigerant leak
Not much hope for a cheap repair
Apr 14, 2011 | Turboair 49 cu. ft. Upright Freezer...
Freezer ok fridge not cold enough
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Mar 07, 2011 | Daewoo FRSU20IA Freezer
My frost free freezer is frosting up. what can I do
heatman101
Dec 21, 2010 | Kenmore Freezers
Freezer works ,fridge does not?
heatman101
Dec 12, 2010 | Freezers
The center bar section between the two doors is extremely hot. Freezer is cool, but not longer freezing food. Ice maker is no longer working.
PULL THE REFRIGERATOR OUT AND REMOVE THE BACK PANNEL.ITS PROBEBLY VERY DUSTY A;SO CHECK THE FAN IT MAY BE STUCK.TURN IT TOGET IT RUNNING. WATCH IT FOR A COUPLE OF DAYS IF IT STOPS AGAIN YOU NEED TO REPLACE IT.GOOD LUCK!
ERIC
Jan 23, 2010 | Amana Freezers
I TRANSPORTED A REFRIGERATOR FROM HOUSTON TO MEXICO IN A HORIZONTAL POSITION SO NOW WHEN I RE-CONNECT IT, ITS INTERIOR IS COLD BUT ITS EXERIOR WALLS ARE SO HOT...?
sound like the condenser fan motor by the compressor has stopped and the not allowing the proper cooling check that also you should have waited at least 6 hr upright before starting the unit
Aug 27, 2009 | Frigidaire Freezers
Commercial Freezers
I have worked in a lot of kitchens and don't really have a preferance. The top mounted compressor is better for you as it is easier to service and leaves more cabinet room. Dirt and dust also stay near the floor. YOu won't have to clean the filter as often up high The disadvantage to this in a kitchen is that kitchens are hot and up high is hotter still. Order a cheaper model. No glass doors, no stainless steel. You don't need these features.
Jun 24, 2008 | Traulsen 7 cu. ft. / 198 liter Commercial...
Freezer Problem
If it started to cool again the compressor was running. Check the condenser and make sure it is clean. Provide as much air movement through the garage as possible . 100 degrees is a high temperature to be operating a refrigerator in.
Jun 10, 2008 | Frigidaire Freezer 16.7 cu. ft. Upright...
Freezers Logo
409 people viewed this question
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
AJMAL KHAN
Are you a Freezer Expert? Answer questions, earn points and help others
