I bought the unit at an auction and it is locked.
SOURCE: magellan roadmate 760 gps receiver
unfortunately you have to purchase the unlock code from magellan. You contacted magellan and the unit is no longer able to be unlocked? Once I have more information I can assist you further.
Thank you,
lee
SOURCE: Magellan roadmate 800 unlock code
turn off your unit with the slide switch on the top. Hold down the repeat button or the one beside the slide switch and then put the slide switch back to the on position. Then select hdd tools then format. exit out and turn the switch off and back on and it should work
SOURCE: I cracked the display on
The only place you are likely to see one of such things is on ebay.
You may have to purchase it and have it shipped to you
SOURCE: My magellan roadmate 1700 will
The battery is on its last leg..
I do suggest replacing it with new one.
Here is the link online
1. http://www.batterytrader.com/magellan-roadmate-1700-2793801j3-replacement-battery-p-35557.html?language=URL_LANGUAGE
It costs 28.42 us dollars
2 http://www.batterybay.net/Battery-for-Magellan-RoadMate-1700-p/magelancs-mr1700sl.htm
It costs 16.79 us dollars.
