Question about Copystar CS-1810 Copier
Copystar 1810 document feeder slips grinding noice
Copystar 1810 document feeder slips and makes loud noise. Any houghts where to obtain spare parts?
Thank you,
Mike
    President:
  • 3,085 Answers
Sorry Mike,
No spare parts are available.
Posted on Jun 27, 2009
I have canon IR2010F copier with ADF and automatic feeder slips while taking the document in the feeder and makes tic tic tic tic noise while taking in the paper in the feeder, When we provide hand...
there are two locking handles for the adf on either side of the cover of adf i am sure one of them is broken or disfigured that why when u press it the adf works.i dont think this spare part is available u have to use ur own creative skills to make it through melting plastic to make a hook for that side
Jun 05, 2011 | Canon imageRUNNER 2010F Copier
Xerox grinding noise
the bearing on the motor or the rotating path must have damaged..
replace them
Jun 02, 2008 | Xerox WorkCentre Pro 215 Printer & Copier...
Error code C-710
check ur document feeder
May 03, 2010 | Copystar CS-1810 Copier
Copystar 1810 error E70
E70 Before switching on, originals were found on the
document feeder
Mar 05, 2010 | Copystar CS-1810 Copier
Hi I have a copystar CS 1810 and it started to make a loud clicking noise and now I have a code showing on the display 620 and C. Can you help Thank you, John
Hello sir; It's a fuser problem, but you need to reset, the procedure as follow; Press and holding down following keys in order, "stop/reset", "start", and "left copy density", then press "stop/reset" key again, then enter U63 press "start", window will display "CLE", press start again to clear.
Oct 27, 2009 | Copystar CS-1810 Copier
I have a kyocera 1810 copier. it has a error a 400
Does this machine have an ADF ( document feeder) on it? If so, check the connect cable from the document feeder to the machine. Also check the connectors from the scanner PWB to the document driver PWB. ( these are the 2 boards that do the communicating , the machine and the document feeder). If this machine does not have a ADF the check the side covers/ doors and make sure that they are closed securely.
Jan 05, 2009 | Kyocera KM-1510 Copier
Copystar CS-1810 Error Code
I'm sorry, Copystar is not a brand I am familiar with.
Be blessed.
Mar 19, 2008 | Copystar CS-1810 Copier
Loud grinding noice before starting to print
Mine makes a grinding noise when scanning or making copies. As long as everything is working, I just tolerate the noise in which the rest of the staff find amusing at first and then ignore it as I do.
Jan 25, 2008 | HP PSC 1210 All-In-One InkJet Printer
Loud groaning noise when copier is turned on.
sounds to me like the laser unit is going bad. common problem on this model.
razors
Nov 28, 2007 | Copystar CS-1510 Copier
Won't print documents from computer! PLEASE HELP! ASAP!
You cannot use an IP number for more then one device. It is an unique identification number. On the PORT section uner the Windows driver, change the last three digits for the Copystar machine, do not change the other ones (keep in mind that it should be unique!). Then go to the copier and thorugh the user panel get into network settings and enter the COMPLETE IP number just typed in Windows. It should work.
Sep 16, 2007 | Copystar CS-1810 Copier
Copystar CS-1810 Copier Logo
121 people viewed this question
Top Copystar Office Equipment & Supplies Experts
Kyocera HP Expert
Tammie Duggan
Tammie Duggan
Timothy Van Der...
Are you a Copystar Office Equipment and Supply Expert? Answer questions, earn points and help others
