Question about Nikon D200 Digital Camera
Nikon D200 - problems formatting card
Every time I try to format the card (as the camera insists on), it formats it and then says "Done", but every time I try to use it it tells me to format the card it does this when I use the menu to format the card. I have also tried the two format buttons (where you are supposed to hold them down until you see "For" and then realese them and press them again), but when I press them again nothing happens...
    Problem Solver:
  • 20 Answers
To use the two format buttons:
Press the "trashcan" format button and hold it. Then press the "mode" format button and hold it. Hold for approx 3~4 seconds. The screen will go blank and display "For" and the number of shots taken on the card.
Release both buttons. Then press the "trashcan" again followed by the format button. The screen will go back to normal, except the number of shots indicator, it will display "For". In a few seconds, your card will be formatted.
Although this may not solve your problem, you may have bad CF Card.
This is normal. Happens all the time.
Try another card. It should format fine. If it doesnt, take your camera to an authorized dealer/repair shop for maint.
Posted on Jan 05, 2010
My Nikon D80 shows an ERR, what should I do? FYI...I tried turning the camra on, removing the battery and pressing the shutter button for 30 seconds. That didn't work.
It's possible that you need to format the memory card. Formatting is found in the camera set up menu scroll down to "Format Memory Card" and follow on screen instructions.
Formatting should be done after each time you download pictures to your computer. Not delete, as delete does leave some data behind and eventually clogs the memory card so new data can not be placed on it. Another possibility is that the card somehow has become locked I'll include a diagram. Also a new card needs to be formatted to the cameratri3mast_228.jpg it is going to be used in.
Diagram
Jan 27, 2011 | Nikon D80 Digital Camera with 18-135mm...
When I put a card inside my camera D200, the massage displays and blinking "For", whats the issue and how can i fix it
Sounds like a format error. Try formatting the card. There is a function in the camera menus to do this. If it won't format or gives an error when you try, then there may be an issue with the connectors in the card slot or the card may be incompatible.
Maybe it is having trouble with the size of the memory. Memory cards have grown enormously in capacity in the last couple of years, and even relatively new cameras may not be able to cope with the memory size of the newest cards. It is often difficult to find out the maximum capacity a camera will use, as today's memory cards are much larger that those available when the manuals for the camera was written.
SD and SDHC cards fit the same slots, but many cameras won't work with the SDHC (high capacity) cards. SDHC is not backwards compatible.
Nov 10, 2010 | Nikon D200 Body Only Digital Camera
My Nikon D2oo is not working with Extreme 111 Compact flash cards that I just had the camera Format. There is an burn oder coming from either the camera or card.Wanting to put card not formatted with...
Hello, and thanks for using FixYa.
Please if the card contains any important pictures, connect it to a computer and copy them to the computer if they are not backed up. Then put the card in the camera and format the card in the camera, then you can connect it back to the computer, put those pictures in there and then the card back into the camera if that is what you wanted to do.
Note that the camera might not show your pictures, unless they are named the same way as original pictures taken with the camera.
Oct 22, 2010 | Nikon D200 Body Only Digital Camera
Format problems. every time I try to format the
Sound like a damaged card, can you try another card in the camera?
My D80 did this once and the card would work in other cameras but not the D80 again.
Jun 27, 2009 | Nikon D200 Digital Camera with 18-200mm...
Can not format card for Nikon d200
Is you camera plugged into you computer. If so, you cannot format the card from the camera, unless it is unplugged. This just happened to me (I was about to look for a bent pin). Unplugging solved the problem.
Sep 26, 2008 | Nikon D200 Body Only Digital Camera
D-200 not recognizing flash card
try to plug the card to a card reader, connect to a computer and check if it can still detect the card. If it does, check if your pix are still there, if none, reformat the card using the computer
May 05, 2008 | Nikon D200 Digital Camera with 18-200mm...
Nikon
The cards may have been corrupted in some way. Have you tried them in another camera or a card reader? If you have a reader, you might want to try formatting one of them from your computer.
Jan 10, 2008 | Nikon D70 Digital Camera
"for" message on LCD
It means you need to format your compact flash card.  Or...it may be that you've been bitten by the infamous BGLD problem (Blinking Green Light of Death) that caused my D70 to eventually be replaced by Nikon.  Thankfully it was under warranty at the point, which yours will not be.
If you haven't ever formatted your card, this is probably the problem.  To do so, just hold the two buttons that say "for" in red on them down for a second so that the letters "FOR" start to blink, then do it again while seeing that.  Let go and wait a couple of seconds.  The FOR will be replaced by numbers that tell you how many images you have left on the card until it is full.  I format my cards EVERY time I put a card back in the camera.  This prevents bad locations from cropping up on the card and creating bad images (corrupt).
Dec 27, 2007 | Nikon D70 Digital Camera with 18-50mm Lens
Nikon D200 and microdrive
I assume by "microdrive" you mean the compact flash card - right? Not all compact flash cards will word with the D200 - what is the brand of each of the flash cards you have (and are they all the same-purchased at the same time)?
Nov 02, 2007 | Nikon D200 Digital Camera with 18-200mm...
Nikon D200 Digital Camera Logo
139 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
