Question about Frigidaire FGQ332ES Gas Dryer
Dryer heats, then stops heating
I have a similar issue (gas dryer), my dryer starts fine & heats up for 5 minutes or so, but then there's a clicking/rattling sound & the heat stops (the air & tumble keeps going). I'm thinking there's a faulty sensor, but don't know how to test it. Any ideas?
SOURCE: Dryer tumbles but doesn't heat
The next step is checking the themostats.
Posted on Apr 05, 2007
JOE LLAMA
  • 26 Answers
SOURCE: LG ELECTRIC DRYER
Henry, its going to be 1 of 2 things. Check inside your drum, see if the vent in the rear has burning or discoloration around it. If it does, it sounds as if your vent is restricted causing the unit to overheat, so clean/fix/replace the venting and your support pulleys will need to be repalce ie flat spots from overheat. If there is no scoarching marks and you know its not the vent or heat issue, the drum seam may have parted causing the thump as every revolution is made.
Posted on Apr 04, 2008
docjohn174
  • 943 Answers
SOURCE: Amana ALE643RAW Gas Dryer
.hi with gas dryers the parts to look for are . the blower . will take longer to dry and noisy .The venting very important. The coils on the gas valve .Will cause the flame to only come on for a few minutes . then nothing so for that problem . replace the coils. Thanks the appliance doc
Posted on Sep 30, 2008
SOURCE: Homemaker HMCD50Y dryer
Because the dryer is running, but not heating, it sounds like the element. The rattling could be a part of the element that was weak and then broken during the move.
Inspect the element by taking off the back cover [unplug first] and remove the section of the flue-like piece that goes from bottom toward top at angle. The element is the spiral wire that runs inside that larger aluminum section.
Be sure to remeber where the 6 or 8 wires were connected. Grab a digital camera before removing the wires.
If you need an element, it comes with that aluminum section in a large box--not just the curly wires.
I've seen bad elements with breaks that could only be found by continuity testing and some that are obviously burnt in 2 or more places. I've also seen them ground out by a metal bone from a woman's bra. The move and the rattling--I'd check the element.
You have to remove the vent hose before removing the back cover. Be careful not to damage it. The cover can be a pain to reseat and fit around the vent housing at the same time--depending on work space. With part and tools in hand, 1 1/2 hours for a casual DIYer.
Posted on Oct 14, 2008
SOURCE: tumble dryer when switched on cuts power to all sockets in house
i had the same problem after it tripped the fuse i looked in the dryer where the cloths were and saw that there was a buildup of steam in the drum. i then realised that because i was using the dryer in a very cold outhouse in the winter the water in the cloths was condensing too fast for the machine to process, this in turn caused a a backup of steam in the drum which backed up so much that the heating elements shorted out and caused the fuse to trip out. i hope this helps. after moving the dryer to a warmer part of the house i have had no problems.
Posted on Dec 08, 2008
MY DRYER SERIAL NUMBER X073808040 STOPS AFTER 20 MINUTES
Kenmore Dryer - heats & runs but stops mid-cycle - Ask Me Help Desk
https://www.askmehelpdesk.com/.../kenmore-dryer-heats-runs-but-stops-...
Kenmore Dryer - heats & runs but stops mid-cycle. Asked Aug 30, 2006, 12:25 PM - 10 Answers .... Unfortunately it shuts off after a few minutes, I'll estimate about 5.After waiting about 30 minutes, ... New Member. Jun 16, 2010, 09:20 AM ...
Sep 15, 2015 | Dryers
Turns on, no heat, stopas after about 5 mins and all lights start blinking.
Good Afternoon Amanda,
I understand that your Frigidaire Affinity dryer, model# FAQE7001LW, is not heating as well as only running about 5-7 minutes of the cycle before shutting off. There are a couple things to check.
    1)The gas supply valve is not open. Check to make sure that the gas valve is open.
    2)The dryer does not have enough air supply to support the burner flame. Check with your local gas company to make sure that your dryer is installed correctly.
    3)There is a possibility that your LP gas supply tank is empty or there has been a utility interruption of natural gas. Try refilling or replacing the tank.
    If you are still having trouble with your dryer, I suggest giving it a hard reset, by either unplugging it or shutting the power off at your homes circuit breaker for 3-5 minutes. When power is restored, start any cycle. If you are still noticing that there is no heat and it stops 5-7 minutes into the cycle, I suggest contacting your local authorized technician. Hope this is helpful.
    -Best Regards-
    WP
May 14, 2014 | Frigidaire FAQE7001LW Dryer
I have a Maytag Neptune model number MDG9700A gas dryer...When I first turn the dryer on the dryer will get hot for about minute then the gas turns off and will not heat up again...It glows fine after...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 01, 2011 | Maytag Neptune MDG9700A Gas Dryer
Starts and then stops after 5 minutes and is not heating
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Sep 10, 2010 | Frigidaire Dryers
Gas dryer heat is intermediate
does the igniter glow white or orange? if it is orange you need to replace it. has to be white hot to ignite. if the igniter is white it could be the coils not opening the gas valve all the time - an intermittent problem.
Oct 04, 2009 | Kenmore 73952 Gas Dryer
Dryer runs then stops after short periods (5-10 mins)
THere maybe a thermal limit sensor gone bad. Keeps the dryer from over-heating. Located behind rear panel on most and mounted on the heat tube. Verify with volt/ohm meter if possible
Jul 28, 2009 | Kenmore 73952 Gas Dryer
Low heat output
A clogged or partially clogged vent . Especially if vents up thru the wall . If it vents straight out , make sure you have good air flow to the outside . Make sure the vent hose has no sharp kinks also . Try drying a load with the vent hose disconnected from the dryer . If clothes dry fine , that tells you the problem is elsewhere . Normally , a dryer either heats or doesn't heat . A heat for a few minutes then stops heating but continues to run complaint ,would be bad coils on the gas valve .
Jul 19, 2009 | Dryers
I HAVE A MAYTAG ATLANTIS GAS DRYER STOPS HEATING ABOUT 5 MINUTES IN
the flame going out is normal. the heat cycles on and off as called for by the thermostat. If the heat doesn't come back on i would start by changing the gas coils.
Oct 08, 2008 | Maytag Atlantis MDG7400AW Gas Dryer
Dryer heat shuts off after a few minutes.
replace the 2 black solenoids on the gas valve ..after heat up they sometimes will go bad and burner will not reignite even though the ignitor glows
Sep 23, 2008 | Dryers
Frigidaire FGQ332ES Gas Dryer Logo
535 people viewed this question
Top Frigidaire Dryers Experts
Tim Whalen
Sal De
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
