Question about Hitachi 53UDX10B 53" Rear Projection Television
Screen went black, red power light is flashing. Had power off all night same issue.
Checked all fuses, Ok. Smell something on the DP1X Convergence PWB. Please help.
  • 1 more comment
  • theonlyg Nov 18, 2007
    Same problem I replaced the 2 IC's and now the TV won't turn on. Red power light keeps blinking. I smell a burning scent also. 2 green lights on the center board inside of the TV are clicking and blinking.
  • Anonymous Nov 18, 2007
    screen has started going black, with power light flashing. I am able to turn off for a while and it will work again, but how can I correct problem before tv screen completely goes black?
    tv screen goes blank , but power light flashes. How can I repair before tv completely stops working?
    Genius:
  • 1,153 Answers
Change C603 and S901
Posted on Nov 26, 2007
Toshiba 57H81, power to transformer and flyback.
IF YOU REPLACED THE SAME PICO FUSE, YOU PROBABLY HAVE A BAD CONVERGENCE IC AGAIN . DID YOY SNUG UP THE IC TO THE HEAT SINK AND USE THERMAL HEAT COMPOUND ON THE NEW IC'S? ALSO CHECK SOLDER CONNECTIONS TO C810 AND C809 THE FUSE BY THE CAPACITORS MAY BE OPEN.
Jan 22, 2009 | Toshiba 57H81 57" Rear Projection...
Power Light blinking 5 times
check the resistors near the
stk's. There are some reports that they get fried when the stk's fry....or the other way around. The resistor ratings are labeled on the resistors. 2.2, 82, 180 or something like that. Also check the board as you turn on the tv. See if any glow red.
Sep 22, 2008 | Panasonic PT-47WX53 47" Rear Projection...
No Power
Ok, easy !!!.( take it out the box ) Look, in the front part of the box TV ( under convergence panel controls) you will see a little black box, we call high voltages splitter ( 5 red wires go to pictures tubes and screen focus box). Replaced it. Am suggested inspected for possible leak coolant, just for be sure noy leak coolant projection and prevent future problems. I hope this help you, Thank you !!!
Aug 03, 2008 | RCA P52926 52" Rear Projection Television
Akai pt4299hd
replace your STKs big black Ics STK394-250 there is 2 of them thses are your convergence ics.Also ck resistors and pico fuses.
Jul 22, 2008 | Akai PT4799HD Rear Projection Television
Toshiba 50h71 red light after fixing the convergence chips
Did you check to be certain none of the resistors were burned or open that power the ICs ? This is fairly common for one or two of the convergenvce resistors to be open when the ICs go out. Also double check the iC pins to insure that none of the pins are bridged with solder. If you need more assistance please let me know.
May 19, 2008 | Toshiba 50H71 50" Rear Projection...
Samsung 42" Plasma spn-4235 Went black
SOMETHING IS LOADING DOWN THE POWER SUPPLY...COULD BE THE Y-SUS BOARD OR UPPER OR LOWER Y-DRIVE BUFFERS...TAKE THE BACK OFF SET..GIVE IT THE SMELL TEST AND EYEBALL THE FLAT I.C.`S ON THE THIN BOARDS TO THE LEFT OF Y-SUS BD. IF NO BURNING SMELL AND NO CRACKS ON THE FLAT I.C.`S ...TRY REPLACING THE Y-SUS BOARD...NUMBER ONE PRIME SUSPECT...DO NOT POWER UP SET WITH BACK OFF UNLESS YOU ARE QUALIFIED SERVICE TECH...JOE ACE
May 13, 2008 | Samsung SPN4235 42 in. Plasma HDTV
51 big screen apex tv, convergence or verticle IC?
If the lines are thin and close together running horizontally, it may be the vertical driver, but that usually takes out the resistor and sometimes the diode in the B+ for the vert. Also you must replace the caps that caused the problem in the first place.
Feb 05, 2008 | Apex Digital GB5108 51" Rear Projection...
Toshiba 42H81 problem set won't turn on
This repair is for technical skilled only.....
1) Pull chassis
2)Replace open fuse(s)
3)Replace Convergence IC"s
4)Solder specific bad connects
5)Reassemble,test
Please read my previous posts concerning convergence repairs.
Or provide Make,model,age and symptom.............T.
Jan 03, 2008 | Toshiba 42H81 42" Rear Projection...
No Picture, Not Convergence Board Problem
PVAT! Give a real close look at the signal pcb for evidence of coolant leak.That will pull down power circuits, giving all kinds of strange symptoms.
Oct 07, 2007 | Samsung HCM4215W 42" Rear Projection...
Power button Flashes
Bad Convergence circuit , replace 2 STK392-110 & fuse will take care the problem
Jul 18, 2007 | Hitachi 43FDX15B 43" Rear Projection...
Hitachi 53UDX10B 53" Rear Projection Television Logo
159 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
