Question about Sunbeam Heating & Cooling
Sunbeam KY-25/Y fan problem
The exhaust fan of our Sunbeam KY-25/Y air conditioner is not working. Is this replaceable? If so, how do you remove it and where can we find a replacement fan?
I have a sunbeam ky-25 portable a/c that needs new exhaust fan but I can't find one
Posted on Aug 07, 2009
Can i add freon to this unit
unless you are certified refrigeration repairman no you can not .
Jul 27, 2015 | Sunbeam Ky-25/y Portable Air Conditioner
Exhaust hose
I would try any plumbing/heating store.
May 14, 2014 | Soleus KY-34 Portable Air Conditioner
Sunbeam portable air condition..all things work..compressor runs..but now cold air sunbeam portable air conditoner mode KY25 ..9,000 btu I have it since 2005..I've used it for one year..it's been...
sometimes storing an AC for long periods of time will allow the coolant that it uses to seep out, leaving you with an AC that seems to work, but won'tr cool any air. If you have a user's manual (or can find one) check to see what type of coolant it uses (if it's freon or something else) and if you can refill it. If you can refill the coolant, that should resolve your problem ... if not, you might be able to take it to a repair shop and have them do it for you. Good luck!
May 29, 2011 | Sunbeam SCA082RPC1 Portable Air...
Window Kit Parts
You can check at any hvac supply house like United refrigeration, fw webb, johnstone supply ,Lennox parts plus or grainger
Mar 07, 2018 | Sunbeam Heating & Cooling
Sunbeam KY-25 portable air conditioner not working.
Mine works but with a bad exhaust fan, want to sell yours?
Apr 26, 2009 | Soleus KY-25U Air Conditioner
Sunbeam air conditioner
It is normal for water to collect in the lower base of an air conditioner. See the section entitled: "There is water sloshing around inside." If water leaks out the front it is usually because the unit is tilted forward in the window frame. All air conditioners should be installed so they tilt slightly back to allow for proper removal of the condensation collected.
There is water sloshing around inside All window air conditioners will remove moisture from the air if there is any. Most window air conditioners collect this moisture in the bottom pan of the air conditioner and attempt to evaporate the moisture. The evaporation process works as follows: First, the water drips down off of the cold evaporator coils on the front of the unit. Then the water collects in the bottom of the air conditioner base, the "pan." If the air conditioner is installed properly it will be tilted slightly back.
The water then collects near the back of the unit. On some units, the fan blade used to cool the rear condensing coils will have a rim on the outside of the fins of the blade. This rim, or "slinger," will come close to touching the inside of the air conditioner pan when the fan is spinning. As the water collects in the pan and reaches the depth necessary for the fan ring to touch it, the ring will lift some of the water up and the fan will blow it at the condensing coils. Because the coils are warm, they will evaporate the moisture to the outside.
While this is happening it is normal to hear water splashing and sloshing around. As long as there is no water leaking inside the room that is being cooled there is no cause for concern.
Never drill into the bottom of and air conditioning unit to "let the water out."
if this helps please give me a fix ya
Jul 14, 2008 | Sunbeam Heating & Cooling
Solebus heating
yes, it is intended that way. I also have a Soleus and a special manual addendum sheet was inside the manual and it pointed out this feature..I think Soleus had a lot of customer phone-ins over this...I guess the idea for the exhaust is to withdraw moisture from the room, since anytime air is heated or cooled, moisture is a by-product that must be eliminated.
Nov 03, 2007 | Soleus KY-34 Portable Air Conditioner
Heating & Cooling Logo
862 people viewed this question
Top Sunbeam Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Craig Butler
Craig Butler
Are you a Sunbeam Heating and Cooling Expert? Answer questions, earn points and help others
