Question about GE WSXH208A Front Load Washer
Coins in my front loader
Coins, etc. bouncing around in my front load washer! How can I get it out?
  • 249 Answers
Remove element, remove coins with magnite telescopic type.replace element
Posted on Nov 24, 2007
Speed Queen Front Load Coin operated # SWFT71.. The coin changer keeps getting stuck. Any ideas on how to resolve this?? How do I remove the coin changer from inside the machine??
I have not fixed any of these front loaders for a while, but the top cover should come off (usually with a key), which will give you access to the coin mechanism and timer. There you usually need a 5/16 wrench or a flat screwdriver to remove the screw at the top of the mechanism.
Dec 04, 2012 | Speed Queen SWFT71 27" Coin Operated...
Kenmore 417.43042200 Front load washer. Replace shock absorbers and coin trap
Hello Karen,
The following video should fully explain everything that you should know on how to do this replacement and any warnings.
Good Luck!
Rich Lilja
Apr 27, 2017 | Kenmore HE2 Plus Front Load Washer
We are moving do we need to do anything special with the front loaders before moving.
it is recommend you put the shipping bolts that came with the unit back in. ideally you dont want the tub to be bounced around
Jun 02, 2010 | Whirlpool Duet GHW9150P Front Load Washer
How to unclog drain hose/pump? my front loader
First of start by checking the rubber gasket seals around the door and making sure those are good and clean and dry. Then inspect the barrel itself. My daughter loves to leave scraps of paper in her pockets that then get stuck in my front loader. Clear any debris from the barrel. Does your machine have a small front access panel or back access to get to the filter? Most front loaders have some sort of filter on them apart from the barrel. If you can find this part, it is a common culprit. Mine is a tube shaped basket with a front access panel on this one. On the front loader before this one is was back panel accessable under the drum. when you check these have a bucket and some thing mop up with handy, towels, mop, etc. One other thing to consider is the drain hose from the machine. I have flushed mine using a garden hose in the yard and used a little bleach.
May 12, 2017 | Frigidaire ATF6000ES Front Load Washer
LG front load washer A coin fell in between drum and housing.coin rubs on drum while spinning. how do you access the area between the drum and housing?
take off the front panel
on the bottom/front of the drum is the heater- held in with 10 mm nut - slacken the nut- this will loosen the heater in its holder- pull out the heater- this gives you access to the bottom of the tank
Jul 16, 2009 | LG WM-2277HW Front Load Washer
Front load washer- coin removal
Hi, The coin is probably inside the baffle that tosses the clothes around. I believe this nodel has a screw that holds the baffle in place. I hope this helps you. Please let me know if I can assist you further.
May 28, 2009 | GE WSXH208A Front Load Washer
The washer bounces during spin cycle
Front loaders don't like small loads. There's not enough clothing to settle around to balance it. Only do large loads.
Apr 29, 2009 | Kenmore HE2 Plus Front Load Washer
Bosch front loader washing machine water pump?
Always check to see if the water waste (located normally at bottom right) has no foreign objects in their such as bobby pins, coins etc It has happened to me 3 times (first time cost me $150)
Jul 10, 2008 | Bosch Nexxt Premium WFMC6400UC Front Load...
Bosch Washer
In due course they will land up in your outlet filter. It wuold be good to check all pockets, etc before loading the laundry into the machine.......I am talking about your washer; no comments about the dryer.
Dec 06, 2007 | Bosch Classixx WVF 2402 Front Load...
GE WSXH208A Front Load Washer Logo
128 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
