Question about Kenmore 98702 Stacked Washer/Dryer
Broken belt on Kenmore stackable # 417.99570140
I've replaced belts on mowers and such, but does this job require any special skills or tools that the average home handyman would need? Thanks, Phil
  • 82 Answers
Replacement belts are v shaped or groved they stretch slightley turn the power off take the back off put new belt on the moter first then on the pulley slightley turn the pully and the belt will pull itself on to the pully itself if you guide it on
Posted on Jun 27, 2009
Timing chain replaced on 04 range rover and now no power
The most likely cause is that the timing belt has been installed incorrectly. To install a timing belt is a skilled job that needs special tools to line up the engine and camshafts Get it wrong and you will get low power, and possibly engine damage. Get those who did the job to check it.
Jan 01, 2016 | 2004 Land Rover Range Rover
Need to replace belt
Search Results
    How to repair a KENMORE double decker washer&dryer ...
    ? 4:59
    www.youtube.com/watch?v=Rc_ZGugYBTY
    May 31, 2014 - Uploaded by MrProductionist
    How to repair a broken dryer belt from a Double Decker Washer and Dryer. ... I have a Kenmore stackable Washer-Dryer, and the dryer belt is ...
Oct 21, 2015 | Frigidaire FFLE1011MW White Washer/Dryer...
Timing belt worn. how and what type of skills do i need to get it right? i have a 1998 ford escort coupe 2.0 4 cylinder ztech engine
This is not a recomended job for unskilled persons ,it requires a lot of special tools and if you get it wrong you can seriously damage the engine
Jan 21, 2011 | 1998 Ford Escort
I need to replace broken serpentine belt but cannot get to the area. Do I have to take out the coolant reservoir?
yes you do.take out anything that is going to be in your way this will make the job alot easier to do.
Feb 07, 2010 | 2004 Chevrolet Cavalier
How to change a timing belt on a 2000 galant
Changing a timing belt is a job that is better left to the professionals. On some engines if it is not done properly severe engine damage can result. Damage such as bent valves, broken pistons etc. Seriously if you are here on Fixya asking about timing belt replacement you probably do not have the mechanical expertise to properly do the job. In addition on some vehicles special tools are required for disassembly and assembly.
Hope this helps
Bob
Oct 17, 2009 | Mitsubishi Galant Cars & Trucks
1997 Dodge Intrepid 3.5L How to replace water pump and timing belt.
This a dificult and time consuming project. Suggest you purchase you a repair manual which gives you diagrams and detailed instructions for this type of repair. Difficult to explain procudure in writing.
Sep 10, 2009 | 1997 Dodge Intrepid
Stackable washer/dryer
hi..
When your dryer drum isn’t turning anymore, it’s usually a broken belt. Tearing the dryer apart is usually straight-forward enough but stringing the new belt on the motor and idler pulley can be tricky. The Complete Encyclopedia of Dryer Belt Configurations shows the belt configurations for almost every dryer brand you can think of.
this will fix ur problem..
thank u rate me
May 25, 2009 | Kenmore 93702 Top Load Stacked Washer /...
Sovereign SLM 1500 lawn mower blades have stopped turning
The belts are available part number is SV150. Call ALM Manufacturing 01423 797208 for advice/stockists.
Apr 13, 2009 | Garden
Water pump
It's time-consuming, as requires removing aux drivebelt (with alternator etc on it), and the cam belt. Well worth replacing the cam belt, aux belt and crankshaft oil seal while there. It's quite hard, but no special tools needed - except the Honda manual/instructions for setting up correctly (unless you mark the belt and replace exactly on pulleys).
Sep 15, 2008 | 1995 Honda Prelude
Kenmore 98702 Stacked Washer/Dryer Logo
821 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
