Question about Maytag PAV2300 Top Load Washer
White residue under washing machine - Maytag PAV2300 Top Load Washer
2 Suggested Answers
SOURCE:
  • 76 Answers
SOURCE: our maytag washing machine model
screws loose
Posted on Apr 12, 2011
White Residue on black clothes after cycle
If the FILTER is not cleaned after each load was completed this will happen.
Mar 01, 2014 | GE Washing Machines
White residue on black clothing
I am sure you did not wash dark clothes with white, right?
How old is the washing machine?
Do you feel/see any white particles in the basket of the machine, when the cover is open, and it dries out inside?-- when you wipe your hand inside (the dry machine), do you pick up white residue?
What type of soaps are you using?-- any chance they could be causing the residue?
How hard is your water? (Do you have a water softener in the water system?
Please tell us more about your circumstances.
Mack B
Dec 28, 2010 | Washing Machines
White powder/residue left on clothes
could be a faulty water valve and not rinsing
Dec 14, 2009 | Whirlpool Washing Machines
Dishwasher leaving white sticky residue on dishes
maybe machine is not filling with correct amount of water try adding an extra omunt of water say 2 litres and see if the machine sounds like it is washing properly
open the door when operating and observe wah arm positions as these turn aroun as it washes
also check that the wash arms are not blocked
Nov 03, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Hard scratchy towels. Have used all wash cycles, and use fabric softener
have you tried just white vinegar as your rinse aid. Do a full cycle of your washing machine using white vinegar instead of detergent, to clean any residue from pipes, and then in the next wash try white vinegar as your rinse aid.
Apr 18, 2009 | Bosch Nexxt 700 Series WFMC6401UC Front...
My washing machine is leaving little residue on all my clothes after a complete wash, What are they? and how do you get rid of it, the washing machine is not yet a year old
Describe the residue. If it's oily (black, dk green) then the seal is out of the tranny and oil is getting into the tub. Dry cleaning is best for oil based stains. Liquid dish detergent is good also. On white it is tough to remove. Your washer will need a new transmission or replacing.
If it is powdery I'd guess a soap buildup, especially if you've recently changed detergents. The new detergent is breaking up the old soap scum in the outer drum and it is redepositing onto your clothes. This should wash out/off.
Tip: If it's a soap residue, fill washer full without clothes with hot water. Add 1 gallon white vinegar and more hot water until the unit if as full as possible. Agitate 15 minutes and drain. Rinse with a full level and drain.
Jan 24, 2009 | Samsung SW62ASP Top Load Washer
Leaving white residue on dishes salt ok any ideas please
A white residue could be some type of water hardness or residual detergent. Wash dishes by hand and dry, does white residue remain? If yes, there is too much detergent in machine. If no, water problem. Consult with a local water expert
Aug 19, 2008 | GE Adora GHDA656LSS Stainless Steel...
Oily residue under machine
it is coming from the transmission seal the part number is wh8x281 it is located behind the transmission pulley, remove the pulley and remove the old seal and intall the new one
Apr 13, 2008 | Washing Machines
Maytag PAV2300 Top Load Washer Logo
Top Maytag Washing Machines Experts
jimorris77
Sheldon Dedek
Bill Long
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
